Kernel: 6.0.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=838e1ee0-ad5c-4f2e-bb04-93779801833f rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.26.2 tk: Qt v: 5.15.7 info: latte-dock
Type: Laptop System: NEC product: PC-VK27MDZEJ v: N/A
Mobo: NEC model: Justice3-SH v: 3A3B serial: <superuser required>
UEFI: NEC v: NOTE Version /745A2304 date: 10/23/2014
ID-1: BAT1 charge: 15.7 Wh (100.0%) condition: 15.7/24.3 Wh (64.5%)
volts: 3.8 min: 10.8 model: NEC PC-VP-WP135/OP-570-77018 type: Li-ion
serial: N/A status: full
Info: model: Intel Core i5-4310M bits: 64 type: MT MCP arch: Haswell
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2870 high: 3400 min/max: 800/3400 scaling:
driver: intel_cpufreq governor: performance cores: 1: 2694 2: 2694 3: 3400
4: 2695 bogomips: 21550
vulnerable
Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Lenovo
driver: i915 v: kernel arch: Gen-5.75 process: Intel 45nm built: 2010 ports:
active: VGA-1,eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:0416
Screen-1: 0 s-res: 2806x900 s-dpi: 96 s-size: 742x238mm (29.21x9.37")
s-diag: 779mm (30.68")
Monitor-1: VGA-1 pos: right model: Lenovo L197 Wide serial: <filter>
built: 2009 res: 1440x900 hz: 60 dpi: 89 gamma: 1.2
size: 410x257mm (16.14x10.12") diag: 484mm (19.1") ratio: 16:10 modes:
max: 1440x900 min: 720x400
Monitor-2: eDP-1 pos: primary,left model: LG Display 0x038e built: 2013
res: 1366x768 hz: 60 dpi: 101 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: 1366x768
API: OpenGL v: 4.6 Mesa 22.2.2 renderer: Mesa Intel HD Graphics 4600 (HSW
GT2) direct render: Yes
vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:03.0
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
Sound API: ALSA v: k6.0.7-zen1-1-zen running: yes
Device-1: Intel Ethernet I217-LM vendor: Lenovo driver: e1000e v: kernel
port: 4080 bus-ID: 00:19.0 chip-ID: 8086:153a class-ID: 0200
IF: enp0s25 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:08b1 class-ID: 0280
bus-ID: 3-7:4 chip-ID: 8087:07dc class-ID: e001
Local Storage: total: 465.76 GiB used: 86.78 GiB (18.6%)
model: WD5000LPVX-08V0TT5 size: 465.76 GiB block-size: physical: 4096 B
rev: 1A05 scheme: GPT
ID-1: / raw-size: 241.19 GiB size: 241.19 GiB (100.00%)
used: 86.74 GiB (36.0%) fs: btrfs dev: /dev/sda5 maj-min: 8:5
used: 38.7 MiB (40.3%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 241.19 GiB size: 241.19 GiB (100.00%)
ID-4: /var/log raw-size: 241.19 GiB size: 241.19 GiB (100.00%)
ID-5: /var/tmp raw-size: 241.19 GiB size: 241.19 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.67 GiB used: 2.8 MiB (0.0%) priority: 100
System Temperatures: cpu: 59.0 C mobo: N/A
Processes: 235 Uptime: 14h 16m wakeups: 4 Memory: 7.67 GiB
used: 2.98 GiB (38.9%) Init: systemd v: 251 default: graphical
pkgs: 1955 libs: 544 tools: octopi,paru Shell: fish v: 3.5.1
running-in: alacritty inxi: 3.3.23
Garuda (2.6.9-1):
System install date: 2022-09-17
Last full system update: 2022-11-08 ↻
running vivaldi-stable shows this
╰─λ vivaldi-stable
chrome_crashpad_handler: --database is required
Try 'chrome_crashpad_handler --help' for more information.
[30432:30432:1108/142530.603189:ERROR:socket.cc(120)] recvmsg: Connection reset by peer (104)
fish: Job 1, 'vivaldi-stable' terminated by signal SIGTRAP (Trace or breakpoint trap)
please help if anyone knows the problem
