USB interface breaks between GRUB and GNOME session
Hi everyone,
I encountered a new weird issue. I currently only have three devices connected to my system which are daisy chained (PC --> Monitor, Monitor --> Keyboard, Keyboard --> Mouse). Mouse and keyboard are working fine in BIOS, and the keyboard is also working during boot in both LUKS decryption prompt as well as in GRUB & GRUB console.
However, once I am on the GNOME desktop (autologin) all USB devices are non-functional in the beginning. It then takes roughly 60-70 seconds for the USB interfaces to work again. Neither the mouse nor the keyboard respond to input in that timeframe. The keyboard seems actually to be powered down (as the LED lights go off), but weirdly enough the LED lights of the mouse (which is daisy chained to the keyboard) are on.
I confirmed that the problem has nothing to do with the daisy chain, as the same problem occurs when keyboard and mouse are directly connected to the PC. I also confirmed, that it has nothing to do with my hardware, as it works flawlessly on a Manjaro Live Stick.
Thank you in advance for your support.
dapari
  Kernel: 6.1.7-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    root=UUID=96d85ceb-9f0c-4bbf-a5b5-78faf25e7cde rw rootflags=subvol=@
    quiet
    cryptdevice=UUID=037c865d-59ed-4f6b-9fd9-2480ed588a95:luks-037c865d-59ed-4f6b-9fd9-2480ed588a95
    root=/dev/mapper/luks-037c865d-59ed-4f6b-9fd9-2480ed588a95 quiet splash
  Desktop: GNOME v: 43.2 tk: GTK v: 3.24.36 wm: gnome-shell dm: GDM v: 43.0
  Mobo: ASUSTeK model: ROG STRIX X670E-A GAMING WIFI v: Rev 1.xx
    serial: <superuser required> UEFI: American Megatrends v: 0805
    date: 11/04/2022
  Info: model: AMD Ryzen 5 7600X bits: 64 type: MT MCP arch: Zen 4 gen: 5
    level: v4 note: check built: 2022 process: TSMC n5 (5nm) family: 0x19 (25)
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 6 MiB desc: 6x1024 KiB
    L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 3000 min/max: 3000/5453 boost: disabled scaling:
    driver: acpi-cpufreq governor: ondemand cores: 1: 3000 2: 3000 3: 3000
    4: 3000 5: 3000 6: 3000 7: 3000 8: 3000 9: 3000 10: 3000 11: 3000 12: 3000
    bogomips: 112844
  Device-1: AMD Navi 21 [Radeon RX 6950 XT] vendor: Sapphire driver: amdgpu
    pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-3
    empty: DP-1,DP-2,HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:73a5
  Display: wayland server: X.org v: 1.21.1.6 with: Xwayland v: 22.1.7
    compositor: gnome-shell driver: X: loaded: amdgpu
    gpu: amdgpu display-ID: 0
  Monitor-1: DP-3 model: Acer XV282K KV serial: <filter> built: 2022
    res: 3840x2160 dpi: 157 gamma: 1.2 size: 621x341mm (24.45x13.43")
    diag: 708mm (27.9") ratio: 16:9 modes: max: 3840x2160 min: 720x400
  API: OpenGL v: 4.6 Mesa 22.3.3 renderer: AMD Radeon RX 6950 XT (navi21
    LLVM 15.0.7 DRM 3.49 6.1.7-arch1-1) direct render: Yes
    bus-ID: 3-6:2 chip-ID: 0b05:1a52 gen: 4 class-ID: 0300 speed: 16 GT/s
    lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28 class-ID: 0403
  Device-2: ASUSTek USB Audio type: USB
  Sound API: ALSA v: k6.1.7-arch1-1 running: yes
    lanes: 1 bus-ID: 0b:00.0 chip-ID: 14c3:0616 class-ID: 0280
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 0c:00.0
  Local Storage: total: 2.38 TiB used: 245.78 GiB (10.1%)
    model: WD BLACK SN850X 1000GB size: 931.51 GiB block-size: physical: 512 B
    rev: 620281WD temp: 35.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Western Digital
    rev: 620281WD temp: 27.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 840 EVO 120GB
    type: SSD serial: <filter> rev: DB6Q scheme: GPT
  ID-4: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT500MX200SSD1
    type: SSD serial: <filter> rev: MU02 scheme: GPT
  ID-1: / raw-size: 931.21 GiB size: 931.21 GiB (100.00%)
    used: 245.75 GiB (26.4%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-037c865d-59ed-4f6b-9fd9-2480ed588a95
    used: 29.8 MiB (10.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:2
  ID-3: /home raw-size: 931.21 GiB size: 931.21 GiB (100.00%)
  ID-4: /var/log raw-size: 931.21 GiB size: 931.21 GiB (100.00%)
  ID-5: /var/tmp raw-size: 931.21 GiB size: 931.21 GiB (100.00%)
  ID-1: swap-1 type: zram size: 31.09 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 46.6 C mobo: N/A gpu: amdgpu temp: 52.0 C
