Hello,
I have the same problem as Roberto. Except, the error is the file /usr/lib/calamares/modules/mount/main.py, missing.
I tested with version 04.28, 08.23 and 08.24
Another thing, when I launch livecd, the desktop is not complete. I don’t have the menu bar, nor the program launch icon.
Does anyone have a solution?
I move your post.
- Search the web and forums
- Read How to search for solutions the right way | Garuda Linux wiki
- Read FAQ and Tutorials Table of Contents
Issue still unresolved? Then:
- ONE issue per topic.
- Describe your issue in detail. The more we know, the better we can help
- Show us the results of your searches, and what you’ve tried
in the body of the post (not linked externally, or collapsed with the “hide details” feature) - Format terminal output (including your
) as a code block by clicking the preformatted text button (</>) , or put three tildes (~) above and below the text
It is better not to mix various different problems in one topic.
If solutions in the other post have helped you, post it here.
