Vivaldi browser stopped starting due to rsync
garuda-inxi:
  Kernel: 6.1.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    root=UUID=2e84a14e-89d1-4ea8-b55e-0e0d7524db3f rw [email protected]
    loglevel=3 ibt=off
  Desktop: KDE Plasma v: 5.27.1 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Desktop Mobo: ASUSTeK model: PRIME H310-PLUS v: Rev X.0x
    serial: <superuser required> UEFI: American Megatrends v: 0401
    date: 02/28/2018
  Info: model: Intel Core i5-9500 bits: 64 type: MCP arch: Coffee Lake
    desc: 1x9 MiB
  Speed (MHz): avg: 4043 high: 4300 min/max: 800/4400 scaling:
    driver: intel_pstate governor: performance cores: 1: 4271 2: 4300 3: 2936
    4: 4283 5: 4170 6: 4300 bogomips: 36000
  Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: ASUSTeK
    ports: active: HDMI-A-1 empty: DP-1 bus-ID: 00:02.0 chip-ID: 8086:3e92
  Device-2: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: ASUSTeK
    driver: nvidia v: 525.89.02 alternate: nouveau,nvidia_drm non-free: 525.xx+
    status: current (as of 2023-02) arch: Pascal code: GP10x
    process: TSMC 16nm built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
    link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1c82
    alternate: fbdev,intel,nouveau,nv,vesa dri: iris gpu: i915 display-ID: :0
    s-diag: 414mm (16.31")
  Monitor-1: HDMI-A-1 mapped: HDMI-1 model: Acer K202HQLA serial: <filter>
    built: 2016 res: 1366x768 hz: 60 dpi: 80 gamma: 1.2
    size: 434x236mm (17.09x9.29") diag: 494mm (19.4") ratio: 16:9 modes:
    max: 1366x768 min: 720x400
  API: OpenGL v: 4.6 Mesa 22.3.5 renderer: Mesa Intel UHD Graphics 630 (CFL
    GT2) direct-render: Yes
  Device-2: NVIDIA GP107GL High Definition Audio vendor: ASUSTeK
    link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:0fb9
  Sound API: ALSA v: k6.1.12-zen1-1-zen running: yes
    speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 05:00.0 chip-ID: 10ec:8168
  IF: enp5s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Device-2: Ralink RT5370 Wireless Adapter type: USB driver: rt2800usb
    bus-ID: 1-4:3 chip-ID: 148f:5370 class-ID: 0000 serial: <filter>
  IF: wlp0s20f0u4 state: down mac: <filter>
  Local Storage: total: 2.05 TiB used: 292.14 GiB (13.9%)
    type: HDD rpm: 5400 serial: <filter> rev: SDM2 scheme: MBR
  ID-2: /dev/sdb maj-min: 8:16 model: UDore 256GB size: 238.47 GiB
    serial: <filter> rev: 1A0 scheme: GPT
  ID-3: /dev/sdc maj-min: 8:32 vendor: Toshiba model: DT01ACA100
    type: HDD rpm: 7200 serial: <filter> rev: A8A0 scheme: GPT
  ID-1: / raw-size: 116.95 GiB size: 116.95 GiB (100.00%)
    used: 24.49 GiB (20.9%) fs: btrfs dev: /dev/sdb6 maj-min: 8:22
  ID-2: /boot/efi raw-size: 800 MiB size: 798.4 MiB (99.80%)
    used: 608 KiB (0.1%) fs: vfat dev: /dev/sdb5 maj-min: 8:21
  ID-3: /home raw-size: 531.12 GiB size: 531.12 GiB (100.00%)
    used: 267.65 GiB (50.4%) fs: btrfs dev: /dev/sda6 maj-min: 8:6
  ID-4: /var/log raw-size: 116.95 GiB size: 116.95 GiB (100.00%)
  ID-5: /var/tmp raw-size: 116.95 GiB size: 116.95 GiB (100.00%)
  ID-1: swap-1 type: zram size: 23.32 GiB used: 511.2 MiB (2.1%)
  System Temperatures: cpu: 47.0 C mobo: N/A
  Processes: 335 Uptime: 2h 15m wakeups: 0 Memory: 23.32 GiB
  used: 10.1 GiB (43.3%) Init: systemd v: 253 default: graphical
  pkgs: 2155 libs: 556 tools: octopi,paru pm: flatpak pkgs: 0 Shell: fish
  v: 3.6.0 running-in: qterminal inxi: 3.3.25
Garuda (2.6.15-1):
  System install date:     2023-02-22
  Last full system update: 2023-02-22
  Failed units:            anbox-container-manager.service bluetooth-autoconnect.service
The Vivaldi browser has stopped starting, and instead of starting, the process "rsync -aX --in place --no-whole-file /home/username/.config/vivaldi-backup/ /run/user/1000/psd/username-vivaldi" appears. And the browser will not start until you remove this process, while the current session and tabs are lost. On the browser forum, I was answered "There is no vivaldi-backup builtin with rsync in Vivaldi browser." and that this is a distro problem and not a browser. Can you tell me please what to do with this problem? I'm just not a very advanced user.
