Hello, sorry if my english is a little bit bad, it not my primary language. i’m very better to read english.
I’m new to linux.
I have installed Garuda some month ago. learn and install app, do update, use my computer. The basic.
I love it.
but 2 day ago i wanted to use my dock drive plugged in firewire800 port. but each time i try to use it, the system crash. I know it worked before. i have used it to copy file in my fresh install of Garuda.
What i try:
the system are all to date with garuda-update
the system crash if i run the drive the time garuda work or during the shutdown (the system don’t shutdown)
i try to run it before i start the computer and the system freeze at the startup (like after the detection of the video card (i see log of something)).
I can run it want i choose the uefi (like boot my old mac partition) so the disk and the firewire port work.
I have boot the garuda install iso and the firewire work. i have access to the disk.
I want to repair that but i don’t know how to do it.
garuda-inxi with firewire drive running fail. nothing show.
garuda-inxi without firewire drive running.
Thank for your help and time,
(UPDATE 12 mar 2024)
I have reinstall all the package with garuda assistant, reboot and try again the access to the firewire drive. that don’t do nothing same problem .
for the firewire if is running at the boot the last line of “log” indicate something like:
tg3 000:02:00.0 vdp access failed
It seem also possible for me to change to the terminal (ctrl alt f3) and connect in this. the system don’t boot in graphical mode. for the limited thing i understand.
Did you need other thing(command, log, ?) to help me?
sudo garuda-inxi =>
Kernel: 6.7.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=cf1a222f-bde5-4fd9-8123-f1c596b1365d rw rootflags=subvol=@
quiet resume=UUID=82e4639f-ad2a-4f0b-acbf-b681f21abca3 loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.0.1 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Type: Desktop System: Apple product: iMac11,3 v: 1.0 serial: <filter>
Chassis: type: 13 v: Mac-F2238BAE serial: <filter>
Mobo: Apple model: Mac-F2238BAE v: iMac11,3 serial: <filter>
uuid: c2e3076e-ca8e-3251-acdd-2ec2d3fd39b9 UEFI: Apple v: 99.0.0.0.0
date: 06/13/2019
Info: model: Intel Core i5 680 socket: U2E1 bits: 64 type: MT MCP SMP
arch: Westmere gen: core 1 level: v2 built: 2010-11 process: Intel 32nm
family: 6 model-id: 0x25 (37) stepping: 5 microcode: 0x7
L1: 4x 128 KiB (512 KiB) desc: d-2x32 KiB; i-2x32 KiB L2: 4x 512 KiB (2 MiB)
desc: 2x256 KiB L3: 4x 4 MiB (16 MiB) desc: 1x4 MiB
Speed (MHz): avg: 3592 min/max: 1197/3592 boost: enabled
base/boost: 3600/3600 scaling: driver: acpi-cpufreq governor: performance
volts: 0.0 V ext-clock: 133 MHz cores: 1: 3592 2: 3592 3: 3592 4: 3592
bogomips: 28727
Device-1: AMD Broadway PRO [Mobility Radeon HD 5850]
vendor: Apple iMac MC511 driver: radeon v: kernel alternate: amdgpu
arch: TeraScale-2 code: Evergreen process: TSMC 32-40nm built: 2009-15
pcie: gen: 2 speed: 5 GT/s lanes: 16 ports: active: eDP-1 empty: DP-1
bus-ID: 01:00.0 chip-ID: 1002:68a1 class-ID: 0300
Device-2: Apple Built-in iSight driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.1:3 chip-ID: 05ac:8502
Display: server: X.Org v: 23.2.4 with: Xwayland v: 23.2.4
compositor: kwin_wayland driver: X: loaded: radeon unloaded: modesetting
alternate: fbdev,vesa dri: r600 gpu: radeon display-ID: :1 screens: 1
