I just installed the Garuda KDE "Dragon Gaming" distro and I set everything up and restarted to sync the nvidia drivers and the transparency effects and window animations are no longer existant. How can I get them back?
System Settings -> Display and Monitor -> Compositor -> Re-enable
If it still doesn't, change Rendering backend and then change back if you want.
Thank you very much kind sir.
What is Rendering backend ? I have the same problem and re-enable don't change something and I don't understand whats is rendering backend
Please read
