Kernel: 5.19.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
root=UUID=d84d1289-1918-4cb8-b260-dc86d66875da rw rootflags=subvol=@
loglevel=3 ibt=off
Type: Desktop System: Micro-Star product: MS-7A38 v: 2.0
Mobo: Micro-Star model: B350M PRO-VDH (MS-7A38) v: 2.0
serial: <superuser required> UEFI: American Megatrends v: A.E0
date: 09/21/2018
Info: model: AMD Ryzen 5 1400 bits: 64 type: MT MCP arch: Zen
built: 2017-19 process: GF 14nm family: 0x17 (23) model-id: 1 stepping: 1
microcode: 0x8001137
L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 3078 high: 3379 min/max: N/A cores: 1: 2722 2: 2805
3: 3309 4: 2956 5: 3110 6: 3240 7: 3103 8: 3379 bogomips: 54398
Device-1: NVIDIA GP106 [GeForce GTX 1060 3GB] vendor: eVga.com.
driver: nvidia v: 515.65.01 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-07) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 1f:00.0 chip-ID: 10de:1c02 class-ID: 0300
compositor: kwin_x11 driver: X: loaded: nvidia
s-diag: 610mm (24")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 92
OpenGL: renderer: NVIDIA GeForce GTX 1060 3GB/PCIe/SSE2 v: 4.6.0 NVIDIA
515.65.01 direct render: Yes
Device-1: NVIDIA GP106 High Definition Audio vendor: eVga.com.
driver: snd_hda_intel bus-ID: 3-3.1.3:19 v: kernel pcie: chip-ID: 1532:0521
gen: 3 class-ID: 0300 speed: 8 GT/s serial: <filter> lanes: 16
bus-ID: 1f:00.1 chip-ID: 10de:10f1 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
bus-ID: 21:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: Razer USA Kraken Kitty Edition type: USB
Sound Server-1: ALSA v: k5.19.1-zen1-1-zen running: yes
lanes: 1 port: f000 bus-ID: 1b:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp27s0 state: down mac: <filter>
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 1d:00.0 chip-ID: 8086:24f3 class-ID: 0280
IF: wlp29s0 state: up mac: <filter>
Local Storage: total: 1.02 TiB used: 863.53 GiB (82.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Silicon Power model: SPCC Solid State
Disk size: 111.79 GiB block-size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 21.1 scheme: GPT
model: WD10EZEX-08WN4A0 size: 931.51 GiB block-size: physical: 4096 B
rev: 1A01 scheme: GPT
ID-1: / raw-size: 111.49 GiB size: 111.49 GiB (100.00%) used: 58.99 GiB
(52.9%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 576 KiB
ID-3: /home raw-size: 111.49 GiB size: 111.49 GiB (100.00%) used: 58.99
GiB (52.9%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-4: /var/log raw-size: 111.49 GiB size: 111.49 GiB (100.00%) used: 58.99
ID-5: /var/tmp raw-size: 111.49 GiB size: 111.49 GiB (100.00%) used: 58.99
ID-1: swap-1 type: zram size: 15.57 GiB used: 259.8 MiB (1.6%)
System Temperatures: cpu: 41.0 C mobo: 43.5 C
Fan Speeds (RPM): fan-1: 0 fan-2: 1931 fan-3: 1231 fan-4: 864 fan-5: 0
Power: 12v: N/A 5v: N/A 3.3v: 3.39 vbat: 3.25
Processes: 320 Uptime: 2h 2m wakeups: 0 Memory: 15.57 GiB used: 6.24 GiB
(40.1%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.1.1 clang: 14.0.6 Packages: pacman: 2129 lib: 641
Shell: fish v: 3.5.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.20
Garuda (2.6.6-1):
System install date: 2022-08-05
Last full system update: 2022-08-16
Hello, I have a USB Headset (Razer Kraken), and it often will suddenly disconnect and sometimes reconnect all by itself. The issue only happens when there is something being outputted to the device. I really have no clue what I'm doing so if I could get some help that would be great because sometimes the headset is just completely unuseable. Here is the output from running dmesg when the headset disconnects (nothing of relevance came before). Thank you for your help and I hope this is under the right topic.
