Vm garuda help!
Good day to all! Please help, there was a problem with Garuda when installing it on a virtual machine (Virtual Box).When you first turn it on, it says welcome message and
time, tz keytable, lang, NO SUITABLE KERNELS AVAIBLE, memtest, Launch currently installed BIOS system, Reboot. I don’t understand where to click when I’ve set everything up.
Our distro is optimized for performance on real hardware. Installing in virtual machines is not recommended as it may result in a bad experience due to the missing graphics acceleration …
bad (
I don’t seem to have understood the question :grin:
Ich scheine die Frage nicht verstanden zu haben :grins:
:down_arrow:
This:
Obviously you installed Garuda Linux and did not remove the live.iso afterwards, therefore the live environment is booted again. You can also remove the installation medium from the VM or change the boot sequence in the BIOS of the VM.