What is the output of systemctl status psd.service?
Unit psd.service could not be found.
My mistake, try with the --user flag:
systemctl --user status psd.service
● psd.service - Profile-sync-daemon
     Loaded: loaded (/usr/lib/systemd/user/psd.service; enabled; preset: enabled)
     Active: active (exited) since Wed 2023-02-22 18:45:23 +06; 4h 4min ago
       Docs: man:psd(1)
             man:profile-sync-daemon(1)
             https://wiki.archlinux.org/index.php/Profile-sync-daemon
   Main PID: 4077 (code=exited, status=0/SUCCESS)
        CPU: 541ms
feb 22 18:45:18 iindin-systemproductname systemd[3677]: Starting Profile-sync-daemon...
feb 22 18:45:19 iindin-systemproductname profile-sync-daemon[4077]: Ungraceful state detected for /home/iindin/.firedragon/09awrc7s.default so fixing
feb 22 18:45:19 iindin-systemproductname profile-sync-daemon[4077]: Ungraceful state detected for /home/iindin/.firedragon/jpc9w1r3.default-release so fixing
feb 22 18:45:19 iindin-systemproductname profile-sync-daemon[4077]: Ungraceful state detected for /home/iindin/.config/chromium so fixing
feb 22 18:45:19 iindin-systemproductname profile-sync-daemon[4077]: Ungraceful state detected for /home/iindin/.config/vivaldi so fixing
feb 22 18:45:22 iindin-systemproductname profile-sync-daemon[4077]: Ungraceful state detected for /home/iindin/.config/google-chrome so fixing
feb 22 18:45:23 iindin-systemproductname profile-sync-daemon[4077]: psd startup check successful
feb 22 18:45:23 iindin-systemproductname systemd[3677]: Finished Profile-sync-daemon.
Did you lose power or force a shutdown or anything like that?
Are there files in this directory? Check ls ~/.config/vivaldi-backup
Is this the only browser with this issue? Check those other browsers, Firedragon and Google Chrome and see if they return a similar error.
Try restarting the profile sync daemon:
systemctl --user restart psd.service
Then check the status again.
Another thing to test would be move that Vivaldi backup directory it is stuck syncing to see what happens:
mv ~/.config/vivaldi-backup ~/.config/vivaldi-backup.bak
Reopen the browser and check for a change to the error message.
Yes, there are files there.
Yes, other browsers don't have this problem.
Now I will restart daemon and also move the vivaldi-backup directory and write to you
There is no error message, the browser simply stops starting after restarting the system (turn it off). That's the problem. And until these processes are removed, the browser does not start, while all tabs and sessions are deleted if they are removed. At the same time, these processes can hang indefinitely.
shut down in the main menu
See if you have better luck if the profile sync daemon leaves Vivaldi alone altogether.
micro .config/psd/psd.conf
Scroll down the line that says BROWSERS= and delete Vivaldi out of the list.
Then restart the psd.service again, or better yet take a reboot if you can and test if the browser opens normally.
By the way, if moving the backup directory did not help at all you can either move it back:
mv ~/.config/vivaldi-backup.bak ~/.config/vivaldi-backup
or just delete it if it has already made a new one.
Yes, it helped, thank you
