the first update on 500mb error I dont know what to put yes or not but at the end it always says update failed and makes me everything from the start
error: whois: signature from "Evangelos Foutras <foutrelis@archlinux.org>" is marginal trust
:: File /var/cache/pacman/pkg/whois-5.5.20-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PG
P signature)).
Do you want to delete it? [Y/n] y
error: wine-mono: signature from "Daniel Bermond <dbermond@archlinux.org>" is marginal trust
:: File /var/cache/pacman/pkg/wine-mono-8.1.0-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PG
P signature)).
error: wine-nine: signature from "Laurent Carlier <lordheavym@archlinux.org>" is marginal trust
:: File /var/cache/pacman/pkg/wine-nine-0.9-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (P
GP signature)).
error: wxwidgets-common: signature from "Antonio Rojas <arojas@archlinux.org>" is marginal trust
:: File /var/cache/pacman/pkg/wxwidgets-common-3.2.4-3-x86_64.pkg.tar.zst is corrupted (invalid or corrupted p
ackage (PGP signature)).
error: wxwidgets-gtk3: signature from "Antonio Rojas <arojas@archlinux.org>" is marginal trust
:: File /var/cache/pacman/pkg/wxwidgets-gtk3-3.2.4-3-x86_64.pkg.tar.zst is corrupted (invalid or corrupted pac
error: failed to commit transaction (invalid or corrupted package (PGP signature))
Press enter to exit
at the end it update failed
Hi @Batman222 , Please provide garuda-inxi
root=UUID=21a64577-223b-4b12-9474-12bcb6c83900 rw rootflags=subvol=@
Mobo: ASUSTeK model: PRIME B550M-K v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2803
date: 04/28/2022
Info: model: AMD Ryzen 5 2400G with Radeon Vega Graphics bits: 64
type: MT MCP arch: Zen level: v3 note: check built: 2017-19 process: GF 14nm
family: 0x17 (23) model-id: 0x11 (17) stepping: 0 microcode: 0x8101016
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 2821 high: 3600 min/max: 1600/3600 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3600 2: 2477
3: 3600 4: 2971 5: 1351 6: 3600 7: 1369 8: 3600 bogomips: 57492
Device-1: AMD Navi 14 [Radeon RX 5500/5500M / Pro 5500M] vendor: ASUSTeK
driver: amdgpu v: kernel arch: RDNA-1 code: Navi-1x process: TSMC n7 (7nm)
built: 2019-20 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 03:00.0 chip-ID: 1002:7340
Device-2: KYE Systems (Mouse Systems) [] driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:3
chip-ID: 0458:6006 class-ID: 0102 serial: <filter>
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: AOC 2460 serial: <filter>
built: 2014 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
inactive: gbm,wayland
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 5500 XT (navi14 LLVM
16.0.6 DRM 3.54 6.5.9-zen2-1-zen) device-ID: 1002:7340 memory: 7.81 GiB
unified: no
API: Vulkan v: 1.3.269 layers: 13 device: 0 type: discrete-gpu name: AMD
Radeon RX 5500 XT (RADV NAVI14) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:7340 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab38
Device-2: AMD Family 17h/19h HD Audio vendor: ASUSTeK
bus-ID: 0e:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-3: JMTek LLC. [] driver: hid-generic,snd-usb-audio,usbhid type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1:2 chip-ID: 0c76:162f
Device-4: KYE Systems (Mouse Systems) [] driver: snd-usb-audio,uvcvideo
speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 0c:00.0 chip-ID: 10ec:8168
IF: enp12s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 1.14 TiB used: 158.12 GiB (13.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 model: SSD 1TB size: 931.51 GiB
tech: SSD serial: <filter> fw-rev: V0926A3 temp: 39.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 model: SSD 256GB size: 238.47 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 0326 scheme: GPT
used: 158.12 GiB (17.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.53 GiB used: 280 MiB (1.8%) priority: 100
System Temperatures: cpu: 42.0 C mobo: N/A gpu: amdgpu temp: 40.0 C
mem: 0.0 C
Processes: 314 Uptime: 3h 11m wakeups: 0 Memory: total: 16 GiB
available: 15.53 GiB used: 5.82 GiB (37.5%) Init: systemd v: 254
pm: pacman pkgs: 1772 libs: 522 tools: octopi,paru Shell: fish v: 3.6.1
Garuda (2.6.17-1):
System install date: 2023-12-12
Last full system update: 2023-12-12
╭─giuseppe@giuseppe in ~ took 2s
╰─λ
Please try these :
1:
sudo pacman -Sy archlinux-keyring
2:
sudo pacman -Syu
[sudo] password di giuseppe:
:: Sincronizzazione dei database in corso...
garuda è aggiornato
core è aggiornato
extra 8,3 MiB 6,07 MiB/s 00:01 [------------------------------------] 100%
multilib 140,0 KiB 631 KiB/s 00:00 [------------------------------------] 100%
chaotic-aur 2,7 MiB 1722 KiB/s 00:02 [------------------------------------] 100%
attenzione: archlinux-keyring-20231207-1 è aggiornato ma sarà reinstallato
risoluzione delle dipendenze in corso...
ricerca dei pacchetti in conflitto in corso...
