Hi,
I am on a Lenovo Thinkpad P14, AMD Gen 2.
I have Garuda installed in X11 env. Everything is fine except my camera will not work.
I tried websites like Jitsi, Zoom and local apps OBS & Cheese and none can display video.
I am not sure what I can do to get it working.
I have installed the following:
xf86-video-amdgpu
libva-mesa-driver
Also output of garuda-inix...
Kernel: 5.19.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=5975aa68-76c5-4cd2-9dd6-c52d3b36cfcc rw rootflags=subvol=@
quiet
cryptdevice=UUID=1821d2be-6c0b-48d9-b513-f97100cef96b:luks-1821d2be-6c0b-48d9-b513-f97100cef96b
root=/dev/mapper/luks-1821d2be-6c0b-48d9-b513-f97100cef96b quiet splash
resume=/dev/mapper/luks-582c2573-a523-4fd9-b720-0558d5315181 loglevel=3
Desktop: Qtile v: 0.21.0 wm: LG3D vt: 1 dm: SDDM Distro: Garuda Linux
Type: Laptop System: LENOVO product: 21A0CTO1WW v: ThinkPad P14s Gen 2a
Mobo: LENOVO model: 21A0CTO1WW serial: <superuser required> UEFI: LENOVO
v: R1MET43W (1.13 ) date: 11/05/2021
ID-1: BAT0 charge: 50.1 Wh (97.3%) condition: 51.5/50.5 Wh (101.9%)
volts: 12.9 min: 11.6 model: LGC 5B10W51826 type: Li-poly serial: <filter>
status: not charging cycles: 121
Info: model: AMD Ryzen 7 PRO 5850U with Radeon Graphics bits: 64
type: MT MCP arch: Zen 3 gen: 4 built: 2021-22 process: TSMC n7 (7nm)
family: 0x19 (25) model-id: 0x50 (80) stepping: 0 microcode: 0xA50000C
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1868 high: 2768 min/max: 1600/4505 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1900 2: 2768
3: 1600 4: 1486 5: 1858 6: 1600 7: 1858 8: 1900 9: 1915 10: 1900 11: 1600
12: 1600 13: 1800 14: 1915 15: 2599 16: 1600 bogomips: 60682
Device-1: AMD Cezanne vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5.1
code: Vega-2 process: TSMC n7 (7nm) built: 2018-21 pcie: gen: 3
active: HDMI-A-1,eDP-1 empty: DP-1,DP-2 bus-ID: 07:00.0
chip-ID: 1002:1638 class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 compositor: Picom v: git-c4107
driver: X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa
Screen-1: 0 s-res: 5760x1080 s-dpi: 96 s-size: 1524x285mm (60.00x11.22")
s-diag: 1550mm (61.04")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 pos: right model: ASUS XG49V
serial: <filter> built: 2021 res: 3840x1080 hz: 120 dpi: 81 gamma: 1.2
size: 1200x340mm (47.24x13.39") diag: 1242mm (48.9") modes:
max: 3840x1080 min: 720x400
Monitor-2: eDP-1 mapped: eDP pos: primary,left model: ChiMei InnoLux
0x1409 built: 2019 res: 1920x1080 hz: 60 dpi: 158 gamma: 1.2
size: 309x173mm (12.17x6.81") diag: 354mm (13.9") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
link-max: gen: 4 speed: 16 GT/s bus-ID: 07:00.1 chip-ID: 1002:1637
alternate: snd_pci_acp3x,snd_pci_acp5x,snd_pci_acp6x,snd_acp_pci,snd_sof_amd_renoir
bus-ID: 07:00.5 chip-ID: 1022:15e2 class-ID: 0480
link-max: gen: 4 speed: 16 GT/s bus-ID: 07:00.6 chip-ID: 1022:15e3
Sound Server-1: ALSA v: k5.19.4-zen1-1-zen running: yes
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp2s0f0 state: down mac: <filter>
vendor: Lenovo driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s
Device-3: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
lanes: 1 port: 2000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-1: Foxconn / Hon Hai Wireless_Device type: USB driver: btusb v: 0.8
bus-ID: 3-4:2 chip-ID: 0489:e0cd class-ID: e001 serial: <filter>
Local Storage: total: 1.86 TiB used: 19.37 GiB (1.0%)
model: MZVL22T0HBLB-00BL7 size: 1.86 TiB block-size: physical: 512 B
rev: 6L2QGXB7 temp: 52.9 C scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 19.37 GiB (1.0%)
mapped: luks-1821d2be-6c0b-48d9-b513-f97100cef96b
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 752 KiB
ID-3: /home raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 19.37 GiB
(1.0%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
ID-4: /var/log raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 19.37
GiB (1.0%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
ID-5: /var/tmp raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 19.37
ID-1: swap-1 type: zram size: 42.94 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 47.23 GiB used: 0 KiB (0.0%)
mapped: luks-582c2573-a523-4fd9-b720-0558d5315181
System Temperatures: cpu: 55.0 C mobo: N/A gpu: amdgpu temp: 52.0 C
Fan Speeds (RPM): fan-1: 3600 fan-2: 3600
Processes: 350 Uptime: 3h 55m wakeups: 21046 Memory: 42.94 GiB used: 4.24
GiB (9.9%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pacman: 1324 lib: 358 Shell: Bash
v: 5.1.16 running-in: wezterm-gui inxi: 3.3.20
Garuda (2.6.6-1):
System install date: 2022-08-28
Last full system update: 2022-08-28 ↻
