USB C HDMI to TV
Hi. Can anyone help me? I have shitty laptop but garuda works very good on it. Specs: Intel celeron j4125, 16 gb ram, intel uhd 600, 512 gb ssd. My problem is when i connect this laptop to tv with usb c hdmi cable bcs laptop dont have hdmi port resolution is only from 640x480 to 1024x768. My tv is full hd. Now i use windows bcs everything is work but i want garuda (i am not new in this distro). How to set full hd resolution? I can test on usb live and sorry for my english .
Kernel: 6.8.7-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
misobasedir=garuda root=miso:LABEL=GARUDA_DR460NIZEDGAMING_BIRDOFPR quiet
systemd.show_status=1 checksum=y driver=free nouveau.modeset=1
Type: Laptop System: CHUWI�Innovation�And�(ShenZhen) product: GemiBook Pro
v: N/A serial: <superuser required>
Mobo: N/A model: N/A serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends
v: JXX-BI-14.1-W133GWR200-035-D date: 09/30/2020
ID-1: BAT0 charge: 38.0 Wh (100.0%) condition: 38.0/N/A Wh volts: 7.6
min: N/A model: N/A type: Unknown serial: <filter> status: charging
Info: model: Intel Celeron J4125 bits: 64 type: MCP arch: Goldmont Plus
level: v2 built: 2017 process: Intel 14nm family: 6 model-id: 0x7A (122)
stepping: 8 microcode: 0xC
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 224 KiB
desc: d-4x24 KiB; i-4x32 KiB L2: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 2622 high: 2700 min/max: 800/2700 scaling:
driver: intel_cpufreq governor: performance cores: 1: 2596 2: 2596 3: 2596
4: 2700 bogomips: 15974
Device-1: Intel GeminiLake [UHD Graphics 600] driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: DP-1,eDP-1
empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:3185 class-ID: 0300
Device-2: Microdia Webcam Vitade AF driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:5 chip-ID: 0c45:6366
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 23.2.6
Screen-1: 0 s-res: 2800x1440 s-dpi: 96 s-size: 740x381mm (29.13x15.00")
s-diag: 832mm (32.77")
Monitor-1: DP-1 pos: right res: 640x480 hz: 60 size: N/A modes:
max: 640x480 min: 848x480
Monitor-2: eDP-1 pos: primary,left model: ChiMei InnoLux P140ZKA-BZ1
built: 2018 res: 2160x1440 hz: 60 dpi: 185 gamma: 1.2
size: 296x197mm (11.65x7.76") diag: 356mm (14") ratio: 3:2
modes: 2160x1440
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.5-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 600 (GLK 2)
device-ID: 8086:3185 memory: 15.07 GiB unified: yes
API: Vulkan v: 1.3.279 layers: 9 device: 0 type: integrated-gpu name: Intel
UHD Graphics 600 (GLK 2) driver: mesa intel v: 24.0.5-arch1.1
device-ID: 8086:3185 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 17.0.6 128 bits) driver: mesa llvmpipe v: 24.0.5-arch1.1 (LLVM
Device-1: Intel Celeron/Pentium Silver Processor High Definition Audio
driver: snd_hda_intel v: kernel alternate: snd_soc_skl, snd_soc_avs,
snd_sof_pci_intel_apl bus-ID: 00:0e.0 chip-ID: 8086:3198 class-ID: 0403
API: ALSA v: k6.8.7-zen1-2-zen status: kernel-api with: aoss
speed: 5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp1s0 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:4 chip-ID: 8087:0029
Local Storage: total: 505.61 GiB used: 0 KiB (0.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Gateway model: W800S 512GB SSD
tech: SSD serial: <filter> fw-rev: 2A0 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: SanDisk model: Cruzer Blade
size: 28.67 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: 1.00 scheme: MBR
ID-1: swap-1 type: zram size: 15.43 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 50.0 C mobo: N/A
Memory: total: 16 GiB available: 15.44 GiB used: 2.46 GiB (16.0%)
Processes: 210 Power: uptime: 6m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.14 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1846 libs: 539 tools: octopi,paru Compilers:
clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.1
System install date:     2025-01-16
Last full system update: 2025-01-16 ↻
Looks like you need a reboot.
You can try installing the LTS keernel and see if that makes a difference
Welcome
I installed and updated it before, but now I have Windows and I can play with live USB. Will kernel lts help?
It more stable and less cutting edge, but not sure which kernel it will load on the live iso
With lts is the same, dp1 is 640x480 and highest is 1024x768
A quick internet search and a look at the Chuwi forum confirms this:
In addition, the hardware is designed exclusively for Windows, and even there there are tons of issues.
Linux is not Windows :slightly_smiling_face:
The laptop should have different settings for the USB-C port in the BIOS, have you tried this?
Otherwise I would recommend booting different live distributions (e.g. Fedora/Debian/Ubuntu) to check whether the same problem occurs.
On fedora, chrome os flex and fyde os its the same problem. Unknown display and low resolution. Dont want but i stay on windows.
Then the cause is definitely the Microsoft specification for hardware and firmware.
“Good luck” :wink:
