Hello,
new to both Linux and Garuda here.
Installed Garuda alongside Win10 (dual boot) on my laptop
had some problems during the install:
had to use systemd.mask=mhwd-live.service
to securely boot
and even there I had stability issues ON THE LIVE USB itself
fortunately a Bios/uefi update seemed to have made things better and I was finally able to install Garuda onto the laptop
but one major problem remains : using the keyboard makes the system crash
it seems like it goes into a forced shutdown
to be more precise:
I can still use the keyboard but I have to make sure to stay around 1 or 2 keypresses per second and that there is no overlap between the keypresses ( as you can imagine that isn't something that can be used on the long run as a gamer / aspiring dev )
I also connected a wireless Logitech Keyboard/MousePad to the laptop (logitech K400r) that uses a dongle
using the logitech keyboard DID NOT make garuda crash, this makes me think that this is linked to maybe the driver for the built in keyboard, or maybe the bios/uefi itself
I've tried looking for crash logs, but /var/crashes doesn't exist
my inexperience here shows, since I can't seem to find where I could find those crash reports, or logs.
The built in Keyboard had per key LED lighting, and there are also LEDs on the bottom of the laptop (ambiance lighting). I don't know if there is some kind of interference with this type of keyboard, but seeing that Garuda targets the gaming community I feel like LED keyboards would be supported
thanks for any input, and I am available if you need any extra information
SYSTEM INFO :
System: Kernel: 5.12.2-zen2-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=9ced3168-9c0d-403b-a12f-7872de9f227b rw [email protected] quiet splash
Desktop: LXQt 0.17.1 tk: Qt 5.15.2 info: cairo-dock, lxqt-panel wm: kwin_x11 vt: 1
Machine: Type: Laptop System: ASUSTeK product: ROG Strix G713QR_G713QR v: 1.0 serial: <filter>
Mobo: ASUSTeK model: G713QR v: 1.0 serial: <filter> UEFI: American Megatrends LLC.
v: G713QR.315 date: 03/11/2021
Battery: ID-1: BAT0 charge: 87.6 Wh (100.0%) condition: 87.6/90.0 Wh (97.3%) volts: 17.3
min: 15.9 model: AS3GWAF3KC GA50358 type: Li-ion serial: <filter> status: Full
CPU: Info: 8-Core model: AMD Ryzen 9 5900HX with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 family: 19 (25) model-id: 50 (80) stepping: 0 microcode: A50000B cache:
L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 105403
Speed: 2531 MHz min/max: 1200/3300 MHz boost: enabled Core speeds (MHz): 1: 2531
2: 1660 3: 2751 4: 1397 5: 1396 6: 1397 7: 1395 8: 1397 9: 3736 10: 2742 11: 3875
12: 3832 13: 3643 14: 3667 15: 3996 16: 3632
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW, STIBP:
always-on, RSB filling
Graphics: Device-1: NVIDIA GA104M [GeForce RTX 3070 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 465.27 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:249d class-ID: 0300
Device-2: AMD vendor: ASUSTeK driver: amdgpu v: kernel bus-ID: 06:00.0
chip-ID: 1002:1638 class-ID: 0300
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: modesetting,nvidia display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 300 dpi: 128 size: 382x215mm (15.0x8.5")
diag: 438mm (17.3")
OpenGL: renderer: AMD RENOIR (DRM 3.40.0 5.12.2-zen2-1-zen LLVM 11.1.0)
v: 4.6 Mesa 21.1.0 direct render: Yes
Audio: Device-1: AMD vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 06:00.1
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: ASUSTeK
driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus-ID: 06:00.5
Device-3: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.12.2-zen2-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.27 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK
driver: r8169 v: kernel port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: e000 bus-ID: 03:00.0
chip-ID: 8086:2723 class-ID: 0280
IF: wlan0 state: up mac: <filter>
Bluetooth: Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-4:3
chip-ID: 8087:0029 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 0 state: down bt-service: enabled,running
rfk-block: hardware: no software: yes address: <filter>
Drives: Local Storage: total: 1.84 TiB used: 86.56 GiB (4.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 1TB
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
rotation: SSD serial: <filter> rev: 2B2QEXE7 scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: SK Hynix model: HFM001TD3JX013N
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
rotation: SSD serial: <filter> rev: 41000C20 scheme: GPT
Partition: ID-1: / raw-size: 249.65 GiB size: 249.65 GiB (100.00%) used: 19.71 GiB (7.9%)
fs: btrfs dev: /dev/nvme1n1p7 maj-min: 259:10
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 25.9 MiB (10.1%)
fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:4
ID-3: /home raw-size: 249.65 GiB size: 249.65 GiB (100.00%) used: 19.71 GiB (7.9%)
ID-4: /var/log raw-size: 249.65 GiB size: 249.65 GiB (100.00%) used: 19.71 GiB (7.9%)
ID-5: /var/tmp raw-size: 249.65 GiB size: 249.65 GiB (100.00%) used: 19.71 GiB (7.9%)
ID-1: swap-1 type: zram size: 967.6 MiB used: 0 KiB (0.0%) priority: 32767
ID-2: swap-2 type: zram size: 967.6 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram1
ID-3: swap-3 type: zram size: 967.6 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram2
ID-4: swap-4 type: zram size: 967.6 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram3
ID-5: swap-5 type: zram size: 967.6 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram4
ID-6: swap-6 type: zram size: 967.6 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram5
ID-7: swap-7 type: zram size: 967.6 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram6
ID-8: swap-8 type: zram size: 967.6 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram7
ID-9: swap-9 type: zram size: 967.6 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram8
ID-10: swap-10 type: zram size: 967.6 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram9
ID-11: swap-11 type: zram size: 967.6 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram10
ID-12: swap-12 type: zram size: 967.6 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram11
ID-13: swap-13 type: zram size: 967.6 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram12
ID-14: swap-14 type: zram size: 967.6 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram13
ID-15: swap-15 type: zram size: 967.6 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram14
ID-16: swap-16 type: zram size: 967.6 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram15
Sensors: System Temperatures: cpu: 59.0 C mobo: N/A gpu: amdgpu temp: 54.0 C
Fan Speeds (RPM): cpu: 2500
Info: Processes: 420 Uptime: 1m wakeups: 4 Memory: 15.12 GiB used: 2.76 GiB (18.3%)
Init: systemd v: 248 tool: systemctl Compilers: gcc: 10.2.0 clang: 11.1.0 Packages:
pacman: 1474 lib: 420 Shell: fish v: 3.2.2 running-in: alacritty inxi: 3.3.04
