I recently switched to Garuda linux and i tried formatting my USB but after doing so. The USB just disappeared, and it is not showing in the folder menu.
I tried unplugging and plugging it again but it didn’t worked.
Can someone plz help me.
Can you provide your
as per the forum template as this may help.
This can be done either by cmd line or going to garuda assistant and placing it here
Kernel: 6.6.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1 clocksource: tsc
available: acpi_pm parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen
root=UUID=75894dcc-cf3e-4fe4-9cb3-2d8775f95ebe rw rootflags=subvol=@ quiet loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin_wayland vt: 1 dm: SDDM
Type: Laptop System: Dell product: Latitude 5580 v: N/A serial: <superuser required> Chassis:
type: 10 serial: <superuser required>
Mobo: Dell model: 0FH6CJ v: A00 serial: <superuser required> UEFI: Dell v: 1.16.0
date: 07/03/2019
ID-1: BAT0 charge: 66.6 Wh (97.9%) condition: 68.0/68.0 Wh (100.0%) volts: 8.3 min: 7.6
model: LGC-LGC8.820 DELL DV9NT type: Li-ion serial: <filter> status: discharging
Info: model: Intel Core i7-7820HQ bits: 64 type: MT MCP arch: Kaby Lake gen: core 7 level: v3
note: check built: 2018 process: Intel 14nm family: 6 model-id: 0x9E (158) stepping: 9
microcode: 0xF4
Topology: cpus: 1x cores: 4 tpc: 2 threads: 8 smt: enabled cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 2888 high: 3793 min/max: 800/3900 scaling: driver: intel_pstate
governor: powersave cores: 1: 3600 2: 3597 3: 800 4: 3793 5: 3524 6: 3524 7: 3466 8: 800
bogomips: 46398
Device-1: Intel HD Graphics 630 vendor: Dell driver: i915 v: kernel arch: Gen-9.5
process: Intel 14nm built: 2016-20 ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2,
HDMI-A-3 bus-ID: 00:02.0 chip-ID: 8086:591b class-ID: 0300
Device-2: NVIDIA GM107 [GeForce 940MX] vendor: Dell driver: nvidia v: 545.29.02
alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current (as of 2023-10; EOL~2026-12-xx)
arch: Maxwell code: GMxxx process: TSMC 28nm built: 2014-2019 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:179c class-ID: 0302
Device-3: Microdia Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 1-11:4 chip-ID: 0c45:6717 class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.9 with: Xwayland v: 23.2.2 compositor: kwin_wayland
driver: X: loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,intel,nv,vesa dri: iris
Monitor-1: eDP-1 res: 1536x864 size: N/A modes: N/A
API: EGL v: 1.5 hw: drv: intel iris drv: nvidia platforms: device: 0 drv: nvidia device: 1
drv: iris device: 3 drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia wayland: drv: iris x11:
drv: iris inactive: device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 23.2.1-arch1.2 glx-v: 1.4
direct-render: yes renderer: Mesa Intel HD Graphics 630 (KBL GT2) device-ID: 8086:591b
memory: 7.46 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.269 layers: 4 device: 0 type: integrated-gpu name: Intel HD Graphics 630
(KBL GT2) driver: mesa intel v: 23.2.1-arch1.2 device-ID: 8086:591b surfaces: xcb,xlib,wayland
device: 1 type: discrete-gpu name: NVIDIA GeForce 940MX driver: nvidia v: 545.29.02
device-ID: 10de:179c surfaces: xcb,xlib,wayland device: 2 type: cpu name: llvmpipe (LLVM
16.0.6 256 bits) driver: mesa llvmpipe v: 23.2.1-arch1.2 (LLVM 16.0.6) device-ID: 10005:0000
Device-1: Intel CM238 HD Audio vendor: Dell driver: snd_hda_intel v: kernel
alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:a171 class-ID: 0403
Device-2: NVIDIA GM107 High Definition Audio [GeForce 940MX] driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0fbc class-ID: 0403
API: ALSA v: k6.6.1-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.85 status: active with: 1: pipewire-pulse status: active
2: wireplumber status: active 3: pipewire-alsa type: plugin
4: pw-jack type: plugin
Device-1: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel port: N/A bus-ID: 00:1f.6
chip-ID: 8086:15e3 class-ID: 0200
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:24fd class-ID: 0280
Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:2 chip-ID: 8087:0a2b class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 2 state: down bt-service: enabled,running rfk-block:
hardware: no software: no address: <filter> bt-v: 4.2 lmp-v: 8 status: discoverable: no
pairing: no
Local Storage: total: 238.47 GiB used: 16.11 GiB (6.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Consistent model: M.2 S6 256GB size: 238.47 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 0A0 scheme: GPT
ID-1: / raw-size: 238.17 GiB size: 238.17 GiB (100.00%) used: 16.11 GiB (6.8%) fs: btrfs
dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 576 KiB (0.2%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 238.17 GiB size: 238.17 GiB (100.00%) used: 16.11 GiB (6.8%) fs: btrfs
ID-4: /var/log raw-size: 238.17 GiB size: 238.17 GiB (100.00%) used: 16.11 GiB (6.8%) fs: btrfs
ID-5: /var/tmp raw-size: 238.17 GiB size: 238.17 GiB (100.00%) used: 16.11 GiB (6.8%) fs: btrfs
ID-1: swap-1 type: zram size: 7.64 GiB used: 0 KiB (0.0%) priority: 100 comp: zstd
avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 8 dev: /dev/zram0
System Temperatures: cpu: 51.0 C pch: 39.5 C mobo: 37.0 C
Fan Speeds (rpm): cpu: 0
Processes: 260 Uptime: 3m wakeups: 0 Memory: total: 8 GiB available: 7.64 GiB
used: 2.43 GiB (31.9%) Init: systemd v: 254 default: graphical tool: systemctl Compilers:
gcc: 13.2.1 Packages: pm: pacman pkgs: 1334 libs: 380 tools: octopi,paru Client: shell wrapper
v: 5.2.15-release inxi: 3.3.31
Garuda (2.6.19-2):
System install date: 2023-11-19
Last full system update: 2023-11-18
Failed units: System:
date: 07/03/2019
microcode: 0xF4
bogomips: 46398
pairing: no
Garuda (2.6.19-2):
Failed units: v
Use gnome-disk-utility and make yourself to owner.
How do i install gnome disk utility in garuda linux
like other apps too, or ssimple
upd -- gnome-disk-utility
It downloaded but I don’t know how to make myself owner
Thanks it worked, now it shows
