Hello.
I have really low fps in cs:go. In windows it is about 150 fps and here, in garuda linux, this is 30 fps. Is this normal fps for linux? Ask me all you need to help me solve this issue and I will post it here. Of course I tried googling, but after about 3 hours of trying it didn't give me anything meaningful. Thank you in adnvance
Kernel: 5.16.8-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=768379d5-879a-43fa-9c68-08812119bb91 rw rootflags=subvol=@
pci=nomsi
Desktop: KDE Plasma 5.24.0 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
Type: Laptop System: Acer product: Nitro AN515-54 v: V1.31
Mobo: CFL model: Octavia_CFS v: V1.31 serial: <superuser required>
UEFI: Insyde v: 1.31 date: 06/29/2020
ID-1: BAT1 charge: 39.5 Wh (99.5%) condition: 39.7/58.8 Wh (67.5%)
volts: 16.2 min: 15.4 model: SMP AP18E7M type: Li-ion serial: <filter>
status: N/A
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEC
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 4374 high: 4466 min/max: 800/4500 scaling:
driver: intel_pstate governor: performance cores: 1: 4321 2: 4466 3: 4414
4: 4377 5: 4402 6: 4401 7: 4440 8: 4401 9: 4299 10: 4246 11: 4426
12: 4305 bogomips: 62399
Type: l1tf
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630]
vendor: Acer Incorporated ALI driver: i915 v: kernel bus-ID: 0000:00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile]
vendor: Acer Incorporated ALI driver: nouveau v: kernel
bus-ID: 0000:01:00.0 chip-ID: 10de:2191 class-ID: 0300
Device-3: Quanta HD Webcam type: USB driver: uvcvideo bus-ID: 1-5:3
chip-ID: 0408:a060 class-ID: 0e02 serial: <filter>
loaded: intel,modesetting,nouveau alternate: fbdev,nv,vesa display-ID: :0
s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143
size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
v: 4.6 Mesa 21.3.5 direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Acer Incorporated ALI
alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 0000:00:1f.3
Device-2: NVIDIA TU116 High Definition Audio driver: snd_hda_intel
v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:1aeb class-ID: 0403
Sound Server-1: ALSA v: k5.16.8-zen1-1-zen running: yes
bus-ID: 0000:00:14.3 chip-ID: 8086:a370 class-ID: 0280
Device-2: Qualcomm Atheros Killer E2500 Gigabit Ethernet
vendor: Acer Incorporated ALI driver: alx v: kernel port: 3000
bus-ID: 0000:06:00.0 chip-ID: 1969:e0b1 class-ID: 0200
IF: enp6s0 state: up speed: 100 Mbps duplex: full mac: <filter>
driver: btusb v: 0.8 bus-ID: 1-14:4 chip-ID: 8087:0aaa class-ID: e001
driver: intel_nvme_remap v: N/A port: 5060 bus-ID: 0000:00:17.0
chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 1.14 TiB used: 38.04 GiB (3.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
model: HFM256GDJTNG-8310A size: 238.47 GiB block-size: physical: 512 B
logical: 512 B type: SSD serial: <filter> rev: 80002C00 temp: 30.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 1J scheme: GPT
ID-1: / raw-size: 244.14 GiB size: 244.14 GiB (100.00%)
used: 38.01 GiB (15.6%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
used: 25.5 MiB (26.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 244.14 GiB size: 244.14 GiB (100.00%)
ID-4: /var/log raw-size: 244.14 GiB size: 244.14 GiB (100.00%)
ID-5: /var/tmp raw-size: 244.14 GiB size: 244.14 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.6 GiB used: 56 MiB (0.7%) priority: 100
System Temperatures: cpu: 45.0 C pch: 43.0 C mobo: N/A
Processes: 310 Uptime: 51m wakeups: 1 Memory: 7.6 GiB
used: 3.02 GiB (39.7%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.1 Packages: pacman: 1491 lib: 368 Shell: fish
e[1;34mGaruda (2.5.4-2):e[0m
e[1;34m System install date:e[0m 2022-02-13
e[1;34m Last full system update:e[0m 2022-02-13
e[1;34m Is partially upgraded: e[0m No
e[1;34m Relevant software: e[0m NetworkManager
e[1;34m Windows dual boot: e[0m Probably (Run as root to verify)
e[1;34m Snapshots: e[0m Snapper
e[1;34m Failed units: e[0m
