Kernel: 6.1.56-1-lts arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=53e07a01-a231-4637-a873-763292a95245 rw rootflags=subvol=@
quiet rd.udev.log_priority=3 vt.global_cursor_default=0 loglevel=3
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
Type: Desktop System: Dell product: Inspiron 3670 v: N/A
Mobo: Dell model: 0R6JMP v: A00 serial: <superuser required> UEFI: Dell
v: 2.15.0 date: 02/21/2020
Info: model: Intel Core i5-9400 bits: 64 type: MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xD (13) microcode: 0xFA
desc: 1x9 MiB
Speed (MHz): avg: 3882 high: 3906 min/max: 800/4100 scaling:
driver: intel_pstate governor: performance cores: 1: 3899 2: 3787 3: 3903
4: 3906 5: 3898 6: 3901 bogomips: 34814
Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: Dell
ports: active: DP-1,HDMI-A-1 empty: none bus-ID: 00:02.0
chip-ID: 8086:3e98 class-ID: 0300
Device-2: Microdia Dual Mode Camera (8006 VGA) driver: hid-generic,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9.4:6
chip-ID: 0c45:8006 class-ID: 0301
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.2.1 compositors:
1: kwin_x11 2: Tabby driver: X: loaded: intel unloaded: modesetting
alternate: fbdev,vesa dri: i965 gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 3520x1080 s-dpi: 96 s-size: 928x285mm (36.54x11.22")
s-diag: 971mm (38.22")
Monitor-1: DP-1 mapped: DP1 pos: right model: Dell E2020H serial: <filter>
built: 2020 res: 1600x900 hz: 60 dpi: 95 gamma: 1.2
size: 430x240mm (16.93x9.45") diag: 494mm (19.4") ratio: 16:9 modes:
max: 1600x900 min: 720x400
Monitor-2: HDMI-A-1 mapped: HDMI1 pos: primary,left model: Samsung C24F390
serial: <filter> built: 2020 res: 1920x1080 hz: 60 dpi: 94 gamma: 1.2
size: 520x290mm (20.47x11.42") diag: 598mm (23.5") ratio: 16:9 modes:
inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.2.1-arch1.2
GT2) device-ID: 8086:3e98 memory: 30.43 GiB unified: yes
API: Vulkan v: 1.3.264 layers: 3 device: 0 type: integrated-gpu name: Intel
UHD Graphics 630 (CFL GT2) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:3e98 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
API: ALSA v: k6.1.56-1-lts status: kernel-api tools: N/A
Server-2: PipeWire v: 0.3.81 status: active with: 1: pipewire-pulse
vendor: Dell driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: Dell Vostro 3470 driver: ath9k v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:0036 class-ID: 0280
Device-1: Qualcomm Atheros driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:7 chip-ID: 0cf3:e005
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 4.0
lmp-v: 6 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 1.36 TiB used: 459.66 GiB (32.9%)
model: WDS500G2B0C-00PXH0 size: 465.76 GiB block-size: physical: 512 B
fw-rev: 211070WD temp: 30.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM010-2EP102
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC45 scheme: GPT
used: 155.54 GiB (33.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 31.16 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 6 dev: /dev/zram0
System Temperatures: cpu: 32.0 C pch: 49.0 C mobo: 32.0 C
Fan Speeds (rpm): cpu: 1003
Processes: 284 Uptime: 18d 7h 32m wakeups: 0 Memory: total: 32 GiB
available: 31.16 GiB used: 6.87 GiB (22.0%) Init: systemd v: 254
Packages: pm: dpkg pkgs: 0 pm: pacman pkgs: 2032 libs: 473
tools: octopi,pamac,paru Shell: fish v: 3.6.1 running-in: yakuake
inxi: 3.3.30
Garuda (2.6.17-1):
System install date: 2022-02-10
Last full system update: 2023-10-08
:: Replace kirigami-addons with extra/kirigami-addons5? [Y/n] y
:: Replace libinput_gestures_qt with chaotic-aur/libinput-gestures-qt? [Y/n] y
resolving dependencies...
:: installing kio5 (5.111.0-1) breaks dependency 'kio' required by kipi-plugins
:: installing kxmlgui5 (5.111.0-1) breaks dependency 'kxmlgui' required by libkipi
:: installing kservice5 (5.111.0-1) breaks dependency 'kservice' required by libkipi
:: installing kauth5 (5.111.0-1) breaks dependency 'kauth' required by samba-mounter-git
:: installing kcmutils5 (5.111.0-1) breaks dependency 'kcmutils' required by samba-mounter-git
:: installing kconfig5 (5.111.0-1) breaks dependency 'kconfig' required by samba-mounter-git
:: installing kio5 (5.111.0-1) breaks dependency 'kio' required by samba-mounter-git
:: installing ki18n5 (5.111.0-1) breaks dependency 'ki18n' required by samba-mounter-git
:: installing solid5 (5.111.0-1) breaks dependency 'solid' required by samba-mounter-git
find-the-command: "/usr/bin/mcfly" is not found locally, searching in repositories...
find-the-command: /var/cache/pkgfile/*.files are out of date, update? [Y/n]
filo
27 October 2023 07:09
2
Due to the Arch activities for KDE described in this announcement, some AUR package maintainers havenât adjusted their packages yet accordingly:
Hello everyone
Some of you have already discovered that there are a few changes in the Arch repository, possibly breaking some package dependencies. So whatâs going on here?
KDE 6 is going to be released next year, which moves the entire desktop from Qt5 to Qt6. In order to prepare the upgrade, Archlinux alters current packages to have a 5 at the end (reflecting being built against Qt5).
This was recently also applied to KDE frameworks, which a lot of packages of ours and the AUâŚ
The best thing would be to temporarily remove those AUR packages and update (and if a comment has not been left yet to the mainteiner in the AUR, leave a comment there possibly).
You can uninstall samba-mounter-git
, libkipi
, kipi-plugins
I see also a comment about it here, for example:
https://aur.archlinux.org/packages/libkipi#comment-939450
Bro
27 October 2023 20:51
8
I ran into that with a few AUR pkgs a couple days ago. Installing them blindly with a helper using paru & âânoconfirmâ failed at several points.
Building them one-by-one using PKGBUILDs/makepkg worked swell. Or using paru without any conditions worked. Several of my ânormalâ AUR pkgs needed user-intervention, but ALPM did well that way with either process.
