For some .mkv files, VLC just shoots with any of:
VLC could not decode the format "a52 " (A52 Audio (aka AC3))VLC could not decode the format "eac3" (A/52 B Audio (aka E-AC3))
VLC could not decode the format "a52 " (A52 Audio (aka AC3))VLC could not decode the format "eac3" (A/52 B Audio (aka E-AC3))Seems they have no issues
I have searched through their forum and such errors were discussed for version 2.x, but long been fixed. Are there probably codecs missing? How do I re-install it but also clean up the config?
I use mpv, but conf files are often in ~/.config/
so maybe in ~/.config/vlc/
find -iname '*vlc*'
or pamac
Nope, deleteing the config dir doesn't help.
mpv works. I need to learn the shortcuts now
Strange. Today it magically works. And I have not installed any updates.
We still do not have an answer to this??
And do you have those codecs installed?
We have ![]()
Please open a new help request, if still necessary, after you have worked through the template.
I just closed this five-year-old thread.
