Hello.
Got a Issue with my USB Stick.
Issue:
I cant created a new Boot Stick for Windows, I unmount the Stick and format it.
Now i cant mount it again
What i have done:
-udisksctl unmount -b -f /dev/sdc1
-mkfs.vfat /dev/sdc1
After this it unable to mount it again... i try different commands and method...
Hope i get some help here, maybe there is a Tool for this to manage?
Here are in In- An Output:
System: Kernel: 5.14.8-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=1cd508bb-7f15-4e60-ac09-3ce30403aae6
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Desktop Mobo: ASRock model: Z97E-ITX/ac serial: <filter> UEFI: American Megatrends
v: P2.00 date: 10/12/2015
CPU: Info: Quad Core model: Intel Core i7-5775C bits: 64 type: MT MCP arch: Broadwell family: 6
model-id: 47 (71) stepping: 1 microcode: 22 cache: L2: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 52680
Speed: 3681 MHz min/max: 800/3700 MHz Core speeds (MHz): 1: 3681 2: 3690 3: 3690 4: 3607
5: 3683 6: 3694 7: 3686 8: 3695
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Graphics: Device-1: NVIDIA GM204 [GeForce GTX 970] vendor: Gigabyte driver: nouveau v: kernel
bus-ID: 01:00.0 chip-ID: 10de:13c2 class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: nouveau
unloaded: modesetting alternate: fbdev,nv,vesa display-ID: :0 screens: 1
Monitor-1: HDMI-1 res: 1920x1080 hz: 60 dpi: 70 size: 698x392mm (27.5x15.4")
diag: 801mm (31.5")
OpenGL: renderer: NV124 v: 4.3 Mesa 21.2.2 direct render: Yes
Audio: Device-1: Intel 9 Series Family HD Audio vendor: ASRock driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:8ca0 class-ID: 0403
Device-2: NVIDIA GM204 High Definition Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
bus-ID: 01:00.1 chip-ID: 10de:0fbb class-ID: 0403
Sound Server-1: ALSA v: k5.14.8-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.37 running: yes
Network: Device-1: Intel Ethernet I218-V vendor: ASRock driver: e1000e v: kernel port: f040
bus-ID: 00:19.0 chip-ID: 8086:15a1 class-ID: 0200
Device-2: Broadcom BCM4352 802.11ac Wireless Network Adapter vendor: AzureWave driver: wl
v: kernel modules: bcma port: e000 bus-ID: 03:00.0 chip-ID: 14e4:43b1 class-ID: 0280
IF: wlp3s0 state: dormant mac: <filter>
IF-ID-1: enp0s20u9 state: unknown speed: -1 duplex: half mac: <filter>
Bluetooth: Device-1: IMC Networks BCM20702A0 type: USB driver: btusb v: 0.8 bus-ID: 3-11:5
chip-ID: 13d3:3404 class-ID: fe01 serial: <filter>
Device-2: Samsung Galaxy series misc. (tethering mode) type: USB driver: rndis_host v: kernel
bus-ID: 3-9:13 chip-ID: 04e8:6863 class-ID: 0a00 serial: <filter>
Drives: Local Storage: total: 949.93 GiB used: 431.47 GiB (45.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD5000BPKT-00PK4T0 size: 465.76 GiB
block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s type: HDD rpm: 7200
serial: <filter> rev: 1A01 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Transcend model: TS512GMTS400 size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 9A scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Toshiba model: TransMemory size: 7.23 GiB
block-size: physical: 512 B logical: 512 B type: N/A serial: <filter> rev: 1.00 scheme: MBR
Partition: ID-1: / raw-size: 476.68 GiB size: 476.68 GiB (100.00%) used: 26.86 GiB (5.6%) fs: btrfs
dev: /dev/sdb2 maj-min: 8:18
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.45%) used: 562 KiB (0.2%) fs: vfat
dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 476.68 GiB size: 476.68 GiB (100.00%) used: 26.86 GiB (5.6%) fs: btrfs
ID-4: /var/log raw-size: 476.68 GiB size: 476.68 GiB (100.00%) used: 26.86 GiB (5.6%) fs: btrfs
ID-5: /var/tmp raw-size: 476.68 GiB size: 476.68 GiB (100.00%) used: 26.86 GiB (5.6%) fs: btrfs
ID-1: swap-1 type: zram size: 15.57 GiB used: 1.8 MiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 37.0 C mobo: N/A gpu: nouveau temp: 31.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 1801
Info: Processes: 250 Uptime: 31m wakeups: 0 Memory: 15.57 GiB used: 2.45 GiB (15.7%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1673 lib: 499
Shell: fish v: 3.3.1 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
