/usr/lib/polkit-kde-authentication-agent-1
Hello I Downloaded garuda linux plasma 10 minutes ago I have the same problem there 243 updtaes to be done but it says authentication required and there is no box to insert your password any help please
thank you it worked !!!
Hello, I did input /usr/lib/polkit-kde-authentication-agent-1 into the terminal ok it works but everytime I restart the pc or switch off I have to redo the process or the message shows up: "authentication required"
Is there way to fix this so I dont have to redo the process each time?
