Upgrade AMD Zen Kernel
1st day on Linux so please be gentle.
I’ve been reading around and from what I gather I can somehow upgrade the kernel to better support AMD’s Zen 4 CPU’s ?
Currently in the terminal window it says I’m running a Zen 1 based kernel.
Again I am completely new to this and would really appreciate any pointers.
I think you mean Linux 6.9.5-zen1-1-zen. This has nothing to do with the AMD kernels like linux-amd-znver3.
We could help you better if you post your garuda-inxi:
(please paste the output here and format them using the "</>"button)
Welcome to the community :slight_smile:
Thanks for the reply :slight_smile:
Kernel: 6.8.8-AMD arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-amd
root=UUID=0c310529-9d32-487d-bcd5-20f7c39ab0e8 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.3.0
Type: Desktop Mobo: ASRock model: X670E Taichi Carrara
Megatrends LLC. v: 3.01 date: 05/13/2024
Info: model: AMD Ryzen 7 7800X3D bits: 64 type: MT MCP arch: Zen 4 gen: 5
L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 733 high: 3559 min/max: 545/5050 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 545 2: 545 3: 545
4: 545 5: 545 6: 545 7: 545 8: 545 9: 545 10: 545 11: 545 12: 545 13: 545
14: 545 15: 545 16: 3559 bogomips: 134450
Device-1: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX/7900M]
vendor: Sapphire NITRO+ driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x
process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: DP-1 empty: DP-2, HDMI-A-1, HDMI-A-2, Writeback-1
bus-ID: 03:00.0 chip-ID: 1002:744c class-ID: 0300
Device-2: AMD Raphael vendor: ASRock driver: amdgpu v: kernel arch: RDNA-2
speed: 16 GT/s lanes: 16 ports: active: none empty: DP-3, DP-4, DP-5,
HDMI-A-3, Writeback-2 bus-ID: 18:00.0 chip-ID: 1002:164e class-ID: 0300
temp: 38.0 C
gpu: amdgpu,amdgpu display-ID: 0
Monitor-1: DP-1 res: 3440x1440 size: N/A modes: N/A
device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: kms_swrast
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.1-arch1.1
navi31 LLVM 17.0.6 DRM 3.57 6.8.8-AMD) device-ID: 1002:744c
memory: 23.44 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 10 device: 0 type: discrete-gpu name: AMD
Radeon RX 7900 XTX (RADV NAVI31) driver: mesa radv v: 24.1.1-arch1.1
device-ID: 1002:744c surfaces: xcb,xlib,wayland device: 1
type: integrated-gpu name: AMD Radeon Graphics (RADV RAPHAEL_MENDOCINO)
driver: mesa radv v: 24.1.1-arch1.1 device-ID: 1002:164e
17.0.6 256 bits) driver: mesa llvmpipe v: 24.1.1-arch1.1 (LLVM 17.0.6)
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 18:00.1
Device-3: AMD Family 17h/19h HD Audio driver: N/A alternate: snd_hda_intel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 18:00.6 chip-ID: 1022:15e3
Device-4: Razer USA RZ19-0229 Gaming Microphone
lanes: 1 mode: 1.1 bus-ID: 1-3:2 chip-ID: 1532:0511 class-ID: 0300
Device-5: XMOS iFi (by AMR) HD USB Audio
lanes: 1 mode: 2.0 bus-ID: 1-4:3 chip-ID: 20b1:3008 class-ID: 0300
Device-6: Generic USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-8:4
chip-ID: 26ce:0a06 class-ID: 0300
API: ALSA v: k6.8.8-AMD status: kernel-api with: aoss type: oss-emulator
tools: N/A
Device-1: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak]
vendor: Rivet Networks Killer driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 08:00.0 chip-ID: 8086:2725 class-ID: 0280
Device-2: Realtek Killer E3000 2.5GbE vendor: ASRock driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: c000 bus-ID: 09:00.0
chip-ID: 10ec:3000 class-ID: 0200
IF: enp9s0 state: up speed: 10 Mbps duplex: full mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-7:3 chip-ID: 8087:0032
Local Storage: total: 6.52 TiB used: 14.39 GiB (0.2%)
ID-1: /dev/nvme0n1 maj-min: 259:4 vendor: Western Digital
model: WDS100T1X0E-00AFY0 size: 931.51 GiB block-size: physical: 512 B
fw-rev: 615400WD temp: 31.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Intel model: SSDPEKNU020TZ
lanes: 4 tech: SSD serial: <filter> fw-rev: 002C temp: 51.9 C scheme: GPT
ID-3: /dev/nvme2n1 maj-min: 259:3 vendor: Western Digital
model: WD BLACK SN850X 2000GB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 620361WD temp: 51.9 C scheme: GPT
ID-4: /dev/sda maj-min: 8:0 vendor: Corsair model: Force GT
tech: SSD serial: <filter> fw-rev: 5.05 scheme: GPT
ID-5: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD2002FAEX-007BA0 size: 1.82 TiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: N/A serial: <filter> fw-rev: 1D05
scheme: MBR
ID-1: / raw-size: 294.48 GiB size: 294.48 GiB (100.00%)
used: 14.36 GiB (4.9%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:11
used: 27 MiB (28.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:7
ID-3: /home raw-size: 294.48 GiB size: 294.48 GiB (100.00%)
ID-4: /var/log raw-size: 294.48 GiB size: 294.48 GiB (100.00%)
ID-5: /var/tmp raw-size: 294.48 GiB size: 294.48 GiB (100.00%)
ID-1: swap-1 type: zram size: 61.94 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 45.6 C mobo: N/A
GPU: device: amdgpu temp: 38.0 C device: amdgpu temp: 47.0 C mem: 52.0 C
fan: 0 watts: 19.00
Memory: total: 64 GiB note: est. available: 61.94 GiB used: 3.93 GiB (6.4%)
Processes: 408 Power: uptime: 27m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 24.77 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1819 libs: 538 tools: octopi,paru Compilers:
clang: 17.0.6 gcc: 14.1.1 Shell: garuda-inxi default: fish v: 3.7.1
System install date:     2024-06-17
Last full system update: 2024-06-17
I followed a basic guide on how to install the gaming edition of garuda but I’m going a little cross eyed :grin:
You have already installed the kernel that is best optimized for AMD Zen4 CPUs:
“Linux kernel aimed at the ZNVER4/MZEN4 AMD Ryzen CPU based hardware”
Awesome sauce, thanks for the input :slight_smile:
