UW Resolution
After a recent systemwide update this past week, my games are not recognizing my UW’s full resolution of 3440x1440 anymore but rather caps at 2867x1200. I took a look in my system desktop, it shows correct resolution, but my system specs shows differently.
Kernel: 6.12.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=0811b3c2-4fae-4301-8cc8-aee6104f5c03 rw rootflags=subvol=@
quiet resume=UUID=b1789870-3e88-4397-87ba-cf22537a4adc loglevel=3
amdgpu.ppfeaturemask=0xffffffff splash ibt=off
Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
Type: Desktop Mobo: ASUSTeK model: TUF GAMING X570-PLUS (WI-FI) v: Rev X.0x
UEFI: American Megatrends v: 5021 date: 09/29/2024
Device-1: ps-controller-battery-d0:bc:c1:fb:46:48 model: N/A serial: N/A
charge: N/A status: charging
Info: model: AMD Ryzen 9 5950X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
Topology: cpus: 1x dies: 1 clusters: 1 cores: 16 threads: 32 tpc: 2
smt: enabled cache: L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB
desc: 16x512 KiB L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3598 min/max: 550/5084 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 3598 2: 3598 3: 3598
4: 3598 5: 3598 6: 3598 7: 3598 8: 3598 9: 3598 10: 3598 11: 3598 12: 3598
13: 3598 14: 3598 15: 3598 16: 3598 17: 3598 18: 3598 19: 3598 20: 3598
21: 3598 22: 3598 23: 3598 24: 3598 25: 3598 26: 3598 27: 3598 28: 3598
29: 3598 30: 3598 31: 3598 32: 3598 bogomips: 217590
Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 [Radeon RX 7900 XT/7900
XTX/7900 GRE/7900M] vendor: XFX RX-79XMERCB9 driver: amdgpu v: kernel
arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm) built: 2022+ pcie:
gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-1 empty: DP-2, DP-3,
HDMI-A-1, Writeback-1 bus-ID: 0a:00.0 chip-ID: 1002:744c class-ID: 0300
Device-2: Logitech BRIO Ultra HD Webcam
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo type: USB rev: 3.1
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-2:3 chip-ID: 046d:085e
unloaded: fbdev,modesetting,radeon,vesa dri: radeonsi gpu: amdgpu
display-ID: 0
Monitor-1: DP-1 res: 2867x1200 size: N/A modes: N/A
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.3.1-arch1.2
navi31 LLVM 18.1.8 DRM 3.59 6.12.3-zen1-1-zen) device-ID: 1002:744c
memory: 23.44 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.303 layers: 14 device: 0 type: discrete-gpu name: AMD
Radeon RX 7900 XTX (RADV NAVI31) driver: N/A device-ID: 1002:744c
bus-ID: 0a:00.1 chip-ID: 1002:ab30 class-ID: 0403
lanes: 16 bus-ID: 0c:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Logitech BRIO Ultra HD Webcam
Device-4: Sony DualSense wireless controller (PS5)
driver: playstation,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 5-2:3 chip-ID: 054c:0ce6 class-ID: 0300
API: ALSA v: k6.12.3-zen1-1-zen status: kernel-api with: aoss
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 05:00.0
lanes: 1 port: f000 bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-3: Sony DualSense wireless controller (PS5)
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-5:3 chip-ID: 8087:0032
Local Storage: total: 2.75 TiB used: 440.91 GiB (15.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO with
Heatsink 2TB size: 1.82 TiB block-size: physical: 512 B logical: 512 B
speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7
temp: 57.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Western Digital model: PC SN530
SDBPNPZ-1T00-1002 size: 953.87 GiB block-size: physical: 512 B
fw-rev: 21106000 temp: 42.9 C scheme: GPT
ID-1: / raw-size: 1.79 TiB size: 1.79 TiB (100.00%) used: 440.91 GiB (24.1%)
used: 892 KiB (0.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
used: 440.91 GiB (24.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 32
ID-2: swap-2 type: partition size: 34.37 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 56.1 C mobo: 47.9 C gpu: amdgpu temp: 67.0 C
mem: 74.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 574
Memory: total: 32 GiB available: 31.25 GiB used: 5.71 GiB (18.3%)
Processes: 564 Power: uptime: 21m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.48 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1850 libs: 537 tools: octopi,paru Compilers:
clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1
System install date:     2024-11-27
Last full system update: 2024-12-08
Issue disappeared after further system update the following day.
