Garuda-inxi given below -
Kernel: 5.19.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=ec56f045-0b46-48cb-ad41-c68705366f20 rw rootflags=subvol=@
quiet
cryptdevice=UUID=a67a8316-52c4-4a8e-b15d-27bb91d58197:luks-a67a8316-52c4-4a8e-b15d-27bb91d58197
root=/dev/mapper/luks-a67a8316-52c4-4a8e-b15d-27bb91d58197 quiet splash
Type: Laptop System: Micro-Star product: GL62M 7RD v: REV:1.0
Mobo: Micro-Star model: MS-16J9 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends v: E16J9IMS.324 date: 03/23/2018
ID-1: BAT1 charge: 27.5 Wh (100.0%) condition: 27.5/43.2 Wh (63.7%)
volts: 12.2 min: 10.8 model: MSI BIF0_9 type: Li-ion serial: N/A
status: full
Info: model: Intel Core i7-7700HQ bits: 64 type: MT MCP arch: Kaby Lake
gen: core 7 level: v3 built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 9 microcode: 0xF0
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 2587 high: 2800 min/max: 800/3800 scaling:
driver: intel_pstate governor: powersave cores: 1: 2800 2: 1098 3: 2800
4: 2800 5: 2800 6: 2800 7: 2800 8: 2800 bogomips: 44798
vulnerable
PBRSB-eIBRS: Not affected
Device-1: Intel HD Graphics 630 vendor: Micro-Star MSI driver: i915
active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:591b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Micro-Star MSI
driver: nvidia v: 515.76 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-08) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1c8d
class-ID: 0302
Device-3: Acer BisonCam NB Pro type: USB driver: uvcvideo bus-ID: 1-11:4
chip-ID: 5986:0683 class-ID: 0e02 serial: <filter>
unloaded: nouveau alternate: fbdev,intel,nv,vesa gpu: i915 display-ID: :0
Monitor-1: eDP-1 model: ChiMei InnoLux 0x15d2 built: 2015 res: 1920x1080
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel HD Graphics 630 (KBL GT2) v: 4.6 Mesa 22.1.7
direct render: Yes
Device-1: Intel CM238 HD Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a171 class-ID: 0403
Sound Server-1: ALSA v: k5.19.10-zen1-1-zen running: yes
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0
Device-2: Qualcomm Atheros QCA8171 Gigabit Ethernet
vendor: Micro-Star MSI driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 1969:10a1 class-ID: 0200
Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-10:3 chip-ID: 8087:0aa7 class-ID: e001
Local Storage: total: 931.51 GiB used: 81.83 GiB (8.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS721010A9E630
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: A3U0
ID-1: / raw-size: 65.19 GiB size: 65.19 GiB (100.00%) used: 10.91 GiB
(16.7%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-a67a8316-52c4-4a8e-b15d-27bb91d58197
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%) used: 984 KiB
(0.2%) fs: vfat dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 65.19 GiB size: 65.19 GiB (100.00%) used: 10.91 GiB
ID-4: /var/log raw-size: 65.19 GiB size: 65.19 GiB (100.00%) used: 10.91
GiB (16.7%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
ID-5: /var/tmp raw-size: 65.19 GiB size: 65.19 GiB (100.00%) used: 10.91
ID-1: swap-1 type: zram size: 7.68 GiB used: 505 MiB (6.4%) priority: 100
ID-2: swap-2 type: partition size: 14.9 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda5 maj-min: 8:5
System Temperatures: cpu: 59.0 C pch: 48.0 C mobo: N/A
Processes: 310 Uptime: 1h 32m wakeups: 1 Memory: 7.68 GiB used: 4.28 GiB
(55.7%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: 1237 pm: pacman pkgs: 1227 libs: 311
tools: octopi,paru pm: snap pkgs: 10 Shell: Bash v: 5.1.16
running-in: tilix inxi: 3.3.21
Garuda (2.6.7-1):
System install date: 2022-09-24
Last full system update: 2022-09-24 ↻
I need some help with swap -
swapon
NAME TYPE SIZE USED PRIO
/dev/zram0 partition 7.7G 505.5M 100
/dev/sda5 partition 14.9G 0B -2
I have /dev/sda5 dedicated swap - How can I make sure Garuda is utilizing this for swap and to its fullest ? Any suggestions please. In manual partition this was an option but I needed the disc encryption and hence went for replace partition option during installation.