    mem: 52.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 717
  Processes: 359 Uptime: 9m wakeups: 0 Memory: 31.09 GiB
  used: 3.12 GiB (10.0%) Init: systemd v: 252 default: graphical
  tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1408
  libs: 451 tools: pamac,paru Shell: fish v: 3.6.0 default: Bash v: 5.1.16
  running-in: gnome-terminal inxi: 3.3.24
Garuda (2.6.14-1):
  System install date:     2023-01-07
  Last full system update: 2023-01-25
lsusb
Bus 009 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 010 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 008 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 003: ID 0b05:19af ASUSTek Computer, Inc. AURA LED Controller
Bus 003 Device 002: ID 0b05:1a52 ASUSTek Computer, Inc. USB Audio
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 003: ID 0bda:0411 Realtek Semiconductor Corp. Hub
Bus 002 Device 002: ID 0bda:0411 Realtek Semiconductor Corp. Hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 012: ID 042e:ac0a Acer, Inc. Sensor Hub
Bus 001 Device 010: ID 05e3:0610 Genesys Logic, Inc. Hub
Bus 001 Device 011: ID 0bda:1100 Realtek Semiconductor Corp. HID Device
Bus 001 Device 009: ID 0bda:5411 Realtek Semiconductor Corp. RTS5411 Hub
Bus 001 Device 008: ID 1038:1614 SteelSeries ApS SteelSeries Apex Pro TKL
Bus 001 Device 005: ID 1532:0067 Razer USA, Ltd Naga Trinity
Bus 001 Device 002: ID 0bda:5411 Realtek Semiconductor Corp. RTS5411 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
dmesg | grep USB
[    0.260038] usbcore: registered new interface driver usbfs
[    0.260038] usbcore: registered new interface driver hub
[    0.260038] usbcore: registered new device driver usb
[    0.421993] usbcore: registered new interface driver usbserial_generic
[    0.421996] usbserial: USB Serial support registered for generic
[    6.714527] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[    6.714529] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.714530] usb usb1: Product: xHCI Host Controller
[    6.714531] usb usb1: Manufacturer: Linux 6.1.7-arch1-1 xhci-hcd
[    6.714532] usb usb1: SerialNumber: 0000:10:00.0
[    6.715909] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    6.715917] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
[    6.715918] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.715918] usb usb2: Product: xHCI Host Controller
[    6.715919] usb usb2: Manufacturer: Linux 6.1.7-arch1-1 xhci-hcd
[    6.715919] usb usb2: SerialNumber: 0000:10:00.0
[    6.773437] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[    6.773438] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.773438] usb usb3: Product: xHCI Host Controller
[    6.773439] usb usb3: Manufacturer: Linux 6.1.7-arch1-1 xhci-hcd
[    6.773439] usb usb3: SerialNumber: 0000:12:00.0
[    6.774736] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    6.774744] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
[    6.774744] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.774745] usb usb4: Product: xHCI Host Controller
[    6.774745] usb usb4: Manufacturer: Linux 6.1.7-arch1-1 xhci-hcd
[    6.774745] usb usb4: SerialNumber: 0000:12:00.0
[    6.775895] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[    6.775896] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.775897] usb usb5: Product: xHCI Host Controller
[    6.775897] usb usb5: Manufacturer: Linux 6.1.7-arch1-1 xhci-hcd
[    6.775898] usb usb5: SerialNumber: 0000:15:00.3
[    6.776203] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[    6.776210] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
[    6.776211] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.776212] usb usb6: Product: xHCI Host Controller
[    6.776212] usb usb6: Manufacturer: Linux 6.1.7-arch1-1 xhci-hcd
[    6.776213] usb usb6: SerialNumber: 0000:15:00.3
[    6.777150] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[    6.777150] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.777151] usb usb7: Product: xHCI Host Controller
[    6.777151] usb usb7: Manufacturer: Linux 6.1.7-arch1-1 xhci-hcd
[    6.777152] usb usb7: SerialNumber: 0000:15:00.4
[    6.777428] usb usb8: We don't know the algorithms for LPM for this host, disabling LPM.
