Hello Garuda users and experts.
I have installed Windows 11 in VM VirtualBox. Windows is unable to detect my phone but its able to detect external HDD when i plug in via USB.
I have added the device from the VM Settings > USB but still not working.
I have seen an option serial ports, but don't know how to configure it.
Actually i am trying to connect my device (OnePlus 9) to install stock firmware via MSM DownloadTool. Neither its detecting in ADB nor in Fastboot.
Any help would be highly appreciated. Please help me. Thank you
My Device inxi here:
LANGUAGE = "",
LC_ALL = (unset),
LC_ADDRESS = "en_IN",
LC_NAME = "en_IN",
LC_MONETARY = "en_IN",
LC_PAPER = "en_IN",
LC_IDENTIFICATION = "en_IN",
LC_TELEPHONE = "en_IN",
LC_MEASUREMENT = "en_IN",
LC_TIME = "hi_IN.UTF-8",
LC_NUMERIC = "en_IN",
LANG = "en_IN"
perl: warning: Falling back to a fallback locale ("en_IN").
Kernel: 6.2.11-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=319bf36d-d750-42a7-be05-83119ebc8b12 rw rootflags=subvol=@
loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.9 wm: kwin_x11 dm: SDDM
Type: Laptop System: HP product: Victus by HP Laptop 16-d0xxx v: N/A
Mobo: HP model: 88F9 v: 88.57 serial: <filter> UEFI: AMI v: F.22
date: 11/28/2022
ID-1: BAT0 charge: 52.9 Wh (93.0%) condition: 56.9/70.1 Wh (81.2%)
volts: 17.1 min: 15.4 model: HP Primary type: Li-ion serial: <filter>
status: charging cycles: 72
Info: model: 11th Gen Intel Core i7-11800H socket: U3E1 bits: 64
type: MT MCP arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
microcode: 0x42
L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 2279 high: 4308 min/max: 800/4600 base/boost: 2178/5000
ext-clock: 100 MHz cores: 1: 1066 2: 4164 3: 800 4: 800 5: 801 6: 1321
7: 3003 8: 4126 9: 1741 10: 1578 11: 862 12: 2923 13: 2905 14: 2300
15: 3775 16: 4308 bogomips: 73728
Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Hewlett-Packard
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: eDP-1 empty: DP-1 bus-ID: 0000:00:02.0 chip-ID: 8086:9a60
Device-2: NVIDIA GA107M [GeForce RTX 3050 Ti Mobile]
vendor: Hewlett-Packard driver: nouveau v: kernel non-free: 530.xx+
status: current (as of 2023-03) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 ports: active: none empty: HDMI-A-1
bus-ID: 0000:01:00.0 chip-ID: 10de:25a0 class-ID: 0300
Device-3: Chicony HP Wide Vision HD Camera type: USB driver: N/A
bus-ID: 3-6:2 chip-ID: 04f2:b735 class-ID: fe01 serial: <filter>
compositor: kwin_x11 driver: X: loaded: modesetting,nouveau
alternate: fbdev,intel,nv,vesa dri: iris,nouveau gpu: i915 display-ID: :0
Monitor-1: eDP-1 model: BOE Display 0x0aad built: 2021 res: 1920x1080
hz: 144 dpi: 137 gamma: 1.2 size: 355x200mm (13.98x7.87") diag: 407mm (16")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.0.2 renderer: Mesa Intel UHD Graphics (TGL GT1)
direct-render: Yes
Device-1: Intel Tiger Lake-H HD Audio vendor: Hewlett-Packard
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
chip-ID: 8086:43c8 class-ID: 0401
Device-2: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus-ID: 0000:01:00.1 chip-ID: 10de:2291 class-ID: 0403
API: ALSA v: k6.2.11-zen1-1-zen status: kernel-api with: aoss
type: oss-emulator tools: alsamixer,amixer
Server-1: PipeWire v: 0.3.69 status: n/a (root, process) with:
bus-ID: 0000:00:14.3 chip-ID: 8086:43f0 class-ID: 0280
vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000
bus-ID: 0000:02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-1: Intel AX201 Bluetooth type: USB driver: usbfs bus-ID: 3-14:26
chip-ID: 8087:0026 class-ID: e001
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 476.94 GiB used: 129.08 GiB (27.1%)
model: MTFDKBA512TFH-1BC1AABHA size: 476.94 GiB block-size: physical: 512 B
rev: HPS0043 temp: 55.9 C scheme: GPT
SMART: yes health: PASSED on: 7d 20h cycles: 1,046
read-units: 9,013,439 [4.61 TB] written-units: 12,957,269 [6.63 TB]
used: 129.08 GiB (27.1%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
used: 576 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
maj-min: 259:2
maj-min: 259:2
maj-min: 259:2
ID-1: swap-1 type: zram size: 15.26 GiB used: 1.51 GiB (9.9%)
System Temperatures: cpu: N/A mobo: N/A
Fan Speeds (RPM): cpu: 2886 fan-2: 3084
Processes: 407 Uptime: 1d 15h 3m wakeups: 50199 Memory: 15.26 GiB
used: 10.13 GiB (66.4%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: 1827
pm: pacman pkgs: 1812 libs: 522 tools: octopi,paru pm: flatpak pkgs: 15
inxi: 3.3.26
System install date: 2023-04-10
Last full system update: 2023-04-19 ↻
Is partially upgraded: Yes
Failed units: anbox-container-manager.service nmb.service systemd-networkd-wait-online.service