s-diag: 777mm (30.58")
Monitor-1: eDP-1 model: Apple Color LCD built: 2010 res: 2560x1440 hz: 60
dpi: 108 gamma: 1.2 size: 600x340mm (23.62x13.39") diag: 685mm (27")
API: EGL v: 1.5 hw: drv: amd r600 platforms: device: 0 drv: r600 device: 1
drv: swrast gbm: drv: r600 surfaceless: drv: r600 x11: drv: r600
inactive: wayland
API: OpenGL v: 4.5 vendor: mesa v: 24.0.2-arch1.2 glx-v: 1.4
direct-render: yes renderer: AMD JUNIPER (DRM 2.50.0 / 6.7.9-zen1-1-zen
LLVM 17.0.6) device-ID: 1002:68a1 memory: 1000 MiB unified: no
API: Vulkan v: 1.3.279 layers: 9 device: 0 type: cpu name: llvmpipe (LLVM
17.0.6 128 bits) driver: mesa llvmpipe v: 24.0.2-arch1.2 (LLVM 17.0.6)
Device-1: Intel 5 Series/3400 Series High Definition Audio
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:3b56
Device-2: AMD Juniper HDMI Audio [Radeon HD 5700 Series] vendor: Apple
bus-ID: 01:00.1 chip-ID: 1002:aa58 class-ID: 0403
API: ALSA v: k6.7.9-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.3 status: n/a (root, process) with:
Device-1: Broadcom NetXtreme BCM5764M Gigabit Ethernet PCIe driver: tg3
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 02:00.0
chip-ID: 14e4:1684 class-ID: 0200
Device-2: Qualcomm Atheros AR928X Wireless Network Adapter
vendor: Apple AirPort Extreme driver: ath9k v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:002a class-ID: 0280
IF: wls1 state: up mac: <filter>
Device-1: Apple Built-in Bluetooth 2.0+EDR HCI driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-1.1.1:6
chip-ID: 05ac:8215 class-ID: fe01 serial: <filter>
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 2.1
lmp-v: 4 status: discoverable: no pairing: no class-ID: 6c0104
Local Storage: total: 476.94 GiB used: 238.28 GiB (50.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: PNY model: CS1311 480GB SSD
family: Driven SSDs size: 447.13 GiB block-size: physical: 512 B
logical: 512 B sata: 3.1 speed: 3.0 Gb/s tech: SSD serial: <filter>
fw-rev: 1122 temp: 30 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 280d 13h cycles: 1946
written: 9412 GiB
ID-2: /dev/sdb maj-min: 8:16 vendor: Apple model: SD Card Reader
size: 29.81 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: 1.00
ID-1: / raw-size: 60 GiB size: 60 GiB (100.00%) used: 28.45 GiB (47.4%)
fs: btrfs block-size: 4096 B dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
used: 15.6 MiB (3.1%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 370 GiB size: 370 GiB (100.00%)
used: 209.81 GiB (56.7%) fs: btrfs block-size: 4096 B dev: /dev/sda3
maj-min: 8:3
ID-4: /var/log raw-size: 60 GiB size: 60 GiB (100.00%)
used: 28.45 GiB (47.4%) fs: btrfs block-size: 4096 B dev: /dev/sda2
maj-min: 8:2
ID-5: /var/tmp raw-size: 60 GiB size: 60 GiB (100.00%)
maj-min: 8:2
ID-1: swap-1 type: zram size: 15.61 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda4 maj-min: 8:4
System Temperatures: cpu: 50.0 C mobo: N/A
Fan Speeds (rpm): cpu: 938
Memory: total: 16 GiB available: 15.61 GiB used: 2.19 GiB (14.0%)
Processes: 260 Power: uptime: 1m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.23 GiB services: org_kde_powerdevil,
Packages: 2359 pm: pacman pkgs: 2326 libs: 595 tools: octopi,pamac,paru
pm: flatpak pkgs: 33 Compilers: clang: 17.0.6 gcc: 13.2.1
Shell: garuda-inxi (sudo) default: Bash v: 5.2.26 running-in: konsole
inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2023-11-06
Last full system update: 2024-03-10
