Updating made my display not be detected properly, only showing as "none-1"
So, I’ve been trying to fix this problem for awhile now but nothing is working. After an update I did a month or so back, my dual monitor setup broke, showing the same thing on both sides (using the Odyssey G9 in pip mode) and the display settings only show “none-1”. Unable to change resolution and refresh rates to the correct settings. The terminal is also showing [discrete] next to my GPU (NVIDIA GeForce RTX 3060) when it used to not show it. The system was working fine before the update so I’ve been using a snapshot from before the update to continue using my desktop while I try fixing what ever keeps breaking when I update, which that snapshot uses linux-lts for its kernel as that worked for me before.
Edit: I was told what discrete meant, knowing that, I’m still gonna leave it in incase it’s useful information.
Heres my Garuda-inxi for the post update mess
Kernel: 6.9.0-1-mainline arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-mainline
root=UUID=c9e5750d-6564-43d9-9812-a5c69f36d974 rw rootflags=subvol=@
nvme_load=YES loglevel=3 systemd.unified_cgroup_hierarchy=1 ibt=off
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.2.0
Type: Desktop Mobo: ASUSTeK model: TUF GAMING X570-PLUS (WI-FI) v: Rev X.0x
BIOS: American Megatrends v: 4002 date: 06/15/2021
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3916 high: 4841 min/max: 2200/4850 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3852 2: 3867
3: 3874 4: 3800 5: 3800 6: 3863 7: 3873 8: 3800 9: 3869 10: 3870 11: 3873
12: 4841 13: 3882 14: 3867 15: 3859 16: 3875 bogomips: 121420
Device-1: NVIDIA GA106 [GeForce RTX 3060] vendor: eVga.com. driver: nvidia
v: 550.78 alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current
(as of 2024-04; EOL~2026-12-xx) arch: Ampere code: GAxxx
lanes: 16 bus-ID: 0a:00.0 chip-ID: 10de:2503 class-ID: 0300
Device-2: Valve 3D Camera driver: uvcvideo type: USB rev: 3.2
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-1.1:5 chip-ID: 28de:2400
compositor: kwin_x11 driver: X: loaded: modesetting,nouveau
Monitor-1: Unknown-1 mapped: None-1 res: 1920x1080 hz: 60 size: N/A
modes: 1920x1080
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 1
drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: swrast
inactive: wayland
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: mesa v: 24.0.8-arch1.1
glx-v: 1.4 direct-render: yes renderer: llvmpipe (LLVM 17.0.6 256 bits)
device-ID: ffffffff:ffffffff memory: 122.76 GiB unified: yes
API: Vulkan v: 1.3.279 layers: 14 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 driver: nvidia v: 550.78 device-ID: 10de:2503
surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe (LLVM 17.0.6 256
bits) driver: mesa llvmpipe v: 24.0.8-arch1.1 (LLVM 17.0.6)
Device-1: NVIDIA GA106 High Definition Audio vendor: eVga.com.
bus-ID: 0a:00.1 chip-ID: 10de:228e class-ID: 0403
Device-3: Valve VR Radio driver: cdc_acm,hid-generic,usbhid type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1.3.2:10
chip-ID: 28de:2102 class-ID: 0a00 serial: <filter>
Device-4: Valve VR Radio & HMD Mic
lanes: 1 mode: 1.1 bus-ID: 1-1.3.3:13 chip-ID: 28de:2102 class-ID: 0102
Device-5: HP HyperX QuadCast S driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2.4:6
chip-ID: 03f0:0d8b class-ID: 0300 serial: <filter>
Device-6: Astro Gaming A50 driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:14
chip-ID: 9886:002c class-ID: 0300
API: ALSA v: k6.9.0-1-mainline status: kernel-api with: aoss
Device-1: Intel Wi-Fi 5 Wireless-AC 9x6x [Thunder Peak] driver: iwlwifi
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 05:00.0
vendor: ASUSTeK driver: r8168 v: 8.053.00-NAPI modules: r8169 pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 06:00.0 chip-ID: 10ec:8168
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-5:2
rfk-block: hardware: no software: no address: <filter> bt-v: 5.1 lmp-v: 10
Local Storage: total: 16.84 TiB used: 1.87 TiB (11.1%)
fw-rev: 2B2QEXM7 temp: 45.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Western Digital
model: WD BLACK SN770 2TB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 731100WD temp: 41.9 C scheme: MBR
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST14000DM001-2JC101
size: 12.73 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: DN01 scheme: GPT
model: WD2003FZEX-00SRLA0 size: 1.82 TiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Memorex model: USB Flash Drive
size: 14.75 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 2.0 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: SSD serial: <filter>
fw-rev: 2.00 scheme: MBR
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 604.15 GiB (32.4%)
fs: btrfs block-size: 4096 B dev: /dev/nvme1n1p1 maj-min: 259:3
ID-2: /home raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
used: 604.15 GiB (32.4%) fs: btrfs block-size: 4096 B dev: /dev/nvme1n1p1
maj-min: 259:3
ID-3: /var/log raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
maj-min: 259:3
ID-4: /var/tmp raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
maj-min: 259:3
ID-1: swap-1 type: zram size: 125.71 GiB used: 22.5 MiB (0.0%)
System Temperatures: cpu: 65.0 C mobo: N/A
Memory: total: 128 GiB note: est. available: 125.71 GiB
used: 12.24 GiB (9.7%)
Processes: 497 Power: uptime: 18m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 50.24 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2366 libs: 604 tools: aura, gnome-software,
octopi, pamac, paru Compilers: clang: 17.0.6 gcc: 14.1.1
Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole inxi: 3.3.34
System install date:     2024-01-19
Last full system update: 2024-05-28
Is partially upgraded:   Yes
Failed units:            vmware.service
I’m not so sure as to why this happened as I’m new to linux so its possible I just messed something up or overlooking something. But I do have to mention that I did try to put an AMD GPU into my computer along side my nvidia one before the mess started, but it seemed to cause problems so I just took it out and everything seemed fine after until that update. Honestly was stupid to do without knowing better I must admit, lol. Any help would be appreciated.
