Hello
first:
Kernel: 5.17.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=04f2b34d-95b5-4428-aa90-76b0aa6844b9 rw rootflags=subvol=@
rd.udev.log_priority=3 resume=UUID=732f1b04-1f2b-43a2-8b9c-9ff4724690ec
Type: Convertible System: Acer product: TravelMate Spin B311RN-31 v: V1.18
serial: <superuser required> Chassis: type: 31 serial: <superuser required>
Mobo: GLK model: Maracas_GL v: V1.18 serial: <superuser required>
UEFI: Insyde v: 1.18 date: 08/26/2021
ID-1: BAT0 charge: 40.3 Wh (79.5%) condition: 50.7/48.0 Wh (105.6%)
volts: 12.0 min: 11.2 model: 30G020 AP18C8K type: Li-ion serial: <filter>
status: discharging cycles: 17
Device-1: hid-0018:04F3:2B9C.0001-battery model: ELAN9004:00 04F3:2B9C
serial: N/A charge: N/A status: N/A
Info: model: Intel Pentium Silver N5030 bits: 64 type: MCP
arch: Goldmont Plus family: 6 model-id: 0x7A (122) stepping: 8
microcode: 0x1C
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 224 KiB
desc: d-4x24 KiB; i-4x32 KiB L2: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1570 high: 2064 min/max: 800/3100 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1571 2: 2064 3: 1457
4: 1190 bogomips: 8755
Device-1: Intel GeminiLake [UHD Graphics 605] vendor: Acer Incorporated ALI
driver: i915 v: kernel ports: active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:3184 class-ID: 0300
Device-2: Chicony 5MP World Facing type: USB driver: uvcvideo
bus-ID: 1-2:2 chip-ID: 04f2:b6fe class-ID: 0e02 serial: <filter>
Device-3: Quanta HD User Facing type: USB driver: uvcvideo bus-ID: 1-7:3
chip-ID: 0408:a061 class-ID: 0e02
Monitor-1: eDP-1 model: AU Optronics 0xea8c built: 2019 res: 1920x1080
hz: 60 dpi: 190 gamma: 1.2 size: 256x144mm (10.08x5.67")
diag: 294mm (11.6") ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics 605 (GLK 3) v: 4.6 Mesa 22.0.1
direct render: Yes
Device-1: Intel Celeron/Pentium Silver Processor High Definition Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci_intel_apl bus-ID: 00:0e.0
chip-ID: 8086:3198 class-ID: 0403
Sound Server-1: ALSA v: k5.17.3-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.50 running: yes
Device-1: Intel Gemini Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:0c.0 chip-ID: 8086:31dc class-ID: 0280
IF: wlp0s12f0 state: up mac: <filter>
speed: 2.5 GT/s lanes: 1 port: 1000 bus-ID: 02:00.0 chip-ID: 10ec:8168
driver: btusb v: 0.8 bus-ID: 1-9:5 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 357.99 GiB used: 255.95 GiB (71.5%)
ID-1: /dev/mmcblk1 maj-min: 179:0 type: USB model: GE4S5 size: 238.75 GiB
block-size: physical: 512 B logical: 512 B type: SSD serial: <filter>
scheme: MBR
ID-2: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston
model: RBUSNS8154P3128GJ1 size: 119.24 GiB block-size: physical: 512 B
rev: E8FK12.3 temp: 24.9 C scheme: GPT
ID-1: / raw-size: 110.94 GiB size: 110.94 GiB (100.00%)
used: 36.96 GiB (33.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 110.94 GiB size: 110.94 GiB (100.00%)
ID-4: /var/log raw-size: 110.94 GiB size: 110.94 GiB (100.00%)
ID-5: /var/tmp raw-size: 110.94 GiB size: 110.94 GiB (100.00%)
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
ID-2: swap-2 type: zram size: 3.64 GiB used: 974.2 MiB (26.2%)
System Temperatures: cpu: 41.0 C mobo: N/A
Processes: 271 Uptime: 2h 11m wakeups: 12 Memory: 3.64 GiB
used: 2.09 GiB (57.5%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1634 lib: 400 Shell: fish
v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.15
Garuda (2.6.1-3):
System install date: 2022-02-13
Last full system update: 2022-04-19 ↻
Hello to all!
I have Garuda KDE installed on 2 low spec Intel devices (1 Laptop and 1 Mini PC) just for consuming media or playing with Geforce Now.
On booth PCs i have problems playing video. It's more like a 1-3 sec slideshow than a smooth video playback. But related on which player i am using. Kodi, VLC or MPV just run fine. But with Dragon Player i get a frame every 1 or 2 seconds while audio is playing fine from the same video. Also when i'm using minitube. Then i tried freetube und there all is fine again.
When i try to play with geforce now, it's even getting worse, i have video lags around 5-7 seconds. But you can hear in the audio, that my input from my mouse or controller is right there. For example, if i play a race game, i can hear the motor if i hit the throttle, but the car is moving in around 5-7 seconds visually. Same behaviour here, audio is fine, video shows a frame every few seconds.
I'm using Linux for a year now , for me it seems that Geforce Now and Dragon Player is not using hardware acceleration or someting similar, and when it is fixed, booth will work. But i may be wrong. I know it can work on these PCs, because before Garuda i had Xubuntu installed, and no problems using geforce now.
It doesn't matter if i use Geforce Now in a supported browser like Chrome or MS Edge, or i use the electron app provided by the AUR.
I have no ideas where to look to fix this. Anyone any ideas?