[    6.777435] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
[    6.777436] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.777436] usb usb8: Product: xHCI Host Controller
[    6.777437] usb usb8: Manufacturer: Linux 6.1.7-arch1-1 xhci-hcd
[    6.777437] usb usb8: SerialNumber: 0000:15:00.4
[    6.779292] usb usb9: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[    6.779293] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.779293] usb usb9: Product: xHCI Host Controller
[    6.779294] usb usb9: Manufacturer: Linux 6.1.7-arch1-1 xhci-hcd
[    6.779294] usb usb9: SerialNumber: 0000:16:00.0
[    6.779454] usb usb10: We don't know the algorithms for LPM for this host, disabling LPM.
[    6.779461] usb usb10: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
[    6.779461] usb usb10: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.779462] usb usb10: Product: xHCI Host Controller
[    6.779462] usb usb10: Manufacturer: Linux 6.1.7-arch1-1 xhci-hcd
[    6.779463] usb usb10: SerialNumber: 0000:16:00.0
[    7.035704] usb 1-4: new high-speed USB device number 2 using xhci_hcd
[    7.088740] usb 3-6: new high-speed USB device number 2 using xhci_hcd
[    7.286761] usb 1-4: New USB device found, idVendor=0bda, idProduct=5411, bcdDevice= 1.40
[    7.286764] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    7.286765] usb 1-4: Product: USB2.1 Hub
[    7.286766] usb 1-4: Manufacturer: Generic
[    7.386988] usb 2-4: new SuperSpeed USB device number 2 using xhci_hcd
[    7.422049] usb 2-4: New USB device found, idVendor=0bda, idProduct=0411, bcdDevice= 1.40
[    7.422051] usb 2-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    7.422052] usb 2-4: Product: USB3.2 Hub
[    7.422053] usb 2-4: Manufacturer: Generic
[    7.602062] usb 1-9: new high-speed USB device number 3 using xhci_hcd
[    9.397847] usb 3-6: New USB device found, idVendor=0b05, idProduct=1a52, bcdDevice= 0.05
[    9.397850] usb 3-6: New USB device strings: Mfr=3, Product=1, SerialNumber=0
[    9.397852] usb 3-6: Product: USB Audio
[    9.397853] usb 3-6: Manufacturer: Generic
[    9.454846] hid-generic 0003:0B05:1A52.0001: hiddev96,hidraw0: USB HID v1.11 Device [Generic USB Audio] on usb-0000:12:00.0-6/input7
[    9.454863] usbcore: registered new interface driver usbhid
[    9.454864] usbhid: USB HID core driver
[    9.635384] usb 3-7: new full-speed USB device number 3 using xhci_hcd
[   10.010673] usb 3-7: config 1 has an invalid interface number: 2 but max is 1
[   10.010676] usb 3-7: config 1 has no interface number 1
[   10.022594] usb 3-7: New USB device found, idVendor=0b05, idProduct=19af, bcdDevice= 1.00
[   10.022597] usb 3-7: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[   10.022598] usb 3-7: Product: AURA LED Controller
[   10.022599] usb 3-7: Manufacturer: AsusTek Computer Inc.
