Virsh network breaks when using gpu passthrough for a vm
Hello.
I am dual booting with windows, I saw some other posts on here mention how windows related boot-options can mess stuff up. I have both secure boot and fast boot disabled.
I am trying to set up a virtual machine with GPU passthrough, and everytime I setup the GPU passthrough it causes the virsh default network, which is what I use to get internet in the vm, to no longer have internet access. This connection works perfectly using QXL/Display spice without passthrough, so I am assuming that something in my startup script is causing wifi to break. I've tried the same setup on both Manjaro and EndeavourOS, and it works perfectly fine on both of those. Below is my startup script for running the VM with gpu passthrough
set -x
source "/etc/libvirt/hooks/kvm.conf"
systemctl stop sddm-plymouth
systemctl stop sddm
echo 0 > /sys/class/vtconsole/vtcon0/bind
echo "efi-framebuffer.0" > /sys/bus/platform/drivers/efi-framebuffer/unbind
sleep 10
modprobe -r nvidia_drm
modprobe -r nvidia_modeset
modprobe -r drm_kms_helper
modprobe -r nvidia
modprobe -r i2c_nvidia_gpu
modprobe -r drm
modprobe -r nvidia_uvm
virsh nodedev-detach $VIRSH_GPU_VIDEO
virsh nodedev-detach $VIRSH_GPU_AUDIO
modprobe vfio
modprobe vfio_pci
modprobe vfio_iommu_type1
I have tried disabling wifi powersave and mac address randomization in the garuda network manager, but that has not helped. My assumption is that there is some sort of power saving feature somewhere that disables wifi when sddm is stopped, however if this is the cause of the issue I have not been able to find how to disable it. So far I've got a hacky fix of just passing through my entire network device to the VM, however that leaves garuda with no internet. I would really like to be able to resolve this issue, and have internet on both the VM and host without needing to switch to a different distro.
inxi
System:    Kernel: 5.15.4-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=8354308e-d5e1-41b7-9f9b-bb5bc62114b7
systemd.unified_cgroup_hierarchy=1 loglevel=3 intel_iommu=on iommu=pt mitigations=off
Desktop: KDE Plasma 5.23.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine:   Type: Desktop System: ASUS product: N/A v: N/A serial: <filter>
Mobo: ASUSTeK model: PRIME Z590-P v: Rev 1.xx serial: <filter> UEFI: American Megatrends
v: 1017 date: 07/12/2021
CPU:       Info: 8-Core model: Intel Core i7-10700K bits: 64 type: MT MCP arch: Comet Lake family: 6
model-id: A5 (165) stepping: 5 microcode: EC cache: L2: 16 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 121596
Speed: 5100 MHz min/max: 800/5100 MHz Core speeds (MHz): 1: 5100 2: 5130 3: 5100 4: 5116
5: 5105 6: 5100 7: 5100 8: 5094 9: 5098 10: 5100 11: 5087 12: 5100 13: 5096 14: 5102 15: 5109
16: 5099
status: Vulnerable: __user pointer sanitization and usercopy barriers only; no swapgs barriers
Graphics:  Device-1: NVIDIA GA102 [GeForce RTX 3080] driver: nvidia v: 495.44
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:2206 class-ID: 0300
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver: loaded: nvidia
unloaded: modesetting alternate: fbdev,nouveau,nv,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 4480x1440 s-dpi: 108 s-size: 1054x342mm (41.5x13.5") s-diag: 1108mm (43.6")
Monitor-1: DP-0 res: 1920x1080 hz: 60 dpi: 90 size: 544x303mm (21.4x11.9") diag: 623mm (24.5")
Monitor-2: DP-2 res: 2560x1440 hz: 60 dpi: 109 size: 597x336mm (23.5x13.2") diag: 685mm (27")
OpenGL: renderer: NVIDIA GeForce RTX 3080/PCIe/SSE2 v: 4.6.0 NVIDIA 495.44 direct render: Yes
Audio:     Device-1: Intel vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
chip-ID: 8086:f0c8 class-ID: 0403
Device-2: NVIDIA GA102 High Definition Audio driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 10de:1aef class-ID: 0403
Device-3: SteelSeries ApS SteelSeries Arctis 7 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-11:10 chip-ID: 1038:12ad class-ID: 0300
Sound Server-1: ALSA v: k5.15.4-zen1-1-zen running: yes
Network:   Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel bus-ID: 04:00.0 chip-ID: 8086:095a
Device-2: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel port: 4000
bus-ID: 05:00.0 chip-ID: 10ec:8125 class-ID: 0200
Bluetooth: Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8 bus-ID: 1-2.2:4
chip-ID: 8087:0a2a class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: up address: N/A
Drives:    Local Storage: total: 2.74 TiB used: 23.4 GiB (0.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNVS1000G size: 931.51 GiB
rev: EDFK7N02 temp: 37.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102 size: 1.82 TiB
serial: <filter> rev: 0001 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Verbatim model: STORE N GO size: 7.26 GiB
block-size: physical: 512 B logical: 512 B type: N/A serial: <filter> rev: 5.00 scheme: MBR
Partition: ID-1: / raw-size: 207 GiB size: 207 GiB (100.00%) used: 23.37 GiB (11.3%) fs: btrfs
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 26.5 MiB (27.6%) fs: vfat
ID-3: /home raw-size: 207 GiB size: 207 GiB (100.00%) used: 23.37 GiB (11.3%) fs: btrfs
ID-4: /var/log raw-size: 207 GiB size: 207 GiB (100.00%) used: 23.37 GiB (11.3%) fs: btrfs
ID-5: /var/tmp raw-size: 207 GiB size: 207 GiB (100.00%) used: 23.37 GiB (11.3%) fs: btrfs
ID-1: swap-1 type: zram size: 31.17 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors:   System Temperatures: cpu: 27.8 C mobo: N/A gpu: nvidia temp: 52 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 30%
Info:      Processes: 366 Uptime: 0m wakeups: 0 Memory: 31.17 GiB used: 2.84 GiB (9.1%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1205 lib: 290 Shell: fish
v: 3.3.1 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.08
If it works in EnOS then it will work in Garuda. What’s different between the two setups?
