USB Audio Codec Microphone Volume Too Low
I have an ANT Usb Dual Pre as pre-amp for input and output. I could get the microphone to work, but the volume is WAY too low. I also tested it on Windows and it works fine there.
One strange thing. When I click on Audio icon, on the device, the "additional options" button.
If it's set to "Analog Stereo Duplex", then the output works but not the input.
If it's set to "Digital Stereo Duplex (UEC958)", then the input works (low volume) but not the output.
If it's set to "Analog Stereo Duplex + Digital Stereo Duplex (UEC958)", then the input works (low volume) but trying to output YouTube video jams the playback.
So... there's definitely a microphone volume problem, but there's also a deeper problem. Is it simply unsupported hardware? Any solution?
Kernel: 5.16.4-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=58203bda-e2e2-4c32-a006-c91d933cad4e rw rootflags=subvol=@
systemd.unified_cgroup_hierarchy=1 loglevel=3 intel_iommu=on
Type: Laptop System: Acer product: Predator PH315-53 v: V1.01
Mobo: CML model: QX50_CMS v: V1.01 serial: <superuser required>
UEFI: Insyde v: 1.01 date: 04/27/2020
ID-1: BAT1 charge: 43.8 Wh (100.0%) condition: 43.8/58.8 Wh (74.5%)
volts: 16.3 min: 15.4 model: SMP AP18E7M type: Li-ion serial: <filter>
status: Full
Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
family: 6 model-id: 0xA5 (165) stepping: 2 microcode: 0xEA
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 4537 high: 4769 min/max: 800/5000 scaling:
driver: intel_pstate governor: performance cores: 1: 2720 2: 4700 3: 4622
4: 4755 5: 4611 6: 4710 7: 4751 8: 4749 9: 4769 10: 4652 11: 4755
12: 4659 bogomips: 62399
Device-1: Intel CometLake-H GT2 [UHD Graphics]
vendor: Acer Incorporated ALI driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile]
vendor: Acer Incorporated ALI driver: nvidia v: 495.46
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1f15
Device-3: Quanta HD User Facing type: USB driver: uvcvideo bus-ID: 1-5:3
chip-ID: 0408:a061 class-ID: 0e02
loaded: modesetting,nvidia display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: HDMI-1-0 res: 1920x1080 hz: 60 dpi: 40
size: 1210x680mm (47.6x26.8") diag: 1388mm (54.6")
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.3.5
direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Acer Incorporated ALI
Device-2: NVIDIA TU106 High Definition Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Device-3: Texas Instruments PCM2900B Audio CODEC type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-1.3:9 chip-ID: 08bb:29b0
Sound Server-1: ALSA v: k5.16.4-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.44 running: yes
Device-1: Intel Comet Lake PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
Device-2: Realtek vendor: Acer Incorporated ALI driver: r8169 v: kernel
port: 3000 bus-ID: 07:00.0 chip-ID: 10ec:2600 class-ID: 0200
IF-ID-3: virbr1 state: down mac: <filter>
bus-ID: 1-14:5 chip-ID: 8087:0026 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: down
address: <filter>
Local Storage: total: 1.63 TiB used: 1014.16 GiB (60.9%)
model: PC SN730 SDBQNTY-512G-1014 size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 11101100 temp: 24.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS721010A9E630
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: A3J0
ID-3: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT275MX300SSD4
size: 256.17 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: R060 scheme: GPT
ID-1: / raw-size: 376.95 GiB size: 376.95 GiB (100.00%)
used: 182.36 GiB (48.4%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:2
used: 51.2 MiB (53.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 376.95 GiB size: 376.95 GiB (100.00%)
ID-4: /var/log raw-size: 376.95 GiB size: 376.95 GiB (100.00%)
ID-5: /var/tmp raw-size: 376.95 GiB size: 376.95 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.46 GiB used: 2.2 MiB (0.0%)
System Temperatures: cpu: 62.0 C pch: 62.0 C mobo: N/A
Processes: 363 Uptime: 1h 23m wakeups: 1 Memory: 15.46 GiB
used: 4.39 GiB (28.4%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1734 lib: 493 Shell: fish
Open Pulse Audio volume control, and in configuration, change profile to something like headset unit, if you want to use mic. Also, in input tab, you can check input volume level and adjust it there only. Also refer for more information.
https://wiki.archlinux.org/title/PulseAudio
I hope this solves your issue.
Headset unit isn’t in the profiles list. There’s a mix of Analog, Digital and Surround, and Pro Audio. Volume is 100% of course, and I could also raise maximum volume to 150% but that’s not enough.
See this too
https://wiki.archlinux.org/title/PulseAudio/Troubleshooting
Crazy-long page... luckily I have another pre-amp recorder and that one worked just fine.
Would be nice if things worked better out-of-the box.
This is the only relevant entry on the whole page
### Volume low/too quiet on analog headphones/speakers
If you added the `ignore_dB=1` option earlier to the `load-module module-udev-detect` line in your `/etc/pulse/default.pa`, try removing it.
I could try that when I have the time; trying to get some video done on Linux.
Right, best start fixing this.