[   10.022600] usb 3-7: SerialNumber: 9876543210
[   10.037392] hid-generic 0003:0B05:19AF.0002: hiddev97,hidraw1: USB HID v1.11 Device [AsusTek Computer Inc. AURA LED Controller] on usb-0000:12:00.0-7/input2
[   12.895448] usb 1-9: device descriptor read/64, error -110
[   21.460430] usbcore: registered new interface driver snd-usb-audio
[   28.469074] usb 1-9: device descriptor read/64, error -110
[   28.972313] usb 1-9: new high-speed USB device number 4 using xhci_hcd
[   34.228798] usb 1-9: device descriptor read/64, error -110
[   49.802414] usb 1-9: device descriptor read/64, error -110
[   49.911234] usb usb1-port9: attempt power cycle
[   49.988719] usb 1-4.1: new full-speed USB device number 5 using xhci_hcd
[   50.266101] usb 2-4.3: new SuperSpeed USB device number 3 using xhci_hcd
[   50.301820] usb 1-4.1: New USB device found, idVendor=1532, idProduct=0067, bcdDevice= 2.00
[   50.301823] usb 1-4.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[   50.301825] usb 1-4.1: Product: Razer Naga Trinity
[   50.301826] usb 1-4.1: Manufacturer: Razer
[   50.301827] usb 1-4.1: SerialNumber: 00000000001A
[   50.303191] usb 2-4.3: New USB device found, idVendor=0bda, idProduct=0411, bcdDevice= 1.39
[   50.303195] usb 2-4.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   50.303196] usb 2-4.3: Product: USB3.2 Hub
[   50.303197] usb 2-4.3: Manufacturer: Generic
[   50.342932] input: Razer Razer Naga Trinity as /devices/pci0000:00/0000:00:02.1/0000:05:00.0/0000:06:08.0/0000:08:00.0/0000:09:0c.0/0000:10:00.0/usb1/1-4/1-4.1/1-4.1:1.0/0003:1532:0067.0003/input/input11
[   50.342999] hid-generic 0003:1532:0067.0003: input,hidraw2: USB HID v1.11 Mouse [Razer Razer Naga Trinity] on usb-0000:10:00.0-4.1/input0
[   50.362992] input: Razer Razer Naga Trinity Keyboard as /devices/pci0000:00/0000:00:02.1/0000:05:00.0/0000:06:08.0/0000:08:00.0/0000:09:0c.0/0000:10:00.0/usb1/1-4/1-4.1/1-4.1:1.1/0003:1532:0067.0004/input/input12
[   50.418784] input: Razer Razer Naga Trinity as /devices/pci0000:00/0000:00:02.1/0000:05:00.0/0000:06:08.0/0000:08:00.0/0000:09:0c.0/0000:10:00.0/usb1/1-4/1-4.1/1-4.1:1.1/0003:1532:0067.0004/input/input13
[   50.418825] hid-generic 0003:1532:0067.0004: input,hidraw3: USB HID v1.11 Keyboard [Razer Razer Naga Trinity] on usb-0000:10:00.0-4.1/input1
[   50.433933] input: Razer Razer Naga Trinity as /devices/pci0000:00/0000:00:02.1/0000:05:00.0/0000:06:08.0/0000:08:00.0/0000:09:0c.0/0000:10:00.0/usb1/1-4/1-4.1/1-4.1:1.2/0003:1532:0067.0005/input/input14
[   50.488820] hid-generic 0003:1532:0067.0005: input,hidraw4: USB HID v1.11 Keyboard [Razer Razer Naga Trinity] on usb-0000:10:00.0-4.1/input2
[   50.688704] usb 1-9: new high-speed USB device number 6 using xhci_hcd
[   55.488634] usb 1-9: Device not responding to setup address.
[   60.498436] usb 1-9: Device not responding to setup address.
[   60.705548] usb 1-9: device not accepting address 6, error -71
[   60.898717] usb 1-9: new high-speed USB device number 7 using xhci_hcd
[   65.698764] usb 1-9: Device not responding to setup address.
[   70.708552] usb 1-9: Device not responding to setup address.
[   70.918992] usb 1-9: device not accepting address 7, error -71
[   70.922364] usb usb1-port9: unable to enumerate USB device
[   70.998954] usb 1-4.2: new full-speed USB device number 8 using xhci_hcd
[   71.310045] usb 1-4.2: New USB device found, idVendor=1038, idProduct=1614, bcdDevice= 4.01
[   71.310051] usb 1-4.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   71.310052] usb 1-4.2: Product: SteelSeries Apex Pro TKL
[   71.310054] usb 1-4.2: Manufacturer: SteelSeries
[   71.357577] input: SteelSeries SteelSeries Apex Pro TKL as /devices/pci0000:00/0000:00:02.1/0000:05:00.0/0000:06:08.0/0000:08:00.0/0000:09:0c.0/0000:10:00.0/usb1/1-4/1-4.2/1-4.2:1.0/0003:1038:1614.0006/input/input15
[   71.412531] hid-generic 0003:1038:1614.0006: input,hidraw5: USB HID v1.11 Keyboard [SteelSeries SteelSeries Apex Pro TKL] on usb-0000:10:00.0-4.2/input0
[   71.422573] hid-generic 0003:1038:1614.0007: hiddev98,hidraw6: USB HID v1.11 Device [SteelSeries SteelSeries Apex Pro TKL] on usb-0000:10:00.0-4.2/input1
