I am sorry. I'm new to Linux. I have a problem not being able to connect to any wifi. not even wifi detected.
I can now connect via LAN, and USB Tethering, and I can also create a Hotspot. Previously I always used LAN, because I moved house, so there was only Wifi. I realized that wifi is not detected after I managed to create a hotspot using GitHub - lakinduakash/linux-wifi-hotspot: Feature-rich wifi hotspot creator for Linux which provides both GUI and command-line interface. It is also able to create a hotspot using the same wifi card which is connected to an AP already ( Similar to Windows 10). .
When I run
sudo iwlist wlo1 scan
the result is
wlo1 Interface doesn't support scanning : Network is down
I try run
sudo ifconfig wlo1 up
but still not working
this is the result of ip addr
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: eno1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN group default qlen 1000
link/ether b4:b6:86:e8:e8:92 brd ff:ff:ff:ff:ff:ff
altname enp3s0
3: enp0s20f0u1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UNKNOWN group default qlen 100
0
link/ether 46:95:eb:a2:8a:78 brd ff:ff:ff:ff:ff:ff
inet 192.168.50.106/24 brd 192.168.50.255 scope global dynamic noprefixroute enp0s20f0u1
valid_lft 2956sec preferred_lft 2956sec
inet6 fe80::d2a5:59cb:4c38:7fad/64 scope link noprefixroute
4: wlo1: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether 74:40:bb:83:6d:29 brd ff:ff:ff:ff:ff:ff
altname wlp4s0
this result garuda-inxi
Kernel: 5.18.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=6b198665-886a-4bab-938e-9ea3e5718fc3 rw rootflags=subvol=@
loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.25.2 tk: Qt v: 5.15.5 info: latte-dock
Type: Laptop System: HP product: HP Pavilion Notebook v: N/A
Mobo: HP model: 84F8 v: 08.11 serial: <superuser required> UEFI: AMI
v: F.31 date: 08/10/2021
ID-1: BAT0 charge: 52.7 Wh (100.0%) condition: 52.7/52.7 Wh (100.0%)
volts: 12.2 min: 11.6 model: HP Primary type: Li-ion serial: N/A
status: full
Info: model: Intel Core i5-8300H bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 built: 2018 process: Intel 14nm family: 6 model-id: 0x9E (158)
stepping: 0xA (10) microcode: 0xF0
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 3920 high: 3997 min/max: 800/4000 scaling:
driver: intel_pstate governor: powersave cores: 1: 3900 2: 3900 3: 3878
4: 3901 5: 3900 6: 3901 7: 3984 8: 3997 bogomips: 36799
Type: l1tf
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Hewlett-Packard
driver: i915 v: kernel arch: Gen9.5 process: Intel 14nm built: 2016-20
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:3e9b
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Hewlett-Packard
driver: nvidia v: 515.57 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Pascal process: TSMC 16nm
built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16
ports: active: none off: HDMI-A-2 empty: none bus-ID: 01:00.0
chip-ID: 10de:1c8d class-ID: 0300
Device-3: Chicony HP Wide Vision HD type: USB driver: uvcvideo
bus-ID: 1-6:5 chip-ID: 04f2:b56d class-ID: 0e02
gpu: i915,nvidia,nvidia-nvswitch display-ID: :0 screens: 1
s-diag: 1052mm (41.43")
Monitor-1: HDMI-A-2 mapped: HDMI-0 note: disabled pos: primary,right
model: LG (GoldStar) ULTRAGEAR serial: <filter> built: 2022 res: 1920x1080
hz: 144 dpi: 93 gamma: 1.2 size: 527x296mm (20.75x11.65")
diag: 604mm (23.8") ratio: 16:9 modes: max: 1920x1080 min: 640x480
Monitor-2: eDP-1 mapped: eDP-1-1 pos: primary,left
model: ChiMei InnoLux 0x15e3 built: 2015 res: 1920x1080 hz: 60 dpi: 142
gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9
modes: 1920x1080
OpenGL: renderer: NVIDIA GeForce GTX 1050/PCIe/SSE2
v: 4.6.0 NVIDIA 515.57 direct render: Yes
driver: snd_hda_intel bus-ID: 1-3:23 v: kernel
alternate: snd_soc_skl,snd_sof_pci_intel_cnl chip-ID: 0d8c:0012
bus-ID: 00:1f.3 class-ID: 0300 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16
Device-3: C-Media USB Audio Device type: USB
Sound Server-1: ALSA v: k5.18.8-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.53 running: yes
speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 03:00.0 chip-ID: 10ec:8168
Device-2: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter
vendor: Hewlett-Packard driver: rtw_8822be v: N/A modules: rtw88_8822be
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 04:00.0
chip-ID: 10ec:b822 class-ID: 0280
IF-ID-1: enp0s20f0u1 state: unknown speed: -1 duplex: half mac: <filter>
Device-1: Realtek Bluetooth 4.2 Adapter type: USB driver: btusb v: 0.8
bus-ID: 1-7:7 chip-ID: 0bda:b00b class-ID: e001 serial: <filter>
Report: bt-adapter ID: hci0 rfk-id: 1 state: down
address: <filter>
v: 3.0 port: 6060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A
class-ID: 0104
Local Storage: total: 1.84 TiB used: 672.31 GiB (35.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Transcend model: TS1TMTE220S
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 42A7T36A
temp: 45.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: RSM7
ID-1: / raw-size: 228.87 GiB size: 228.87 GiB (100.00%)
used: 94.9 GiB (41.5%) fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
used: 25.6 MiB (26.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 228.87 GiB size: 228.87 GiB (100.00%)
ID-4: /var/log raw-size: 228.87 GiB size: 228.87 GiB (100.00%)
ID-5: /var/tmp raw-size: 228.87 GiB size: 228.87 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.44 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 62.0 C pch: 70.0 C mobo: N/A gpu: nvidia
temp: 58 C
Processes: 353 Uptime: 50m wakeups: 2 Memory: 15.44 GiB
used: 7.57 GiB (49.0%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6 Packages: apt: 0
pacman: 1710 lib: 451 Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.19
Garuda (2.6.4-2):
System install date: 2022-04-29
Last full system update: 2022-07-03
