V4l2loopback Missing DKMS modules
  Kernel: 6.16.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=748fc83f-8edc-436a-a837-2ebf04b7a602 rw rootflags=subvol=@
    rd.driver.pre=vfio-pci loglevel=3 iommu=1 amd_iommu=on ibt=off
  Desktop: KDE Plasma v: 6.4.4 tk: Qt v: N/A info: frameworks v: 6.17.0
  Type: Desktop Mobo: ASUSTeK model: PRIME X570-P v: Rev X.0x
    UEFI: American Megatrends v: 4021 date: 08/09/2021
  Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
    model-id: 0x21 (33) stepping: 0 microcode: 0xA20102E
  Speed (MHz): avg: 1754 min/max: 556/4854 boost: enabled scaling:
    driver: amd-pstate-epp governor: performance cores: 1: 1754 2: 1754 3: 1754
    4: 1754 5: 1754 6: 1754 7: 1754 8: 1754 9: 1754 10: 1754 11: 1754 12: 1754
    13: 1754 14: 1754 15: 1754 16: 1754 bogomips: 121606
  Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: ASUSTeK driver: nvidia
    v: 580.76.05 alternate: nouveau,nvidia_drm non-free: 550-570.xx+
    status: current (as of 2025-04; EOL~2026-12-xx) arch: Pascal code: GP10x
    process: TSMC 16nm built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
    link-max: gen: 3 speed: 8 GT/s lanes: 16 ports: active: none empty: DP-1,
    DVI-D-1, DVI-D-2, HDMI-A-1 bus-ID: 04:00.0 chip-ID: 10de:1c82
  Device-2: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] vendor: ASUSTeK
    driver: nvidia v: 580.76.05 alternate: nouveau,nvidia_drm
    gen: 4 speed: 16 GT/s lanes: 16 ports: active: none off: DP-4 empty: DP-2,
    DP-3, HDMI-A-2, HDMI-A-3 bus-ID: 09:00.0 chip-ID: 10de:2504 class-ID: 0300
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:2
  Monitor-1: DP-4 model: Samsung U32J59x serial: <filter> built: 2024 res:
    mode: 3840x2160 hz: 60 scale: 100% (1) dpi: 140 gamma: 1.2
    max: 3840x2160 min: 640x480
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 1
    drv: nvidia device: 4 drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia
    wayland: drv: nvidia x11: drv: nvidia inactive: device-2,device-3
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 580.76.05
  API: Vulkan v: 1.4.321 layers: 15 device: 0 type: discrete-gpu
    name: NVIDIA GeForce RTX 3060 driver: nvidia v: 580.76.05
    device-ID: 10de:2504 surfaces: N/A device: 1 type: discrete-gpu
    name: NVIDIA GeForce GTX 1050 Ti driver: nvidia v: 580.76.05
    device-ID: 10de:1c82 surfaces: N/A device: 2 type: cpu name: llvmpipe
    (LLVM 20.1.8 256 bits) driver: mesa llvmpipe v: 25.1.7-arch1.1 (LLVM
  Device-1: NVIDIA GP107GL High Definition Audio vendor: ASUSTeK
    link-max: lanes: 16 bus-ID: 04:00.1 chip-ID: 10de:0fb9 class-ID: 0403
  Device-2: NVIDIA GA106 High Definition Audio vendor: ASUSTeK
    bus-ID: 09:00.1 chip-ID: 10de:228e class-ID: 0403
  Device-3: Advanced Micro Devices [AMD] Starship/Matisse HD Audio
    lanes: 16 bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-5: Focusrite-Novation Scarlett 2i2 3rd Gen driver: snd-usb-audio
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1.4:5
    chip-ID: 1235:8210 class-ID: 0102 serial: <filter>
  API: ALSA v: k6.16.1-zen1-1-zen status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.7 status: active with: 1: pipewire-pulse
    speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 05:00.0 chip-ID: 10ec:8168
  IF-ID-1: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