[   71.432230] input: SteelSeries SteelSeries Apex Pro TKL as /devices/pci0000:00/0000:00:02.1/0000:05:00.0/0000:06:08.0/0000:08:00.0/0000:09:0c.0/0000:10:00.0/usb1/1-4/1-4.2/1-4.2:1.2/0003:1038:1614.0008/input/input16
[   71.489196] hid-generic 0003:1038:1614.0008: input,hidraw7: USB HID v1.11 Keyboard [SteelSeries SteelSeries Apex Pro TKL] on usb-0000:10:00.0-4.2/input2
[   71.501319] input: SteelSeries SteelSeries Apex Pro TKL Consumer Control as /devices/pci0000:00/0000:00:02.1/0000:05:00.0/0000:06:08.0/0000:08:00.0/0000:09:0c.0/0000:10:00.0/usb1/1-4/1-4.2/1-4.2:1.3/0003:1038:1614.0009/input/input17
[   71.555772] input: SteelSeries SteelSeries Apex Pro TKL Mouse as /devices/pci0000:00/0000:00:02.1/0000:05:00.0/0000:06:08.0/0000:08:00.0/0000:09:0c.0/0000:10:00.0/usb1/1-4/1-4.2/1-4.2:1.3/0003:1038:1614.0009/input/input18
[   71.555824] hid-generic 0003:1038:1614.0009: input,hidraw8: USB HID v1.11 Mouse [SteelSeries SteelSeries Apex Pro TKL] on usb-0000:10:00.0-4.2/input3
[   71.565319] hid-generic 0003:1038:1614.000A: hiddev99,hidraw9: USB HID v1.11 Device [SteelSeries SteelSeries Apex Pro TKL] on usb-0000:10:00.0-4.2/input4
[   71.648981] usb 1-4.3: new high-speed USB device number 9 using xhci_hcd
[   71.785049] usb 1-4.3: New USB device found, idVendor=0bda, idProduct=5411, bcdDevice= 1.39
[   71.785054] usb 1-4.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   71.785056] usb 1-4.3: Product: USB2.1 Hub
[   71.785058] usb 1-4.3: Manufacturer: Generic
[   71.908988] usb 1-4.4: new high-speed USB device number 10 using xhci_hcd
[   72.035052] usb 1-4.4: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=60.52
[   72.035057] usb 1-4.4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[   72.035059] usb 1-4.4: Product: USB2.0 Hub
[   72.115531] audit: type=1131 audit(1675149647.432:143): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=ipp-usb comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   72.138877] usb 1-4.3.3: new high-speed USB device number 11 using xhci_hcd
[   72.284003] usb 1-4.3.3: New USB device found, idVendor=0bda, idProduct=1100, bcdDevice= 1.01
[   72.284007] usb 1-4.3.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   72.284009] usb 1-4.3.3: Product: HID Device
[   72.284010] usb 1-4.3.3: Manufacturer: Realtek
[   72.302135] hid-generic 0003:0BDA:1100.000B: hiddev100,hidraw10: USB HID v1.11 Device [Realtek HID Device] on usb-0000:10:00.0-4.3.3/input0
[   72.388987] usb 1-4.4.2: new full-speed USB device number 12 using xhci_hcd
[   72.613448] usb 1-4.4.2: New USB device found, idVendor=042e, idProduct=ac0a, bcdDevice= 2.08
[   72.613454] usb 1-4.4.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[   72.613455] usb 1-4.4.2: Product: Sensor Hub
[   72.613456] usb 1-4.4.2: Manufacturer: Acer Inc.
[   72.613457] usb 1-4.4.2: SerialNumber: 8FF949010000000
[   72.646514] hid-generic 0003:042E:AC0A.000C: hiddev101,hidraw11: USB HID v1.11 Device [Acer Inc. Sensor Hub] on usb-0000:10:00.0-4.4.2/input0
Among others I've spotted this today update:
[2023-01-31T11:14:12+0000] [ALPM] upgraded libgusb (0.4.3-1 -> 0.4.4-1)
Updating your system might help.
Generally, the "device descriptor read/64, error -110" means that USB port power supply was exceeded.
It is possible that your boot time is taking longer because the system is trying to identify/probe your USB devices.
It is possible a kernel update has caused a regression. Test out alternate kernels to see if the issue resolves.
Just did that. No change.
Tried the same with linux-lts. No change.
I read that on the internet too. However, as the whole USB setup is working fine both in BIOS & GRUB I am confused why it should not be working afterwards. Additionally, the problem wasn’t there when I originally installed the system a month ago, But for the love of it I don’t know what changed since then…
Be sure to test the linux-mainline kernel as well. Any update that involves the USB subsystem could potentially cause problems. The kernel is often a cause of breakages when new changes are implemented. Testing out alternate kernels is basically standard procedure whenever a new problem rears its head.
You could try downgrading libgusb as a test to see if that change is responsible.
