Hello.
sudo garuda-update gives me this error:
installing virtualbox (7.0.10-1) breaks dependency 'virtualbox=7.0.8' required by virtualbox-ext-oracle
Tried to do pacman -Rns virtualbox-ext-oracle, but breaks dependency virtualbox-meta, etc.
Kernel: 6.1.37-1-lts arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=b4ca416f-530b-4ae4-bf0b-835736bc4fe7 rw rootflags=subvol=@
loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.6 tk: Qt v: 5.15.10 info: latte-dock
wm: kwin_x11 vt: 2 dm: 1: LightDM v: 1.32.0 note: stopped 2: SDDM
Type: Desktop Mobo: BIOSTAR model: B550MH serial: <superuser required>
UEFI: American Megatrends LLC. v: 5.17 date: 05/05/2022
Info: model: AMD Ryzen 5 5600G with Radeon Graphics bits: 64 type: MT MCP
microcode: 0xA50000D
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 3642 high: 3900 min/max: 1400/4464 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3900 2: 3900
3: 3526 4: 3900 5: 2994 6: 3900 7: 2994 8: 3900 9: 3900 10: 3900 11: 2994
12: 3900 bogomips: 93459
vendor: Biostar Microtech Intl Corp driver: amdgpu v: kernel arch: GCN-5
lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: DP-1,HDMI-A-1
empty: HDMI-A-2 bus-ID: 05:00.0 chip-ID: 1002:1638 class-ID: 0300
temp: 33.0 C
s-diag: 1055mm (41.54")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,right
model: Samsung S24D300 serial: <filter> built: 2014 res: 1920x1080 hz: 60
dpi: 92 gamma: 1.2 size: 531x299mm (20.91x11.77") diag: 609mm (24")
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: left model: Samsung S24D300
serial: <filter> built: 2014 res: 1920x1080 hz: 60 dpi: 94 gamma: 1.2
size: 521x293mm (20.51x11.54") diag: 598mm (23.5") ratio: 16:9 modes:
API: OpenGL v: 4.6 Mesa 23.1.3 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.49 6.1.37-1-lts) direct-render: Yes
speed: 16 GT/s bus-ID: 05:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: Biostar Microtech Intl Corp
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3
API: ALSA v: k6.1.37-1-lts status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.72 status: active with: 1: pipewire-pulse
vendor: Biostar Microtech Intl Corp driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 03:00.0 chip-ID: 10ec:8168
IF-ID-1: br-0230801b624c state: down mac: <filter>
IF-ID-2: br-96c3f4053d28 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-3: br-a539ad42d9b3 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-4: br-ab3483bdfeed state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-5: br-e28deef329de state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-6: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-7: vboxnet0 state: down mac: <filter>
IF-ID-8: veth09a32ca state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-9: veth0efc0c0 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-10: veth2c46ed9 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-11: veth373f38c state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-12: veth52673aa state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-13: veth7e1c0d6 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-14: veth88558ad state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-15: veth8ec2345 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-16: vetha3e5370 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-17: vethd9b7419 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-18: vethda4cff0 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-19: vethed26946 state: up speed: 10000 Mbps duplex: full
mac: <filter>
Local Storage: total: 953.87 GiB used: 379.88 GiB (39.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW010T9
lanes: 4 tech: SSD serial: <filter> fw-rev: 001C temp: 37.9 C scheme: GPT
ID-1: / raw-size: 195.31 GiB size: 195.31 GiB (100.00%)
used: 46.82 GiB (24.0%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
used: 584 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p3 maj-min: 259:3
ID-3: /home raw-size: 758.06 GiB size: 758.06 GiB (100.00%)
used: 333.06 GiB (43.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 195.31 GiB size: 195.31 GiB (100.00%)
ID-5: /var/tmp raw-size: 195.31 GiB size: 195.31 GiB (100.00%)
ID-1: swap-1 type: zram size: 30.74 GiB used: 4.23 GiB (13.7%)
System Temperatures: cpu: 42.0 C mobo: N/A gpu: amdgpu temp: 33.0 C
Processes: 467 Uptime: 2d 20h 52m wakeups: 23 Memory: available: 30.74 GiB
used: 7.41 GiB (24.1%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: 2180
pm: pacman pkgs: 2158 libs: 450 tools: octopi,paru,yay pm: rpm pkgs: 0
pm: flatpak pkgs: 22 Shell: fish v: 3.6.1 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.27
System install date: 2022-04-12
Last full system update: 2023-07-05
Failed units: bluetooth-autoconnect.service shadow.service
What to do?
