Using Picture in Picturn (PiP) on top of top panel again
Hey there;
I’m using KDE Dragonized edition and often use PiP (Picture in Picture) with a minimized video in the top left corner and on top the Top panel bar (so it’s like an overlay) and not only right below where you can’t put the video on top of the top panel. Is there a way to change this new setting back to the previous one? I don’t change it and verify it with a update on my outdated Laptop which used system-update from 5th February 2025 and had this function enabled and after the update it doesn’t.
See Foto about what i mean with this position (as desired pre update with upates from 05th february)
After update and reboot with same settings:
Edit: added garuda-inxi
Kernel: 6.14.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/vmlinuz-linux-zen root=/dev/mapper/vglinux-garuda
rw rootflags=subvol=@ quiet quiet rd.udev.log_priority=3
vt.global_cursor_default=0 loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.3.4 tk: Qt v: N/A info: frameworks v: 6.12.0
Type: Laptop System: Acer product: Aspire E5-571G v: V1.32
Mobo: Acer model: EA50_HB v: V1.32 serial: <superuser required>
part-nu: Aspire E5-571G_0867_V1.32 uuid: <superuser required> UEFI: Insyde
v: 1.32 date: 09/15/2015
ID-1: BAT1 charge: 43.5 Wh (100.0%) condition: 43.5/55.9 Wh (77.7%)
volts: 13.0 min: 11.1 model: SANYO 0x32334134314C41 type: Li-ion
serial: <filter> status: full
Info: model: Intel Core i5-4210U bits: 64 type: MT MCP arch: Haswell
desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2394 min/max: 800/2700 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 2394 2: 2394 3: 2394 4: 2394 bogomips: 19154
Device-1: Intel Haswell-ULT Integrated Graphics
vendor: Acer Incorporated ALI driver: i915 v: kernel arch: Gen-7.5
process: Intel 22nm built: 2013 ports: active: eDP-1
empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:0a16
Device-2: NVIDIA GM108M [GeForce 840M] vendor: Acer Incorporated ALI
driver: nvidia v: 570.133.07 alternate: nouveau,nvidia_drm
arch: Maxwell code: GMxxx process: TSMC 28nm built: 2014-2019 pcie: gen: 1
speed: 2.5 GT/s lanes: 4 link-max: gen: 3 speed: 8 GT/s bus-ID: 03:00.0
chip-ID: 10de:1341 class-ID: 0302
Device-3: Chicony HD WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:4 chip-ID: 04f2:b469
class-ID: 0e02
unloaded: nouveau alternate: fbdev,intel,nv,vesa dri: crocus gpu: i915
display-ID: 0
Monitor-1: eDP-1 model: ChiMei InnoLux 0x15c3 built: 2013 res:
modes: 1920x1080
API: EGL v: 1.5 hw: drv: intel crocus drv: nvidia nouveau drv: nvidia
platforms: device: 0 drv: nvidia device: 1 drv: nouveau device: 2
drv: crocus device: 3 drv: swrast gbm: drv: nvidia surfaceless:
drv: nvidia wayland: drv: crocus x11: drv: crocus
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 25.0.3-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 4400 (HSW
GT2) device-ID: 8086:0a16 memory: 1.46 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.4.309 layers: 6 device: 0 type: integrated-gpu name: Intel
HD Graphics 4400 (HSW GT2) driver: N/A device-ID: 8086:0a16
surfaces: xcb,xlib,wayland device: 1 type: discrete-gpu
name: NVIDIA GeForce 840M driver: N/A device-ID: 10de:1341
Device-1: Intel Haswell-ULT HD Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0a0c
Device-2: Intel 8 Series HD Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9c20
API: ALSA v: k6.14.2-zen1-1-zen status: kernel-api with: aoss
speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 01:00.1 chip-ID: 10ec:8168
IF: enp1s0f1 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Broadcom BCM43142 802.11b/g/n vendor: Lite-On driver: wl
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0
chip-ID: 14e4:4365 class-ID: 0280
IF: wlp2s0 state: dormant mac: <filter>
IF-ID-1: wg0 state: unknown speed: N/A duplex: N/A mac: N/A
Device-1: Lite-On BCM43142A0 driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:3 chip-ID: 04ca:2009
Report: btmgmt ID: hci0 rfk-id: 3 state: up address: N/A
Local Storage: total: 465.76 GiB used: 89.95 GiB (19.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST500LM000-1EJ162
tech: HDD rpm: 5400 serial: <filter> fw-rev: SM28 scheme: GPT
ID-1: / raw-size: 90 GiB size: 90 GiB (100.00%) used: 42.51 GiB (47.2%)
fs: btrfs dev: /dev/dm-3 maj-min: 253:3 mapped: vglinux-garuda
ID-2: /boot raw-size: 512 MiB size: 512 MiB (100.00%)
used: 251.6 MiB (49.1%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
ID-3: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%)
used: 231.4 MiB (45.3%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-4: /home raw-size: 90 GiB size: 90 GiB (100.00%)
used: 42.51 GiB (47.2%) fs: btrfs dev: /dev/dm-3 maj-min: 253:3
ID-5: /var/log raw-size: 90 GiB size: 90 GiB (100.00%)
ID-6: /var/tmp raw-size: 90 GiB size: 90 GiB (100.00%)
ID-1: swap-1 type: zram size: 11.6 GiB used: 59.5 MiB (0.5%) priority: 100
comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 4
System Temperatures: cpu: 68.0 C mobo: N/A
Memory: total: 12 GiB available: 11.6 GiB used: 7.32 GiB (63.1%)
Processes: 271 Power: uptime: 4h 31m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 4.55 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1793 libs: 473 tools: octopi,pamac,paru,yay
pm: appimage pkgs: 0 Compilers: gcc: 14.2.1 Shell: garuda-inxi default: fish
v: 4.0.1 running-in: yakuake inxi: 3.3.37
head: '/var/log/pacman.log' kann nicht zum Lesen geöffnet werden: Datei oder Verzeichnis nicht gefunden
System install date:
Last full system update: 2025-04-16
do you mean this?
r click on the top panel. click show panel configuration and this box will show up.
I don’t verify the previous settings but i verify the change just with a simple update and after reboot it was active, where i can’t put my pip-Video on the top (over panel). The change was made some weeks earlier and i notice it on my daily machine. Just verified it with an outdated Laptop if it’s just a change cause the update or a failure that happens. And a update shouldn’t change the setting of this part on their own. But i choose there “Windows go below” cause i need it to be always visible and it shouldn’t block my Tabs in my web browsers. So i’m searching for a way to enable it again. My screen isn’t the biggest and i don’t want to change my panel to be always in the background or not full size (so like everything on the right). My settings are otherwise the same like yours but always visible with browser full-screen and adaptive opacity blocks some part of the browser window (at least for me).
I can only think there might have been a kde specific change as they transition over to some new code for panels in upcoming 6.4 but i’m not to sure.