[ 7028.746077] usb 3-3.1.3: USB disconnect, device number 17
[ 7030.457742] usb 3-3.1.3: new full-speed USB device number 18 using xhci_hcd
[ 7030.753529] usb 3-3.1.3: New USB device found, idVendor=1532, idProduct=0521, bcdDevice= 0.70
[ 7030.753535] usb 3-3.1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 7030.753537] usb 3-3.1.3: Product: Razer Kraken Kitty Edition
[ 7030.753539] usb 3-3.1.3: Manufacturer: Razer
[ 7030.753540] usb 3-3.1.3: SerialNumber: 00000000
[ 7031.095005] input: Razer Razer Kraken Kitty Edition Consumer Control as /devices/pci0000:00/0000:00:07.1/0000:20
:00.3/usb3/3-3/3-3.1/3-3.1.3/3-3.1.3:1.3/0003:1532:0521.0014/input/input48
[ 7031.146865] input: Razer Razer Kraken Kitty Edition as /devices/pci0000:00/0000:00:07.1/0000:20:00.3/usb3/3-3/3-
3.1/3-3.1.3/3-3.1.3:1.3/0003:1532:0521.0014/input/input49
[ 7031.147055] hid-generic 0003:1532:0521.0014: input,hiddev98,hidraw8: USB HID v1.11 Device [Razer Razer Kraken Ki
tty Edition] on usb-0000:20:00.3-3.1.3/input3
[ 7031.464615] usb 3-3.1.3: 1:1: cannot get freq at ep 0x81
[ 7031.560751] usb 3-3.1.3: 2:1: cannot get freq at ep 0x1
[ 7031.592617] usb 3-3.1.3: 1:1: cannot get freq at ep 0x81
[ 7055.848367] kauditd_printk_skb: 44 callbacks suppressed
[ 7055.848369] audit: type=1101 audit(1660702449.531:278): pid=27071 uid=1000 auid=1000 ses=2 msg='op=PAM:accountin
g grantors=pam_unix,pam_permit,pam_time acct="marceline" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0
res=success'
[ 7055.848486] audit: type=1110 audit(1660702449.531:279): pid=27071 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred g
rantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/de
v/pts/0 res=success'
[ 7055.850106] audit: type=1105 audit(1660702449.532:280): pid=27071 uid=1000 auid=1000 ses=2 msg='op=PAM:session_o
pen grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? term
inal=/dev/pts/0 res=success'
[ 7102.730371] usb 3-3.1.3: USB disconnect, device number 18
[ 7104.439463] usb 3-3.1.3: new full-speed USB device number 19 using xhci_hcd
[ 7104.735495] usb 3-3.1.3: New USB device found, idVendor=1532, idProduct=0521, bcdDevice= 0.70
[ 7104.735501] usb 3-3.1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 7104.735503] usb 3-3.1.3: Product: Razer Kraken Kitty Edition
[ 7104.735505] usb 3-3.1.3: Manufacturer: Razer
[ 7104.735506] usb 3-3.1.3: SerialNumber: 00000000
[ 7105.078729] input: Razer Razer Kraken Kitty Edition Consumer Control as /devices/pci0000:00/0000:00:07.1/0000:20
:00.3/usb3/3-3/3-3.1/3-3.1.3/3-3.1.3:1.3/0003:1532:0521.0015/input/input50
[ 7105.130337] input: Razer Razer Kraken Kitty Edition as /devices/pci0000:00/0000:00:07.1/0000:20:00.3/usb3/3-3/3-
3.1/3-3.1.3/3-3.1.3:1.3/0003:1532:0521.0015/input/input51
[ 7105.130469] hid-generic 0003:1532:0521.0015: input,hiddev98,hidraw8: USB HID v1.11 Device [Razer Razer Kraken Ki
[ 7105.544741] usb 3-3.1.3: 2:1: cannot get freq at ep 0x1
[ 7105.736783] usb 3-3.1.3: 2:1: cannot get freq at ep 0x1
[ 7105.928783] usb 3-3.1.3: 2:1: cannot get freq at ep 0x1
