Trying to do update as well as garuda-update today on my Garuda Cinnamon DE brought up a conflict about missing or unresolvable dependencies.
warning: cannot resolve "lib32-opencl-mesa", a dependency of "garuda-video-linux-config"
:: The following package cannot be upgraded due to unresolvable dependencies:
Any idea how to resolve it?
Here my garuda-inxi :
root=UUID=ba4d191b-711a-44a7-bf2c-90744ec25f0d rw rootflags=subvol=@
Desktop: Cinnamon v: 5.8.4 tk: GTK v: 3.24.38 info: plank wm: muffin vt: 7
dm: LightDM v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Desktop Mobo: Gigabyte model: X570S UD serial: <superuser required>
UEFI: American Megatrends LLC. v: F4d date: 07/20/2022
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 2289 high: 3600 min/max: 2200/4850 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2196 2: 2200
3: 2200 4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 3600 10: 2200 11: 2200
12: 2200 13: 2200 14: 2200 15: 2240 16: 2200 bogomips: 121601
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] vendor: ASRock
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-1
empty: DP-2,DP-3,HDMI-A-1 bus-ID: 0c:00.0 chip-ID: 1002:73bf
Display: x11 server: X.Org v: 21.1.9 driver: X: loaded: amdgpu
unloaded: modesetting,radeon alternate: fbdev,vesa dri: radeonsi gpu: amdgpu
Screen-1: 0 s-res: 3440x1440 s-dpi: 96 s-size: 910x381mm (35.83x15.00")
s-diag: 987mm (38.84")
Monitor-1: DP-1 mapped: DisplayPort-0 model: AOC U34G3XM serial: <filter>
built: 2023 res: 3440x1440 dpi: 110 gamma: 1.2
size: 797x334mm (31.38x13.15") diag: 864mm (34") modes: max: 3440x1440
min: 720x400
inactive: gbm,wayland
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6800 XT (navi21 LLVM
16.0.6 DRM 3.54 6.5.9-zen2-1-zen) device-ID: 1002:73bf memory: 15.62 GiB
unified: no
API: Vulkan v: 1.3.269 layers: 7 device: 0 type: discrete-gpu name: AMD
Radeon RX 6800 XT (RADV NAVI21) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:73bf surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
Device-1: C-Media CMI8788 [Oxygen HD Audio] vendor: ASUSTeK Virtuoso 200
driver: snd_virtuoso v: kernel bus-ID: 06:04.0 chip-ID: 13f6:8788
class-ID: 0401
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0c:00.1 chip-ID: 1002:ab28
Device-3: AMD Starship/Matisse HD Audio vendor: Gigabyte
bus-ID: 0e:00.4 chip-ID: 1022:1487 class-ID: 0403
Server-2: PipeWire v: 0.3.84 status: active with: 1: pipewire-pulse
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 04:00.0
IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 6.13 TiB used: 1.95 TiB (31.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNV2S500G
lanes: 4 tech: SSD serial: <filter> fw-rev: SBI02102 temp: 44.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DX001-1CM162
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC44 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SSD PLUS 240GB
size: 223.58 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 00RL scheme: GPT
model: WD20EARS-00MVWB0 size: 1.82 TiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s tech: N/A serial: <filter> fw-rev: AB51
ID-5: /dev/sdd maj-min: 8:48 vendor: Toshiba model: DT01ACA300
tech: HDD rpm: 7200 serial: <filter> fw-rev: ABB0 scheme: GPT
ID-1: / raw-size: 182.79 GiB size: 182.79 GiB (100.00%)
used: 36.66 GiB (20.1%) fs: btrfs dev: /dev/sdb3 maj-min: 8:19
ID-2: /boot/efi raw-size: 1.25 GiB size: 1.25 GiB (99.80%)
used: 576 KiB (0.0%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 300 GiB size: 300 GiB (100.00%)
used: 45.98 GiB (15.3%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-4: /var/log raw-size: 182.79 GiB size: 182.79 GiB (100.00%)
ID-5: /var/tmp raw-size: 182.79 GiB size: 182.79 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.24 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 39.53 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sdb2 maj-min: 8:18
System Temperatures: cpu: 45.2 C mobo: 30.0 C gpu: amdgpu temp: 39.0 C
mem: 34.0 C
Processes: 450 Uptime: 1h 8m wakeups: 0 Memory: total: 32 GiB
available: 31.24 GiB used: 5.47 GiB (17.5%) Init: systemd v: 254
Packages: pm: pacman pkgs: 2196 libs: 556
tools: octopi,pacaur,pamac,paru,trizen,yay pm: flatpak pkgs: 0 Shell: fish
v: 3.6.1 default: Bash v: 5.2.15 running-in: gnome-terminal inxi: 3.3.31
Garuda (2.6.17-1):
System install date: 2023-07-30
Last full system update: 2023-11-03
Is partially upgraded: Yes