  IF-ID-2: veth52ba403 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-3: vethdd87fc2 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  Local Storage: total: 11.83 TiB used: 7.1 TiB (60.0%)
    fw-rev: 2B2QEXM7 temp: 50.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000DM004-2CV104
  ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST8000VN004-3CP101
    size: 7.28 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: HDD rpm: 7200 serial: <filter> fw-rev: SC60 scheme: GPT
    used: 339.6 GiB (36.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-1: swap-1 type: zram size: 31.24 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 47.5 C mobo: 48.0 C
  Fan Speeds (rpm): fan-1: 0 fan-2: 1339 fan-3: 0 fan-4: 1081 fan-5: 3183
    fan-6: 0 fan-7: 0
  Memory: total: 32 GiB available: 31.24 GiB used: 5.48 GiB (17.6%)
  Processes: 436 Power: uptime: 32m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.41 GiB services: org_kde_powerdevil,
  Packages: pm: pacman pkgs: 2103 libs: 583 tools: pacseek,pamac,paru,yay
    pm: flatpak pkgs: 0 Compilers: clang: 20.1.8 gcc: 15.2.1 alt: 14 Shell: Bash
    v: 5.3.3 default: fish v: 4.0.2 running-in: konsole inxi: 3.3.38
Garuda (2.7.5-1):
  System install date:     2024-09-28
  Last full system update: 2025-08-17
20/21 checks run in 0.67 seconds ⌛
Powered by garuda-health 🦅
Did an update and got this error
[2025-08-17T01:17:22-0700] [ALPM-SCRIPTLET] ==> dkms install --no-depmod v4l2loopback/0.15.0 -k 6.16.1-zen1-1-zen
[2025-08-17T01:17:24-0700] [ALPM-SCRIPTLET]
[2025-08-17T01:17:24-0700] [ALPM-SCRIPTLET] Error! Bad return status for module build on kernel: 6.16.1-zen1-1-zen (x86_64)
[2025-08-17T01:17:24-0700] [ALPM-SCRIPTLET] Consult /var/lib/dkms/v4l2loopback/0.15.0/build/make.log for more information.
[2025-08-17T01:17:24-0700] [ALPM-SCRIPTLET] ==> WARNING: `dkms install --no-depmod v4l2loopback/0.15.0 -k 6.16.1-zen1-1-zen' exited 10
Used Rani to goto the kernels and saw the Some DKMS modules are missing, clicked to reinstall DKMS and got this
+ dkms install --no-depmod v4l2loopback/0.15.0 -k 6.16.1.zen1-1-zen
Error! Your kernel headers for kernel 6.16.1.zen1-1-zen cannot be found at /usr/lib/modules/6.16.1.zen1-1-zen/build or /usr/lib/modules/6.16.1.zen1-1-zen/source.
Please install the linux-headers-6.16.1.zen1-1-zen package or use the --kernelsourcedir option to tell DKMS where it's located.
The current task has finished.
dkms status
nvidia/580.76.05, 6.12.42-1-lts, x86_64: installed
nvidia/580.76.05, 6.15.9-zen1-1.1-zen, x86_64: installed (Original modules exist) (Built modules are missing in the kernel modules folder)
nvidia/580.76.05, 6.16.1-zen1-1-zen, x86_64: installed
openrazer-driver/3.10.3, 6.12.42-1-lts, x86_64: installed
openrazer-driver/3.10.3, 6.16.1-zen1-1-zen, x86_64: installed
v4l2loopback/0.15.0, 6.12.42-1-lts, x86_64: installed
Use pacman or pacseek for the missing things.
IIRC I had same problem like you and must delete something in paru cache folder.
Well I tried a few things and could not find a solutions, so I removed the zen kernel and just decided to use the LTS for right now. Will revisit his when I have more time to figure it out. LTS is probably better since I use the computer for work.
Reinstall kernel + headers ; delete all useless stuff inside /var/lib/dkms folder (older kernel etc) and /home/(user)/.cache/paru can also help.
Let me give that a shot tonight after I finish working for the day
