Hello!
My laptop’s display is veryt bad and color looks washed out which is why I have been using vibrantLinux to increase color saturation in my laptop display to at least make it a little colorful. I have been using it for months and it worked with all apps. However, recently I noticed that vibrantLinux wasn’t working and when I tried to open it, it gave me this display not supported response.
I had this issue for few weeks now but to my surprise, just as I was about to post this topic here in this forum, I found out that vibrantLinux was working again. I don’t know what was causing the issue. Could it be a bug in new version with vibrantLinux? Anyway, just wanted to let you know that I had my problem solved on its own. I didn’t tinker anything at all.
Anyway, here is the output of garuda-inxi:
Kernel: 6.6.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=25a52fbb-0a18-444f-9298-e208ddd7e44e rw rootflags=subvol=@
snd_hda_intel.dmic_detect=0 ibt=off
Type: Laptop System: LENOVO product: 81H7 v: Lenovo ideapad 130-15IKB
serial: <superuser required> Chassis: type: 10 v: Lenovo ideapad 130-15IKB
Mobo: LENOVO model: LNVNB161216 v: No DPK serial: <superuser required>
UEFI: LENOVO v: 8QCN28WW(V1.16) date: 08/19/2021
ID-1: BAT1 charge: 18.6 Wh (100.0%) condition: 18.6/30.0 Wh (62.1%)
power: 0.4 W volts: 8.4 min: 7.6 model: 0x4C 0x47 0x43 0x00 0x31
PABAS0241231 type: Li-ion serial: <filter> status: full cycles: 1158
Info: model: Intel Core i5-8250U bits: 64 type: MT MCP arch: Coffee Lake
model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xF4
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 812 high: 900 min/max: 400/3400 scaling:
5: 900 6: 800 7: 801 8: 800 bogomips: 28800
Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
active: HDMI-A-1,eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:5917
Device-2: Syntek EasyCamera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:4 chip-ID: 174f:241a
class-ID: 0e02
Screen-1: 0 s-res: 3286x1080 s-dpi: 96 s-size: 869x285mm (34.21x11.22")
s-diag: 915mm (36.01")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: primary,top-left
model: BenQ GW2283 serial: <filter> built: 2023 res: 1920x1080 hz: 60
dpi: 102 gamma: 1.2 size: 476x268mm (18.74x10.55") diag: 546mm (21.5")
Monitor-2: eDP-1 pos: bottom-r model: ChiMei InnoLux 0x15db built: 2015
res: 1366x768 hz: 60 dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6")
diag: 394mm (15.5") ratio: 16:9 modes: 1366x768
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.2.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 620 (KBL
GT2) device-ID: 8086:5917 memory: 7.45 GiB unified: yes
API: Vulkan v: 1.3.269 layers: 3 device: 0 type: integrated-gpu name: Intel
UHD Graphics 620 (KBL GT2) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:5917 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
API: ALSA v: k6.6.2-zen1-1-zen status: kernel-api
Server-2: PipeWire v: 0.3.85 status: active with: 1: wireplumber
status: active 2: pw-jack type: plugin tools: pw-cat,pw-cli,wpctl
Server-3: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Lenovo
bus-ID: 01:00.0 chip-ID: 10ec:8136 class-ID: 0200
vendor: Lenovo driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:0042 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:5 chip-ID: 0cf3:e500
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 5.0
lmp-v: 9 status: discoverable: yes pairing: yes class-ID: 7c010c
Local Storage: total: 223.57 GiB used: 102.21 GiB (45.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Hikvision model: HS-SSD-C100 240G
tech: SSD serial: <filter> fw-rev: Hf10 scheme: GPT
ID-1: / raw-size: 143.36 GiB size: 143.36 GiB (100.00%)
used: 102.21 GiB (71.3%) fs: btrfs dev: /dev/sda4 maj-min: 8:4
ID-2: /home raw-size: 143.36 GiB size: 143.36 GiB (100.00%)
ID-3: /var/log raw-size: 143.36 GiB size: 143.36 GiB (100.00%)
ID-4: /var/tmp raw-size: 143.36 GiB size: 143.36 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.62 GiB used: 1.08 GiB (14.1%)
System Temperatures: cpu: 48.0 C pch: 42.5 C mobo: N/A
Processes: 294 Uptime: 25m wakeups: 0 Memory: total: 8 GiB
available: 7.63 GiB used: 4.94 GiB (64.8%) Init: systemd v: 254
Packages: 1559 pm: pacman pkgs: 1546 libs: 437 tools: octopi,paru,trizen,yay
pm: flatpak pkgs: 13 Shell: fish v: 3.6.1 default: Bash v: 5.2.21
Garuda (2.6.19-2):
System install date: 2023-11-14
Last full system update: 2023-11-25
