when I am using this command sudo ls -l /usr/lib/x86_64-linux-gnu/opera/ then it is showing
╰─λ sudo ls -l /usr/lib/x86_64-linux-gnu/opera/
ls: cannot access '/usr/lib/x86_64-linux-gnu/opera/': No such file or directory```
System information? Context? What is the goal?
I assume the context could be as part of this other thread (at least that path was mentioned in the video I suggested and maybe was found also by the requester):
If confirmed, we could merge the topics…
This means the file or directory does not exist on your computer, that is, it is not present. You cannot show a file that isn’t present.
It should be
/usr/lib/opera
