Hi All!
I've been experiencing an issue with my usb wireless mouse ever since garuda-update
would result in 6.3.2-zen1-1-zen kernel. The issue is, that my mouse pointer moves super slow, rendering it basically useless. My garuda-inxi
is below:
Kernel: 6.3.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=cb2ded22-b906-4231-848c-561f155dfdd4 rw rootflags=subvol=@
resume=UUID=80c361fe-abbd-4583-93d4-0b8f4261812e loglevel=3 ibt=off
Type: Laptop System: Acer product: Nitro AN515-43 v: V1.08
Mobo: PK model: Octavia_PKS v: V1.08 serial: <superuser required>
UEFI: Insyde v: 1.08 date: 12/24/2019
ID-1: BAT1 charge: 37.5 Wh (100.0%) condition: 37.5/57.5 Wh (65.2%)
volts: 16.4 min: 15.4 model: LG 0x41,0x50,0x31,0x38,0x45,0x38,0x4D
type: Li-ion serial: <filter> status: full
Info: model: AMD Ryzen 7 3750H with Radeon Vega Mobile Gfx bits: 64
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1481 high: 2300 min/max: 1400/2300 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1400 2: 2300
3: 1400 4: 1223 5: 1400 6: 1400 7: 1327 8: 1400 bogomips: 36729
Device-1: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile]
vendor: Acer Incorporated ALI driver: nvidia v: 530.41.03
alternate: nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-05) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1c8c class-ID: 0302
Device-2: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
vendor: Acer Incorporated ALI driver: amdgpu v: kernel arch: GCN-5
lanes: 16 ports: active: HDMI-A-1,eDP-1 empty: none bus-ID: 05:00.0
chip-ID: 1002:15d8 class-ID: 0300 temp: 65.0 C
Device-3: Quanta HD User Facing driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1:2 chip-ID: 0408:a061
class-ID: 0e02
s-diag: 1245mm (49.01")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 pos: primary,right
model: Samsung C32H71x serial: <filter> built: 2019 res: 2560x1440 hz: 60
dpi: 93 gamma: 1.2 size: 697x392mm (27.44x15.43") diag: 800mm (31.5")
ratio: 16:9 modes: max: 2560x1440 min: 720x400
Monitor-2: eDP-1 mapped: eDP pos: left model: AU Optronics 0xd0ed
built: 2019 res: 1920x1080 hz: 120 dpi: 142 gamma: 1.2
size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 23.0.3 renderer: AMD Radeon Vega 10 Graphics
(raven LLVM 15.0.7 DRM 3.52 6.3.2-zen1-1-zen) direct-render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 05:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: Acer Incorporated ALI
Device-3: DSEA A/S EPOS H3PRO Dongle
lanes: 1 mode: 1.1 bus-ID: 1-3:3 chip-ID: 1395:0303 class-ID: 0300
API: ALSA v: k6.3.2-zen1-1-zen status: kernel-api tools: N/A
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8168
vendor: Lite-On driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 04:00.0 chip-ID: 168c:003e class-ID: 0280 temp: 33.0 C
IF-ID-2: virbr1 state: down mac: <filter>
Device-1: Lite-On driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 3-2:3 chip-ID: 04ca:3016 class-ID: e001
Local Storage: total: 1.14 TiB used: 85.23 GiB (7.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
model: HFM256GDJTNG-8310A size: 238.47 GiB block-size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 tech: SSD serial: <filter>
fw-rev: 80002C00 temp: 47.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM049-2GH172
tech: HDD rpm: 7200 serial: <filter> fw-rev: ACM1 scheme: GPT
ID-1: / raw-size: 223.22 GiB size: 223.22 GiB (100.00%)
used: 85.23 GiB (38.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 223.22 GiB size: 223.22 GiB (100.00%)
ID-4: /var/log raw-size: 223.22 GiB size: 223.22 GiB (100.00%)
ID-5: /var/tmp raw-size: 223.22 GiB size: 223.22 GiB (100.00%)
ID-1: swap-1 type: zram size: 13.59 GiB used: 14.5 MiB (0.1%)
ID-2: swap-2 type: partition size: 14.95 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 64.8 C mobo: N/A gpu: amdgpu temp: 64.0 C
Processes: 317 Uptime: 2m wakeups: 1 Memory: available: 13.59 GiB
used: 3.14 GiB (23.1%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1474 libs: 403 tools: octopi,paru Shell: fish v: 3.6.1 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.27
System install date: 2022-09-11
Last full system update: 2023-05-21
Clicks and scroll-wheel are working and testing the movements with libinput debug-events
I see that POINTER_MOTIONs are getting generated. I can also say that the touchpad is still working. I might also add that the mouse works on the login screen, and only after I logged in starts to exhibit this super slowness on the screen.
