Hello there!
I'm not used to linux yet. Garuda is my first distro since I ditched Windows as my primary. Please be gentle ![]()
I'm having an issue that looks like I cannot google-fu myself out of. When trying to use a GPU card I recently installed (it's the Device-1: AMD Juniper XT [Radeon HD 5770]) the system becomes unusable. Either it is extremely slow that it's not countable in FPS but more in seconds per frame (cursor movement seems unaffected funnily enough) or it just has blank output and I need to reboot with cable plugged back in integrated GPU (Device-3: AMD Raphael).
The card itself is sitting happily in the computer, as long as it doesn't have an output connected it seems to not cause any issues.
I tried updating the OS and toggled the preferred graphics output from iGPU to eGPU in BIOS. No improvement. Also, switched the 5770 with another AMD card but it had the exact same behavior.
There is a Nvidia plugged in (Device-2: NVIDIA GP106 [GeForce GTX 1060 6GB]) but it is used as pass-through IOMMU card and doesn't load / initialize with Garuda, I think it can be safely ignored for now. I've also tested booting up with the 1060 removed from the computer and it didn't change anything. In case it helps:
nvidia-smi
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA
driver is installed and running.
that's fine I think since I'm trying to use an AMD GPU.
As far as I can tell it seems like the drivers for AMD are being used...
Here's the garuda-inxi:
Kernel: 6.0.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=40fa0984-99cd-4310-a32f-915584c29f3a rw rootflags=subvol=@
resume=UUID=a36614fb-3d88-49e3-9062-fede76fac01d loglevel=3 amd_iommu=on
iommu=pt vfio-pci.ids=10de:1c03,10de:10f1 video=efib:off ibt=off
Mobo: ASUSTeK model: TUF GAMING B650-PLUS WIFI v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 0613
date: 09/22/2022
Info: model: AMD Ryzen 7 7700X bits: 64 type: MT MCP arch: Zen 4 gen: 5
level: v4 note: check built: 2022 process: TSMC n5 (5nm) family: 0x19 (25)
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 2266 high: 5539 min/max: 400/5573 boost: enabled
scaling: driver: amd-pstate governor: schedutil cores: 1: 5539 2: 5151
3: 400 4: 400 5: 400 6: 400 7: 5539 8: 400 9: 5376 10: 400 11: 400 12: 400
13: 2757 14: 2769 15: 400 16: 5539 bogomips: 143728
Device-1: AMD Juniper XT [Radeon HD 5770] driver: radeon v: kernel
alternate: amdgpu arch: TeraScale-2 code: Evergreen process: TSMC 32-40nm
built: 2009-15 pcie: gen: 2 speed: 5 GT/s lanes: 16 ports: active: none
empty: DP-1, DVI-I-1, DVI-I-2, HDMI-A-1 bus-ID: 01:00.0 chip-ID: 1002:68b8
class-ID: 0300 temp: 36.0 C
Device-2: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: Gigabyte
driver: vfio-pci v: N/A alternate: nouveau,nvidia_drm,nvidia
non-free: 525.xx+ status: current (as of 2022-12) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 05:00.0
chip-ID: 10de:1c03 class-ID: 0300
Device-3: AMD Raphael driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: DP-2 empty: HDMI-A-2 bus-ID: 0d:00.0 chip-ID: 1002:164e
Display: x11 server: X.Org v: 21.1.5 with: Xwayland v: 22.1.6
compositor: kwin_x11 driver: X: loaded: radeon unloaded: amdgpu,modesetting
alternate: fbdev,vesa dri: radeonsi,r600 gpu: amdgpu display-ID: :0
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 506x285mm (19.92x11.22")
s-diag: 581mm (22.86")
Monitor-1: DP-2 mapped: DisplayPort-1 model: Samsung C49RG9x
serial: <filter> built: 2020 res: 1920x1080 hz: 60 dpi: 41 gamma: 1.2
size: 1190x340mm (46.85x13.39") diag: 1239mm (48.8") modes: max: 1920x1080
min: 720x400
API: OpenGL v: 4.6 Mesa 22.2.3 renderer: AMD Radeon Graphics (gfx1036
LLVM 14.0.6 DRM 3.48 6.0.12-zen1-1-zen) direct render: Yes
Device-1: AMD Juniper HDMI Audio [Radeon HD 5700 Series]
driver: snd_hda_intel v: kernel pcie: bus-ID: 1-6:3 gen: 2
chip-ID: 045e:070f speed: 5 GT/s class-ID: 0300 lanes: 16 bus-ID: 01:00.1
chip-ID: 1002:aa58 class-ID: 0403
Device-2: NVIDIA GP106 High Definition Audio vendor: Gigabyte
driver: vfio-pci alternate: snd_hda_intel pcie: gen: 1 speed: 2.5 GT/s
lanes: 4 link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 05:00.1
chip-ID: 10de:10f1 class-ID: 0403
Device-3: AMD Rembrandt Radeon High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0d:00.1
bus-ID: 0d:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-5: Microsoft LifeChat LX-3000 Headset type: USB
Sound API: ALSA v: k6.0.12-zen1-1-zen running: yes
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: c000 bus-ID: 08:00.0
lanes: 1 bus-ID: 09:00.0 chip-ID: 14c3:7961 class-ID: 0280
IF: wlp9s0 state: up mac: <filter>
Device-1: IMC Networks Wireless_Device type: USB driver: btusb v: 0.8
bus-ID: 1-5:2 chip-ID: 13d3:3563 class-ID: e001 serial: <filter>
Local Storage: total: 1.82 TiB used: 88.68 GiB (4.8%)
ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: Samsung model: SSD 980 PRO 1TB
lanes: 4 type: SSD serial: <filter> rev: 5B2QGXA7 temp: 34.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 1TB
lanes: 4 type: SSD serial: <filter> rev: 5B2QGXA7 temp: 30.9 C scheme: GPT
ID-1: / raw-size: 863.06 GiB size: 863.06 GiB (100.00%)
used: 88.68 GiB (10.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:7
used: 608 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:6
ID-3: /home raw-size: 863.06 GiB size: 863.06 GiB (100.00%)
ID-4: /var/log raw-size: 863.06 GiB size: 863.06 GiB (100.00%)
ID-5: /var/tmp raw-size: 863.06 GiB size: 863.06 GiB (100.00%)
ID-1: swap-1 type: partition size: 68.15 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:8
ID-2: swap-2 type: zram size: 61.96 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 43.0 C mobo: N/A
GPU: device: amdgpu temp: 36.0 C device: radeon temp: 36.0 C
Processes: 344 Uptime: 2h 13m wakeups: 0 Memory: 61.96 GiB
used: 5.01 GiB (8.1%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1393
libs: 419 tools: octopi,paru Shell: fish v: 3.5.1 default: Bash v: 5.1.16
Garuda (2.6.10-1):
System install date: 2022-12-04
Last full system update: 2022-12-15
Let me know if you need more info. Thanks in advance for your time ![]()
