Upgrade problem
hello everyone
i have problem with upgrade my garuda i have same error even i restore past anyway
here this error i seen solution in forum but didnt work on me
╭─iceberg@elysium in ~
╰─λ garuda-update
[sudo] password for iceberg:
:: Paket veritabanları senkronize ediliyor...
garuda güncel
core güncel
extra güncel
multilib güncel
chaotic-aur                             2,6 MiB  3,14 MiB/s 00:01 [------------------------------------] 100%
blackarch güncel
garuda indiriliyor ...
core indiriliyor ...
extra indiriliyor ...
multilib indiriliyor ...
chaotic-aur indiriliyor ...
blackarch indiriliyor ...
resolving dependencies...
:: installing kauth5 (5.111.0-1) breaks dependency 'kauth' required by fancontrol-gui-git
:: installing kconfig5 (5.111.0-1) breaks dependency 'kconfig' required by fancontrol-gui-git
:: installing kcoreaddons5 (5.111.0-1) breaks dependency 'kcoreaddons' required by fancontrol-gui-git
:: installing kdbusaddons5 (5.111.0-1) breaks dependency 'kdbusaddons' required by fancontrol-gui-git
:: installing kdeclarative5 (5.111.0-1) breaks dependency 'kdeclarative' required by fancontrol-gui-git
:: installing ki18n5 (5.111.0-1) breaks dependency 'ki18n' required by fancontrol-gui-git
:: installing knotifications5 (5.111.0-1) breaks dependency 'knotifications' required by fancontrol-gui-git
:: installing kpackage5 (5.111.0-1) breaks dependency 'kpackage' required by fancontrol-gui-git
thank you in time
this should have been placed under the “issues & assistance” topic. and please post your garuda-inxi results. do not fear, it doesn’t have anything like serial numbers or usernames in it.
forum members are currently in the midst of figuring this all out, however as a quick fix you can uninstall fancontrol-gui-git and should be able to update. lots of detail is missing though so please post your garuda-inxi
Use search function, please, before posting.
Kernel: 6.5.7-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=174ac5a6-f31a-4aaa-9b2a-c8791c8d3444 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
Mobo: ASUSTeK model: ROG STRIX Z790-F GAMING WIFI v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 1303
date: 08/02/2023
Info: model: 13th Gen Intel Core i9-13900K bits: 64 type: MST AMCP
microcode: 0x119
Topology: cpus: 1x cores: 24 mt: 8 tpc: 2 st: 16 threads: 32 smt: enabled
cache: L1: 2.1 MiB desc: d-16x32 KiB, 8x48 KiB; i-8x32 KiB, 16x64 KiB
L2: 32 MiB desc: 8x2 MiB, 4x4 MiB L3: 36 MiB desc: 1x36 MiB
Speed (MHz): avg: 809 high: 1100 min/max: 800/5800:5500:4300 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 1100 4: 800
5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800
15: 800 16: 800 17: 800 18: 800 19: 800 20: 800 21: 800 22: 800 23: 800
24: 800 25: 800 26: 800 27: 800 28: 800 29: 800 30: 800 31: 800 32: 800
bogomips: 191692
vendor: Tul / PowerColor driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
process: TSMC n7 (7nm) built: 2020-22 ports: active: HDMI-A-1
empty: DP-1,DP-2,DP-3 bus-ID: 0000:03:00.0 chip-ID: 1002:73df
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 506x285mm (19.92x11.22")
s-diag: 581mm (22.86")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: LG (GoldStar) ULTRAWIDE
serial: <filter> built: 2016 res: 1920x1080 hz: 60 dpi: 61 gamma: 1.2
size: 798x334mm (31.42x13.15") diag: 869mm (34.2") modes: max: 2560x1080
min: 720x400
inactive: gbm,wayland
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6700 XT (navi22 LLVM
16.0.6 DRM 3.54 6.5.7-zen2-1-zen) device-ID: 1002:73df memory: 11.72 GiB
unified: no
API: Vulkan v: 1.3.264 layers: 13 device: 0 type: discrete-gpu name: AMD
Radeon RX 6700 XT (RADV NAVI22) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:73df surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
Device-1: Intel vendor: ASUSTeK driver: snd_hda_intel v: kernel
alternate: snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3 chip-ID: 8086:7a50
bus-ID: 0000:03:00.1 chip-ID: 1002:ab28 class-ID: 0403
Device-3: Audient EVO4 driver: snd-usb-audio type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-10.1:6 chip-ID: 2708:0006
class-ID: fe01
Device-4: ASUSTek USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:2
API: ALSA v: k6.5.7-zen2-1-zen status: kernel-api with: aoss
Device-1: Intel driver: iwlwifi v: kernel port: N/A bus-ID: 0000:00:14.3
chip-ID: 8086:7a70 class-ID: 0280
IF: wlp0s20f3 state: down mac: <filter>
Device-2: Intel Ethernet I226-V vendor: ASUSTeK driver: igc v: kernel
port: N/A bus-ID: 0000:07:00.0 chip-ID: 8086:125c class-ID: 0200
IF: eno2 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Intel driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-14:10 chip-ID: 8087:0033 class-ID: e001
lmp-v: 12 status: discoverable: no pairing: no class-ID: 7c0104
Hardware-1: Intel Volume Management Device NVMe RAID Controller Intel
driver: vmd v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:a77f rev:
class-ID: 0104
Local Storage: total: 9.1 TiB used: 141.91 GiB (1.5%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Western Digital
model: WDS100T1X0E-00AFY0 size: 931.51 GiB block-size: physical: 512 B
fw-rev: 614900WD temp: 38.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 40.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000NM006A-2HZ110
size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: TS02 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST4000NM006A-2HZ110
used: 141.89 GiB (15.2%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:2
used: 27.1 MiB (9.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1
ID-1: swap-1 type: zram size: 31.09 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 32 dev: /dev/zram0
System Temperatures: cpu: 35.0 C mobo: N/A gpu: amdgpu temp: 45.0 C
mem: 42.0 C
Processes: 518 Uptime: 1h 44m wakeups: 0 Memory: total: 32 GiB note: est.
available: 31.09 GiB used: 3.05 GiB (9.8%) Init: systemd v: 254
Packages: pm: pacman pkgs: 2185 libs: 594 tools: octopi,paru pm: flatpak
pkgs: 0 Shell: fish v: 3.6.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.30
Garuda (2.6.17-1):
System install date:     2023-09-28
Last full system update: 2023-10-20
ok i used but some fix method didnt work on me i tried blackarch tools install then start this problem
Most of the time it works if you not use the -git version.
Remove the -git like @Javabean wrote.
Or just wait a little. :slight_smile:
thank you for helping me
The package has been updated in the AUR now, so Chaotic-AUR should have it soon. If not, post in the Chaotic-AUR thread for a rebuild :slight_smile:
thank you for information