Looking at the arch the forums I've found a quite similar issue:Mouse not working in 6.3 kernel / Kernel & Hardware / Arch Linux Forums
..however in my case I do not experience any freezing or boot process hangs.
When I disconnect and reconnect the USB dongle I see the below logs in dmesg:
[ 2028.892132] usb 1-4.1: USB disconnect, device number 5
[ 2033.723831] usb 1-4.1: new full-speed USB device number 7 using xhci_hcd
[ 2033.875505] usb 1-4.1: New USB device found, idVendor=1532, idProduct=0094, bcdDevice= 1.00
[ 2033.875518] usb 1-4.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2033.875522] usb 1-4.1: Product: Orochi V2
[ 2033.875526] usb 1-4.1: Manufacturer: Razer
[ 2033.875529] usb 1-4.1: SerialNumber: 000000000000
[ 2034.056435] input: Razer Orochi V2 as /devices/pci0000:00/0000:00:08.1/0000:05:00.3/usb1/1-4/1-4.1/1-4.1:1.0/0003:1532:0094.000B/input/input27
[ 2034.056688] hid-generic 0003:1532:0094.000B: input,hidraw5: USB HID v1.11 Mouse [Razer Orochi V2] on usb-0000:05:00.3-4.1/input0
[ 2034.064862] input: Razer Orochi V2 Keyboard as /devices/pci0000:00/0000:00:08.1/0000:05:00.3/usb1/1-4/1-4.1/1-4.1:1.1/0003:1532:0094.000C/input/input28
[ 2034.117483] input: Razer Orochi V2 Mouse as /devices/pci0000:00/0000:00:08.1/0000:05:00.3/usb1/1-4/1-4.1/1-4.1:1.1/0003:1532:0094.000C/input/input29
[ 2034.117655] input: Razer Orochi V2 as /devices/pci0000:00/0000:00:08.1/0000:05:00.3/usb1/1-4/1-4.1/1-4.1:1.1/0003:1532:0094.000C/input/input30
[ 2034.117808] hid-generic 0003:1532:0094.000C: input,hidraw6: USB HID v1.11 Keyboard [Razer Orochi V2] on usb-0000:05:00.3-4.1/input1
[ 2034.125202] input: Razer Orochi V2 as /devices/pci0000:00/0000:00:08.1/0000:05:00.3/usb1/1-4/1-4.1/1-4.1:1.2/0003:1532:0094.000D/input/input31
[ 2034.177235] hid-generic 0003:1532:0094.000D: input,hidraw7: USB HID v1.11 Keyboard [Razer Orochi V2] on usb-0000:05:00.3-4.1/input2
[ 2034.185827] hid-generic 0003:1532:0094.000E: hiddev98,hidraw8: USB HID v1.11 Device [Razer Orochi V2] on usb-0000:05:00.3-4.1/input4
[ 2034.193458] input: Razer Orochi V2 Consumer Control as /devices/pci0000:00/0000:00:08.1/0000:05:00.3/usb1/1-4/1-4.1/1-4.1:1.3/0003:1532:0094.000F/input/input32
[ 2034.245798] hid-generic 0003:1532:0094.000F: input,hiddev99,hidraw9: USB HID v1.11 Device [Razer Orochi V2] on usb-0000:05:00.3-4.1/input3
I also have a logitech mouse with an USB wireless dongle - testing with that the result is even worse as the mouse doesn't work at all after the update.
I'm able to revert the update but I was wondering if anyone can help me fixing this issue so that I don't have to stall updating my system. I guess if the issue is with the kernel than there's not much to do (other than trying an other kernel), but I'm not qualified enough to say that the new kernel version is at fault. Thanks very much in advance!
Daniel