Fix this first. Your system is in an unstable state until you do.
I got it to say no so I’m hoping that’s correct. I switched over back to linux-lts as when I did the garuda-update, it said it was unable to build nvidia drivers for linux-mainline.
Kernel: 6.6.32-1-lts arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
Speed (MHz): avg: 4584 high: 4585 min/max: 2200/4850 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4585 2: 4585
3: 4585 4: 4585 5: 4585 6: 4585 7: 4585 8: 4585 9: 4585 10: 4584 11: 4585
12: 4585 13: 4585 14: 4585 15: 4585 16: 4585 bogomips: 121415
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 2 speed: 5 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 0a:00.0
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-1.1:4 chip-ID: 28de:2400
modes: 1920x1080
inactive: wayland
API: ALSA v: k6.6.32-1-lts status: kernel-api with: aoss
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 603.22 GiB (32.4%)
used: 603.22 GiB (32.4%) fs: btrfs block-size: 4096 B dev: /dev/nvme1n1p1
maj-min: 259:3
maj-min: 259:3
maj-min: 259:3
ID-1: swap-1 type: zram size: 125.71 GiB used: 13.5 MiB (0.0%)
System Temperatures: cpu: 78.6 C mobo: N/A
used: 11.19 GiB (8.9%)
Processes: 527 Power: uptime: 2m states: freeze,mem,disk suspend: deep
Still having the same issues though.
It means its using the main GPU an not the integrated (cpu iGPU) its nothing to worry about unless on a laptop an it wont switch back.
That’s good then, glad its not a corrupt GPU or something as that was my first thought. Though it used to not say that and it worked fine, games and everything. But If that’s not a problem then what’s going on with my monitor? I was assuming the monitor was bugging because of the GPU. Any ideas as to why my computer isn’t properly detecting my monitor anymore?
I can only think cause the nouveau open driver is now getting lots of updates since nvidia hired the lead guy an he’s pushing a lot of nice things out. Might try to roll back to a prior version or power cycle the screen but this is best a question for someone using 2 screens or in your case two inputs. As i just use 1 for my ultrawide. At the least I’m sure some one smarter then me in this will chime in.
Glad to hear nvidias playing nice with linux. As far as power cycling my monitor, if I turn it off at all after the update, when it turns back on it just stays a blackscreen and turns back off as if its not getting a signal that its plugged in. I would have to restart my computer for the screen to work again. But if I can’t get it fixed here soon, I’ll just go back to my snapshot I’ve been using until someone comes with an idea to try. Thank you for letting me know what discrete was though, I really though it was corrupted or something, lol.
It’s getting better not 100% but better
If you dont mind proprietary the new 555 beta driver solve most if not all wayland issues so might want to give that a go.
here’s how to install it if you want
I changed my gpu to amd a week before this came out since it was delayed a bit so i haven’t played with it but i haven’t heard a bad thing about it
Atleast its getting better. I’ll try the beta drivers and I’ll post if anything changed.
The beta drivers did not work, and switching to wayland didn’t work, but when I did switch to wayland, plasmashell wont open anymore.
using the command
kstart5 plasmashell
results in these error messages
libEGL warning: MESA-LOADER: failed to open simpledrm: /usr/lib/dri/simpledrm_dri.so: cannot open shared objec
t file: No such file or directory (search paths /usr/lib/dri, suffix _dri)
MESA: error: zink: could not create swapchain
might be related to the problem I’m having? but for right now, I’m gonna stick to x11.
the only thing i could think of is the maid driver is blacklisted, i assume you restarted after updating. but ya x11 is fine if it works just fine.
I think I have fixed the problem. I was fallowing the instructions here
https://wiki.archlinux.org/title/Xrandr#Adding_undetected_resolutions
I wanted to at least fix my resolution but once I did all the steps and figured out what my output actually was. I rebooted and now the monitor is being detected, correct resolution and refresh rate and its counting as 2 monitors now. Can’t believe the answer was right underneath my nose, lol. Thanks for all the help and suggestions, hopefully this post will help anyone else having trouble.
Not everyone has the patience to wade through the Arch Wiki’s hyperlinks. Kudos for the gumption to do what it takes and using the best reference evar! :+1: :arch:
