Hi,
I have been testing wireplumber instead of pipewire-media-session for a few days, and so far all OK.
Is anyone else testing/using it? Maybe become a default replacement for pipewire-media-session ?
Thanks!
Hi,
Thanks!
On it since some weeks, working okay so far. There are occasional issues with changing output device but I'm really not sure if that is to be accounted to PipeWire or Wireplumber
Since Fedora is also looking at replacing the media session with Wireplumber, I think we can go for this as well in the future
What does this provide that the default pipewire-media-session does not? That is, what are the advantages to this?
Details here are pretty vague:
It’s apparently “less limited” than the default… ?
well, I am not an expert on this, hence my asking for feedback if anyone was using:
but like @dr460nf1r3 said, fedora is making the switch with these "supposed advantages": Changes/WirePlumber - Fedora Project Wiki
Well we install wireplumber by default anyway
What else needs to change
I like this first one:
So… the benefit of the change is that it’s the same? ![]()
(Yes, the above is only the first item taken out of context for comedic effect
If it’s not already done, the equivalent of:
systemctl --user --now disable pipewire-media-session
systemctl --user --now enable wireplumber
(Perhaps wireplumber also needs to provides=(pipewire-media-session) so it can be removed…)
Well then that's on arch
Which bit? If wireplumber is installed by default on Garuda but not enabled then it's not actually doing anything?
The provides and replaces stuff needs to be done by arch
As for wireplumber i think it provides wpctl
See we don't install pipewire media session its a dependancy of something
hum.... actually this is taking an unexpected turn for me:
I was expecting an answer like @dr460nf1r3 .... not a "lets do it!!!"
Really, I was just trying to get the conversation and considerations started. Like I mentioned above, I am not an expert on this pipewire newage thing
and I only tested it a few days.
But thanks everyone for your open mindness and quick feedback !
That's how things here work at times
not being backed by companies has advantages, for sure
If it’s better then get it done. ![]()
