My volume in VLC is always defaulting to 100% no matter what I do with pavucontrol. I have read many posts on how to get the default to be something like 70% but I haven't been able to get it to work. Any suggestions are welcome.
It seems to be that pulseaudio is supposed to set the default for VLC but it isn't working for me.
Kernel: 5.16.4-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=746085a3-1efd-44d0-9e3f-bea3af666d4d rw rootflags=subvol=@
systemd.unified_cgroup_hierarchy=1 loglevel=3 nvidia-drm.modeset=1
Desktop: GNOME 41.3 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.3
Type: Desktop System: Gigabyte product: X470 AORUS ULTRA GAMING v: N/A
Mobo: Gigabyte model: X470 AORUS ULTRA GAMING-CF v: x.x
serial: <superuser required> UEFI: American Megatrends v: F3
date: 08/08/2018
Info: model: AMD Ryzen 5 2600X bits: 64 type: MT MCP arch: Zen+
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 2671 high: 3906 min/max: 2200/3600 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3901 2: 3903
3: 3904 4: 3906 5: 1856 6: 1752 7: 2155 8: 2015 9: 2365 10: 2195 11: 1916
12: 2184 bogomips: 86399
STIBP: disabled, RSB filling
Device-1: NVIDIA TU106 [GeForce RTX 2070] vendor: Micro-Star MSI
driver: nvidia v: 510.47.03 alternate: nouveau,nvidia_drm bus-ID: 09:00.0
chip-ID: 10de:1f02 class-ID: 0300
Device-2: Logitech HD Pro Webcam C920 type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-10:7 chip-ID: 046d:082d
Display: wayland server: X.Org 1.21.1.4 compositor: gnome-shell driver:
loaded: nvidia unloaded: modesetting alternate: fbdev,nouveau,nv,vesa
Screen-1: 0 s-res: 3440x2520 s-dpi: 96 s-size: 910x667mm (35.8x26.3")
s-diag: 1128mm (44.4")
Monitor-1: XWAYLAND0 res: 3440x1440 hz: 60 dpi: 109
size: 800x340mm (31.5x13.4") diag: 869mm (34.2")
Monitor-2: XWAYLAND1 res: 1920x1080 hz: 60 dpi: 47
size: 1040x590mm (40.9x23.2") diag: 1196mm (47.1")
OpenGL: renderer: NVIDIA GeForce RTX 2070/PCIe/SSE2
v: 4.6.0 NVIDIA 510.47.03 direct render: Yes
Device-1: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 09:00.1 chip-ID: 10de:10f9
v: kernel bus-ID: 0b:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: Logitech HD Pro Webcam C920 type: USB
Sound Server-1: ALSA v: k5.16.4-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.44 running: yes
Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
port: f000 bus-ID: 06:00.0 chip-ID: 8086:1539 class-ID: 0200
Local Storage: total: 2.75 TiB used: 37.66 GiB (1.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 PRO 1TB
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 1B2QEXP7
temp: 51.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: SDSSDH3 2T00
type: SSD serial: <filter> rev: 00RL scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 37.66 GiB (2.0%)
used: 580 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
used: 37.66 GiB (2.0%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 62.81 GiB used: 0 KiB (0.0%) priority: 100
Message: No sensor data found. Is lm-sensors configured?
Processes: 379 Uptime: 20h 18m wakeups: 1 Memory: 62.86 GiB
used: 10.69 GiB (17.0%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 Packages: pacman: 1544 lib: 398 Shell: fish v: 3.3.1
running-in: tmux: inxi: 3.3.12
e[1;34mGaruda (2.5.4-1):e[0m
e[1;34m System install date:e[0m 2021-12-26
e[1;34m Last full system update:e[0m 2022-02-02
e[1;34m Is partially upgraded: e[0m No
e[1;34m Relevant software: e[0m NetworkManager
e[1;34m Windows dual boot: e[0m Probably (Run as root to verify)
e[1;34m Snapshots: e[0m Snapper
e[1;34m Failed units: e[0m bluetooth-autoconnect.service
