I have created some themes for the Vivaldi Browser using the fine artwork showcased here. Hopefully they'll give Garuda a bit of free promotion ![]()
Can you tell me how to change the icons used by vivaldi? I kinda thought we were locked with the default icon look shipped by vivaldi.
Vivaldi now allows icons to be changed - see the video on this page:
Also see here:
I was going to keep this thread open so that new themes can be posted as they're done, but I think this is now out of the question as it's been solved ![]()
In the show case there should be no solutions, but even if there are, you can undo it or a moderator will just open the thread again.
Am I OK to ignore the 'solved'?
Sorry, I don't see that this thread is resolved.
As I said, even if someone were to mark it as resolved, you can undo that.
Likewise, if it were to close automatically.
I made the first post a wiki post so you can expand/edit it at any time.
More themes are below. I've stuck with the plastic theme for the icons because I like it.
I've tidied up some of the above themes and added some new ones.
Most of the above have been revisited, and the new ones are below....
Its nice to see Garuda is now on Vivaldi ![]()
Some more themes...
Some more new themes...
Some more themes...
I got the animated cube approved as a theme....
Would it be possible for someone to upload the animated webp to gitlab as I haven't got a clue how this is done, and if it is done it will provide a good preview of the animation - as shown in image source of this theme...
Some new themes...
The following have been updated. I converted the images from optimized PNG to lossless webp to eliminate artifacts...
You are really starting to make me think I should be using Vivaldi as my browser ![]()
