root=UUID=0641a2f2-5bcd-46e1-b7d6-10f669121a09 rw rootflags=subvol=@
resume=UUID=da78161c-168c-41f3-a1c6-3cf934c71b57 loglevel=3 ibt=off
Type: Desktop System: Gigabyte product: X470 AORUS ULTRA GAMING v: N/A
serial:
Mobo: Gigabyte model: X470 AORUS ULTRA GAMING-CF v: x.x
serial: UEFI: American Megatrends v: F51g
date: 07/02/2020
Info: model: AMD Ryzen 3 3200G with Radeon Vega Graphics bits: 64 type: MCP
arch: Zen/Zen+ note: check gen: 1 level: v3 note: check built: 2019
process: GF 12nm family: 0x17 (23) model-id: 0x18 (24) stepping: 1
microcode: 0x8108109
Topology: cpus: 1x cores: 4 smt: cache: L1: 384 KiB
desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1644 high: 2300 min/max: 1400/3600 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1254 2: 2300
3: 1771 4: 1254 bogomips: 28799
vendor: Gigabyte driver: amdgpu v: kernel arch: GCN-5 code: Vega
ports: active: HDMI-A-1 empty: none bus-ID: 0a:00.0 chip-ID: 1002:15d8
class-ID: 0300 temp: 37.0 C
s-diag: 414mm (16.31")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Samsung built: 2014
res: 1366x768 hz: 60 dpi: 57 gamma: 1.2 size: 609x347mm (23.98x13.66")
diag: 701mm (27.6") ratio: 16:9 modes: max: 1366x768 min: 720x400
API: OpenGL v: 4.6 Mesa 23.0.3 renderer: AMD Radeon Vega 8 Graphics
(raven LLVM 15.0.7 DRM 3.49 6.2.13-zen-1-zen) direct-render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0a:00.1
Device-2: AMD Family 17h/19h HD Audio vendor: Gigabyte
bus-ID: 0a:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.2.13-zen-1-zen status: kernel-api tools: N/A
Device-1: Realtek RTL8188EE Wireless Network Adapter driver: rtl8188ee
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 03:00.0
chip-ID: 10ec:8179 class-ID: 0280
IF: wlo1 state: down mac:
Device-2: Intel I211 Gigabit Network vendor: Gigabyte driver: igb
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 06:00.0
IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac:
Local Storage: total: 2.25 TiB used: 7.02 GiB (0.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Gigabyte
model: GP-GSM2NE3256GNTD size: 238.47 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial:
rev: EDFM00.7 temp: 28.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
type: HDD rpm: 7200 serial: rev: 0001 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD800JD-55JRA0
size: 74.53 GiB block-size: physical: 512 B logical: 512 B speed: 1.5 Gb/s
type: N/A serial: rev: 1C05 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Patriot model: Burst size: 111.79 GiB
serial: rev: 61.3 scheme: MBR
ID-5: /dev/sdf maj-min: 8:80 type: USB vendor: Generic
model: MassStorageClass size: 14.59 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: rev: 1209 scheme: MBR
ID-1: / raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
used: 7.02 GiB (3.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-4: /var/log raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-5: /var/tmp raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-1: swap-1 type: zram size: 5.73 GiB used: 350.8 MiB (6.0%)
System Temperatures: cpu: 37.0 C mobo: N/A gpu: amdgpu temp: 37.0 C
Processes: 257 Uptime: 20m wakeups: 0 Memory: 5.73 GiB
used: 2.27 GiB (39.6%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1161
libs: 325 tools: octopi,paru Shell: fish v: 3.6.1 default: Bash v: 5.1.16
System install date: 2023-05-05
Last full system update: 2023-05-05 ↻
I've reinstalled Garuda today and after installation with the help of setup assistance I've updated Linux and continued installing some applications and I got the following errors
I have already tried refreshing keys using sudo pacman-key --refresh-keys also tried to update mirrorlists but it failed
