I have this problem for the last two days how can I fix it
garuda-update
:: Synkroniserer pakkedatabaser...
garuda is up to date
core is up to date
extra 8,2 MiB 36,0 MiB/s 00:00 [----------------------] 100%
multilib is up to date
chaotic-aur 2,6 MiB 5,34 MiB/s 00:00 [----------------------] 100%
garuda downloading...
core downloading...
extra downloading...
multilib downloading...
chaotic-aur downloading...
resolving dependencies...
:: installing kvantum (1.0.10-2) breaks dependency 'kvantum-qt5' required by garuda-mate-settings
Kernel: 6.5.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=ff14df11-1857-4590-8e3d-20efe22b14f4 rw rootflags=subvol=@
mitigations=off quiet quiet rd.udev.log_priority=3
vt.global_cursor_default=0 loglevel=3 ibt=off
Desktop: MATE v: 1.26.1 info: mate-panel wm: marco v: 1.26.2 vt: 7
dm: LightDM v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Desktop Mobo: Gigabyte model: B660M DS3H DDR4 v: x.x
serial: <superuser required> UEFI: American Megatrends LLC. v: F20
date: 10/25/2022
Info: model: 12th Gen Intel Core i7-12700 bits: 64 type: MST AMCP
microcode: 0x2E
Topology: cpus: 1x cores: 12 mt: 8 tpc: 2 st: 4 threads: 20 smt: enabled
cache: L1: 1024 KiB desc: d-4x32 KiB, 8x48 KiB; i-8x32 KiB, 4x64 KiB
L2: 12 MiB desc: 8x1.2 MiB, 1x2 MiB L3: 25 MiB desc: 1x25 MiB
Speed (MHz): avg: 888 high: 2569 min/max: 800/4800:4900:3600 scaling:
driver: intel_pstate governor: performance cores: 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 2569 11: 800 12: 800 13: 800
14: 800 15: 800 16: 800 17: 800 18: 800 19: 800 20: 800 bogomips: 84480
Device-1: Intel AlderLake-S GT1 vendor: Gigabyte driver: i915 v: kernel
ports: active: HDMI-A-3 empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:4680 class-ID: 0300
Display: x11 server: X.Org v: 21.1.8 compositor: marco v: 1.26.2 driver:
X: loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915
display-ID: :0.0 screens: 1
Monitor-1: HDMI-A-3 mapped: HDMI-3 model: ASUS VP248 serial: <filter>
built: 2019 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.2.1-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 770 (ADL-S
GT1) device-ID: 8086:4680 memory: 122.63 GiB unified: yes
API: Vulkan v: 1.3.264 layers: 3 device: 0 type: integrated-gpu name: Intel
UHD Graphics 770 (ADL-S GT1) driver: mesa intel v: 23.2.1-arch1.1
device-ID: 8086:4680 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 23.2.1-arch1.1 (LLVM
API: ALSA v: k6.5.5-zen1-1-zen status: kernel-api tools: N/A
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0
Local Storage: total: 2.73 TiB used: 321.46 GiB (11.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNV2S1000G
lanes: 4 tech: SSD serial: <filter> fw-rev: SBJ00101 temp: 31.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2UB102
used: 321.46 GiB (34.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 125.57 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 20 dev: /dev/zram0
System Temperatures: cpu: 36.0 C mobo: 28.0 C
Processes: 373 Uptime: 8m wakeups: 0 Memory: total: 128 GiB note: est.
available: 125.57 GiB used: 4.64 GiB (3.7%) Init: systemd v: 254
Packages: pm: pacman pkgs: 2041 libs: 462 tools: octopi,pamac,paru
Shell: Bash v: 5.1.16 running-in: terminator inxi: 3.3.30
System install date: 2023-01-31
Last full system update: 2023-10-01
