So,
I discovered garuda a few days ago when I accidentally been through a video from a certain DistroTube and after some googling found out the blackarch dr46onized version of Garuda which, as a cybersec professional , instantly caught my attention.
after download (garuda-dr460nized-blackarch-linux-zen-210720) I set a VM which sadly got stuck at :
a start job is running automatic driver installation via mhwd
and runs forever (stopped after few hours)
as I know some ARCH based distributions may be sensitive to virtualisation, I flashed a stick and tried a live boot, got the exact same situation stuck at the same point.
thought there's a conflict somewhere, so I downloaded the nude version of dr46onized garuda (garuda-dr460nized-linux-zen-210720) and went over the same situations precedently exposed.
googled a bit and found two major topics, one concluding that was because of bad hardware (not my case) and the other was a guy that have been into this problem after an update but his old version was still working (in a VM), after some waybacking I've been able to recover an old magnet link to an older version (garuda-dr460nized-gaming-linux-tkg-bmq-210107) that worked perfectly, both in VM and on a liveboot, sadly wasn't been able to update this version to the recent one and not even installing the blackarch repos (which is not my inquiry here as I stopped my digging in fixing that to post this here)
My question :
May any staff member be pleased to provide me a link to the blackarch version related to 210107 this update so I can pursue my troubleshooting?
Hopping this could help fixing the virtualization of the distro, I completely understand the fact you disapprove this way to use your distribution but as you're providing a pentesting version of it, the virtualization is ineluctable
Hardware :
CPU : Ryzen 7 5800x
GPU : R7 370 Strix 4Gb
RAM : 32Gb
VM :
RAM : 8Gb
CPU : 8 Cores
Storage : 50Gb
Accelerated graphics
