Hi iam using an external usb adapter rtl8188ftv
but i dont know how to install the drivers
Welcome
Can you provide your
as per the forum template
should I type in the console
yes and enclose it in
.~~~ before
.~~~ after
Kernel: 5.19.7-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2
root=UUID=0add137b-73ca-4063-bae5-d0be6cf66053 rw rootflags=subvol=@
Type: Desktop Mobo: INTEL model: H61 serial: <superuser required>
UEFI: American Megatrends v: 4.6.5 date: 12/07/2020
Info: model: Intel Core i5-3470S bits: 64 type: MCP arch: Ivy Bridge
gen: core 3 level: v3 built: 2012-15 process: Intel 22nm family: 6
desc: 1x6 MiB
Speed (MHz): avg: 2668 high: 3600 min/max: 1600/3600 scaling:
driver: intel_cpufreq governor: performance cores: 1: 1597 2: 3402 3: 3600
4: 2076 bogomips: 23148
disabled
STIBP: disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel Xeon E3-1200 v2/3rd Gen Core processor Graphics
driver: i915 v: kernel arch: Gen-7 process: Intel 22nm built: 2012-13
ports: active: none empty: DP-1,HDMI-A-2,VGA-2 bus-ID: 00:02.0
chip-ID: 8086:0152 class-ID: 0380
Device-2: NVIDIA GK208B [GeForce GT 710] vendor: ZOTAC driver: nouveau
v: kernel alternate: nvidia_drm,nvidia non-free: series: 470.xx+
status: legacy-active (EOL~2023/24) arch: Fermi 2 code: GF119/GK208
process: TSMC 28nm built: 2010-16 pcie: gen: 2 speed: 5 GT/s lanes: 8
ports: active: VGA-1 empty: DVI-D-1,HDMI-A-1 bus-ID: 01:00.0
chip-ID: 10de:128b class-ID: 0300
Device-3: Microdia USB 2.0 Camera type: USB driver: uvcvideo
bus-ID: 1-1.4:3 chip-ID: 0c45:6367 class-ID: 0e02
compositor: kwin_x11 driver: X: loaded: modesetting,nouveau
alternate: fbdev,intel,nv,vesa gpu: nouveau display-ID: :0 screens: 1
Screen-1: 0 s-res: 1680x1050 s-dpi: 96 s-size: 444x277mm (17.48x10.91")
s-diag: 523mm (20.6")
Monitor-1: VGA-1 model: Dell P2213 serial: <filter> built: 2015
res: 1680x1050 hz: 60 dpi: 90 gamma: 1.2 size: 473x296mm (18.62x11.65")
diag: 558mm (22") ratio: 16:10 modes: max: 1680x1050 min: 720x400
OpenGL: renderer: NV106 v: 4.3 Mesa 22.1.7 direct render: Yes
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1c20
Device-2: NVIDIA GK208 HDMI/DP Audio vendor: ZOTAC driver: snd_hda_intel
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 8 bus-ID: 01:00.1
chip-ID: 10de:0e0f class-ID: 0403
Sound Server-1: ALSA v: k5.19.7-zen2-1-zen running: yes
Device-1: Realtek RTL810xE PCI Express Fast Ethernet driver: r8169
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0
Device-2: Realtek RTL8188FTV 802.11b/g/n 1T1R 2.4G WLAN Adapter type: USB
driver: N/A bus-ID: 2-1.4:4 chip-ID: 0bda:f179 class-ID: 0000
IF-ID-1: enp0s26u1u2 state: unknown speed: -1 duplex: half mac: <filter>
Device-1: Samsung Galaxy series misc. (tethering mode) type: USB
driver: rndis_host v: kernel bus-ID: 1-1.2:21 chip-ID: 04e8:6863
Report: bt-service: enabled,stopped note: tool can't run
Local Storage: total: 447.14 GiB used: 22.7 GiB (5.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: HM160HI
size: 149.05 GiB block-size: physical: 512 B logical: 512 B speed: 1.5 Gb/s
type: N/A serial: <filter> rev: 0-06 scheme: GPT
model: WD3200BEKT-08PVMT1 size: 298.09 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: 1A02 scheme: GPT
ID-1: / raw-size: 297.79 GiB size: 297.79 GiB (100.00%) used: 22.7 GiB
(7.6%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
(0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 297.79 GiB size: 297.79 GiB (100.00%) used: 22.7
GiB (7.6%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
ID-4: /var/log raw-size: 297.79 GiB size: 297.79 GiB (100.00%) used: 22.7
ID-5: /var/tmp raw-size: 297.79 GiB size: 297.79 GiB (100.00%) used: 22.7
ID-1: swap-1 type: zram size: 6.73 GiB used: 47.8 MiB (0.7%)
System Temperatures: cpu: 41.0 C mobo: N/A gpu: nouveau temp: 50.0 C
Processes: 205 Uptime: 1h 45m wakeups: 0 Memory: 6.73 GiB used: 1.91 GiB
(28.4%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1841 libs: 519
running-in: konsole inxi: 3.3.21
Garuda (2.6.8-1):
System install date: 2022-08-08
Last full system update: 2022-10-02 ↻
Failed units: ~~~
is this the one?
There seem to be a couple of packages in the AUR repository, as suggested in this topic.
You’ll need ethernet or phone tethering connection.
To install from AUR use paru <package name>
it look like you need to install 8192eu-dkms from the aur
how do i do it
can u pls guide me
Unfortunately, in any Arch-based distribution, "guiding" is the wrong approach. It may work once but a few hours later you may need more help.
As for paru, the only advice is that it will show you a preview of the PKGBUILD. Press q to exit and confirm to proceed with the installation.
As filo instructed use
paru <package name
in the terminal and use octupi to find the package you need
no no thats not what i meant i dont know how to do it
dkms install 8188fu/${1%%-*}
pre_upgrade() {
pre_remove ${2%%-*}
post_upgrade() {
post_install ${1%%-*}
pre_remove() {
dkms remove 8188fu/${1%%-*} --all
} ~~~ should i type anything?
See above.
Careful here.
You correctly updated your system but have not rebooted.
This is important in this case, due to the new kernel you’ll have now.
-> Running build hook: [grub-btrfs-overlayfs]
==> Generating module dependencies
==> Creating zstd-compressed initcpio image: /boot/initramfs-linux-zen-fallback.img
==> Image generation successful
(4/8) Foreign/AUR package notification
=> No foreign/AUR packages found.
(5/8) Orphaned package notification...
lib32-json-glib 1.6.6-2
lib32-pcre 8.45-3
lib32-rest 0.8.1-4
python-nspektr 0.4.0-2
(6/8) Checking for .pacnew and .pacsave files...
.pac* files found:
/etc/locale.gen.pacnew
Please check and merge
(7/8) Performing snapper post snapshots for the following configurations...
==> root: 14
(8/8) Syncing all file systems... ~~~
what should i do after this
It should be finished. You should have the terminal prompt ready after that.
If there were no error messages, try rebooting.
