I am a garuda user for over an year now, and its pretty stable on my desktop. I recently purchased a samsung monitor and it connects well!
However when I try to switch virtual desktop on one monitor, the virtual desktops on other monitor are also getting switched, this should ideally not happen.
How can I fix this?
Please provide your garuda-inxi, as required by the template.
Without it this description is missing a context.
Sure, the output of garuda-inxi is following
Kernel: 6.6.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=10bb012f-80b1-4834-b834-50d7819480ae rw rootflags=subvol=@
quiet resume=UUID=9bde3fb4-9817-48ef-bbb8-9f747d2c4b74 loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin_wayland vt: 1
Type: Laptop System: Acer product: Aspire A715-41G v: V1.02
Mobo: PK model: Azalea_PKS v: V1.02 serial: <superuser required>
UEFI: INSYDE v: 1.02 date: 06/19/2020
ID-1: BAT1 charge: 25.9 Wh (86.6%) condition: 29.9/53.0 Wh (56.4%)
volts: 14.2 min: 15.4 model: PANASONIC AP19B5L type: Li-ion serial: <filter>
Device-1: hid-f4:73:35:83:92:d1-battery model: Keyboard K480 serial: N/A
charge: N/A status: discharging
Info: model: AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx bits: 64
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1571 high: 2395 min/max: 1400/2100 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2395 2: 2100
3: 1203 4: 1400 5: 1369 6: 1400 7: 1400 8: 1304 bogomips: 33535
Device-1: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q]
vendor: Acer Incorporated ALI driver: nouveau v: kernel non-free: 545.xx+
status: current (as of 2023-10; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1f99 class-ID: 0302
temp: 25.0 C
Device-2: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
vendor: Acer Incorporated ALI driver: amdgpu v: kernel arch: GCN-5
lanes: 16 ports: active: HDMI-A-1,eDP-1 empty: none bus-ID: 05:00.0
chip-ID: 1002:15d8 class-ID: 0300 temp: 36.0 C
Device-3: Quanta HD User Facing driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1:4 chip-ID: 0408:a061
class-ID: 0e02
compositor: kwin_wayland driver: X: loaded: amdgpu,modesetting,nouveau
alternate: fbdev,nv,vesa dri: radeonsi,nouveau gpu: nouveau,amdgpu
d-rect: 3456x1944 display-ID: 0
Monitor-1: HDMI-A-1 pos: top-right res: 1920x1080 size: N/A modes: N/A
Monitor-2: eDP-1 pos: bottom-l res: 1536x864 size: N/A modes: N/A
API: EGL v: 1.5 hw: drv: nvidia nouveau drv: amd radeonsi platforms:
device: 0 drv: radeonsi device: 1 drv: nouveau device: 2 drv: swrast
surfaceless: drv: nouveau wayland: drv: radeonsi x11: drv: radeonsi
inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.3 vendor: amd mesa v: 23.2.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Vega 8 Graphics (raven
LLVM 16.0.6 DRM 3.54 6.6.2-zen1-1-zen) device-ID: 1002:15d8
API: Vulkan v: 1.3.269 layers: 3 device: 0 type: integrated-gpu name: AMD
Radeon Vega 8 Graphics (RADV RAVEN) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:15d8 surfaces: xcb,xlib,wayland device: 1 type: cpu
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 05:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor
vendor: Acer Incorporated ALI driver: snd_pci_acp3x v: kernel
alternate: snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt,
snd_sof_amd_vangogh pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 05:00.5
Device-3: AMD Family 17h/19h HD Audio vendor: Acer Incorporated ALI
API: ALSA v: k6.6.2-zen1-1-zen status: kernel-api tools: N/A
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8168
speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-2.1:3 chip-ID: 8087:0029
lmp-v: 11 status: discoverable: no pairing: no class-ID: 7c010c
Local Storage: total: 476.94 GiB used: 19.31 GiB (4.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
model: HFM512GDJTNG-8310A size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 tech: SSD serial: <filter>
fw-rev: 80002C00 temp: 31.9 C scheme: GPT
used: 19.31 GiB (4.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2
ID-2: swap-2 type: zram size: 5.72 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 37.8 C mobo: N/A
GPU: device: amdgpu temp: 37.0 C device: nouveau temp: 25.0 C
Processes: 309 Uptime: 22m wakeups: 0 Memory: total: 6 GiB
available: 5.72 GiB used: 3.38 GiB (59.0%) Init: systemd v: 254
pm: pacman pkgs: 1216 libs: 356 tools: octopi,paru Shell: fish v: 3.6.1
Garuda (2.6.19-2):
System install date: 2023-11-25
Last full system update: 2023-11-25
it looks like the ith virtual desktop on each monitor are tied
With KDE I don’t think that the feature is possible at all. I rarely use an external monitor, but a quick internet search confirms this.
Maybe something will change with KDE6? Or maybe something has already been implemented using a Wayland session?
Take a look at this 18 year old KDE bug still under discussion…
https://bugs.kde.org/show_bug.cgi?id=107302
