vkBasalt greyed out in GOverlay
I haven’t changed vkbasalt at all. mangohud works but vkBasalt is greyed out in goverlay. vkbasalt is installed from my initial install of garuda.
  Kernel: 6.6.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=1e0ad18c-0993-40e1-b5e4-31a3b75f8dad rw rootflags=subvol=@
  Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin_wayland vt: 1
  Type: Desktop System: Micro-Star product: MS-7C95 v: 1.0
  Mobo: Micro-Star model: B550M PRO-VDH WIFI (MS-7C95) v: 1.0
    serial: <superuser required> UEFI: American Megatrends LLC. v: 2.H0
    date: 09/21/2023
  Device-1: ps-controller-battery-48:18:8d:5f:bf:6b model: N/A serial: N/A
    charge: N/A status: full
  Info: model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2 gen: 3
    family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701030
    L3: 32 MiB desc: 2x16 MiB
  Speed (MHz): avg: 3846 high: 4326 min/max: 2200/4426 boost: enabled
    scaling: driver: acpi-cpufreq governor: performance cores: 1: 3819 2: 3998
    3: 3897 4: 3569 5: 3600 6: 3600 7: 3600 8: 3600 9: 3767 10: 3600 11: 4321
    12: 3600 13: 4324 14: 4326 15: 4325 16: 3600 bogomips: 115198
    vendor: Gigabyte driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
    lanes: 16 ports: active: DP-2 empty: DP-1,HDMI-A-1,HDMI-A-2
    bus-ID: 2d:00.0 chip-ID: 1002:73df class-ID: 0300
    gpu: amdgpu display-ID: 0
  Monitor-1: DP-2 res: 2560x1440 size: N/A modes: N/A
    drv: radeonsi inactive: gbm
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6700 XT (navi22 LLVM
    16.0.6 DRM 3.54 6.6.3-zen1-1-zen) device-ID: 1002:73df memory: 11.72 GiB
    unified: no display-ID: :1.0
  API: Vulkan v: 1.3.269 layers: 13 device: 0 type: discrete-gpu name: AMD
    Radeon RX 6700 XT (RADV NAVI22) driver: mesa radv v: 23.2.1-arch1.2
    device-ID: 1002:73df surfaces: xcb,xlib,wayland device: 1 type: cpu
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 2d:00.1 chip-ID: 1002:ab28
    bus-ID: 2f:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Sony DualSense wireless controller (PS5)
    driver: playstation,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 480 Mb/s
    lanes: 1 mode: 2.0 bus-ID: 1-4:7 chip-ID: 054c:0ce6 class-ID: 0300
  Device-4: C-Media Blue Snowball driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:3
    chip-ID: 0d8c:0005 class-ID: 0300 serial: <filter>
  Device-5: FiiO K3 driver: snd-usb-audio type: USB rev: 2.0 speed: 480 Mb/s
    lanes: 1 mode: 2.0 bus-ID: 3-2:7 chip-ID: 2972:0047 class-ID: fe01
  API: ALSA v: k6.6.3-zen1-1-zen status: kernel-api with: aoss
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 29:00.0
  IF: enp42s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:6 chip-ID: 8087:0aa7
    lmp-v: 8 status: discoverable: no pairing: no class-ID: 7c0104
  Local Storage: total: 2.73 TiB used: 363.83 GiB (13.0%)
    fw-rev: 2B2QEXM7 temp: 48.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 500GB
  ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 500GB
    tech: SSD serial: <filter> fw-rev: 2B6Q scheme: MBR
  ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 363.8 GiB (19.5%)
    used: 35.5 MiB (11.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    used: 363.8 GiB (19.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-1: swap-1 type: zram size: 31.26 GiB used: 142.8 MiB (0.4%)
  System Temperatures: cpu: 52.2 C mobo: N/A gpu: amdgpu temp: 58.0 C
    mem: 64.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 985
  Processes: 482 Uptime: 3h 2m wakeups: 0 Memory: total: 32 GiB
  available: 31.27 GiB used: 6.28 GiB (20.1%) Init: systemd v: 254
  default: graphical tool: systemctl Compilers: gcc: 13.2.1 Packages: 1904
  pm: pacman pkgs: 1896 libs: 520 tools: pamac,paru pm: flatpak pkgs: 8
  Shell: fish v: 3.6.1 running-in: konsole inxi: 3.3.31
Garuda (2.6.19-2):
  System install date:     2023-10-10
  Last full system update: 2023-12-03 ↻
Did you search the web about?
Did you check issue in
I have been looking through the vkbasalt github and searching for solutions online but i cannot find anything or i’m too stupid to realize what the problem actually is