Pacchetto (1) Vecchia versione Nuova versione Variazione netta Dimensione del download
core/archlinux-keyring 20231207-1 20231207-1 0,00 MiB 1,15 MiB
Dimensione totale dei pacchetti da scaricare: 1,15 MiB
Dimensione totale dei pacchetti da installare: 1,64 MiB
Dimensione netta dell'aggiornamento: 0,00 MiB
:: Vuoi procedere con l'installazione? [S/n] s
:: Download dei pacchetti in corso...
archlinux-keyring-20231207-1-any 1180,2 KiB 4,50 MiB/s 00:00 [------------------------------------] 100%
(1/1) verifica delle chiavi presenti nel portachiavi [------------------------------------] 100%
(1/1) verifica dell'integrità dei pacchetti [------------------------------------] 100%
errore: archlinux-keyring: la firma di "Christian Hesse <eworm@archlinux.org>" ha un'affidabilità marginale
:: Il file /var/cache/pacman/pkg/archlinux-keyring-20231207-1-any.pkg.tar.zst è corrotto (il pacchetto non è valido oppure è corrotto (firma PGP)).
Vuoi eliminarlo? [S/n] I did input ```
sudo pacman -Sy archlinux-keyring what should i answer yes or no
SGS
13 December 2023 20:02
7
sudo micro /etc/fstab
Or use gnome-disk-utility.
Please use for terminal text
Terminal text
then others can easily expand or copy the text.
terminal text
then others can easily expand or copy the text in the view. Move the mouse pointer over it in the upper right corner.
Some help
Terminal text
Terminal text
Straight:
sudo pacman -Syu
done
i did answer yes to all questions but now again its starting the 500mb installer and the end it going to ask me again to answer the questions it never ends error: wine-nine: signature from "Laurent Carlier <lordheavym@archlinux.org>" is marginal trust
GP signature)).
This is only a part of the questions I always answered yes but at the end it tells that the update failed
SGS
13 December 2023 20:06
10
Please edit all your posts.
And just wait until the dev’s fixed it.
Straight:
sudo pacman -Syu
arning: insufficient columns available for table display
Packages (570) alsa-card-profiles-1:1.0.0-2 amd-ucode-20231211.f2e52a1c-1 android-tools-34.0.4-3
android-udev-20231124-1 aom-3.8.0-2 appstream-1.0.0-5 appstream-qt-0.16.3-1 [removal]
appstream-qt5-1.0.0-5 ark-23.08.4-1 attica5-5.112.0-1 avahi-1:0.8+r189+g35bb1ba-1
baloo-widgets-23.08.4-1 baloo5-5.112.0-1 bash-5.2.021-1 bind-9.18.20-1 blas-3.12.0-3
bluedevil-1:5.27.10-1 bluez-5.70-2 bluez-hid2hci-5.70-2 bluez-libs-5.70-2
bluez-plugins-5.70-2 bluez-qt5-5.112.0-1 bluez-utils-5.70-2 bomber-23.08.4-1
bovo-23.08.4-1 breeze-5.27.10-1 breeze-icons-5.112.0-1 btrfs-progs-6.6.2-1
ca-certificates-mozilla-3.95-1 cachyos-ananicy-rules-git-20231123.r285.g18e122e-1
candy-icons-git-r1105.ada73e9-1 cblas-3.12.0-3 cfitsio-1:4.3.1-1
chaotic-mirrorlist-20231212-1 corectrl-1.3.8-1 curl-8.5.0-1 ddcutil-2.0.0-1
dialog-1:1.3_20231002-1 discord-0.0.38-1 dolphin-23.08.4-1 dolphin-plugins-23.08.4-1
dracut-059-4 dxvk-mingw-git-2.3.r21.g1b31aa5d-1 edk2-ovmf-202311-1 elisa-23.08.4-1
enchant-2.6.3-1 exiv2-0.28.1-1 eza-0.16.3-1 faad2-2.11.1-1 fakeroot-1.32.2-1
fastfetch-2.3.4-1 faudio-23.11-1 ffmpeg-2:6.1-2 ffmpegthumbs-23.08.4-1 firedragon-119.0-2
firewalld-2.0.2-1 fish-3.6.4-1 frameworkintegration5-5.112.0-2 fwupd-1.9.10-1 fzf-0.44.1-1
garuda-bash-config-1.0.6-1 garuda-boot-options-1.0.4-1 garuda-common-settings-2.6.19-2
garuda-dr460nized-3.0.8-1 garuda-fish-config-1.5.20-1 garuda-icons-r40.a0891d2-1
garuda-libs-1.4.5-1 garuda-network-assistant-1.1.3-1 garuda-video-linux-config-2:1.1.6-1
garuda-wallpapers-r87.6612cb0-1 garuda-welcome-1.2.10-1 gawk-5.3.0-1 gettext-0.22.4-1
ghostscript-10.02.1-1 git-2.43.0-1 glib2-2.78.3-1 glslang-13.1.1-2 gnome-firmware-45.0-1
gnupg-2.4.3-2 gnutls-3.8.2-1 goverlay-git-1.0.r0.g8453556-1 gpgme-1.23.2-1
granatier-23.08.4-1 grub-2:2.12rc1-7 grub-garuda-2.06-2
grub-theme-garuda-dr460nized-r4.61172c5-1 gssdp-1.6.3-1 gst-libav-1.22.7-1
gst-plugin-pipewire-1:1.0.0-2 gst-plugins-bad-1.22.7-1 gst-plugins-bad-libs-1.22.7-1
gst-plugins-base-1.22.7-1 gst-plugins-base-libs-1.22.7-1 gst-plugins-good-1.22.7-1
gst-plugins-ugly-1.22.7-1 gstreamer-1.22.7-1 gstreamer-vaapi-1.22.7-1
gtk-update-icon-cache-1:4.12.4-1 gtk4-1:4.12.4-1 guiscrcpy-1:2023.1.1-4 gupnp-1:1.6.6-1
gvim-9.0.2143-1 gwenview-23.08.4-1 harfbuzz-8.3.0-1 harfbuzz-icu-8.3.0-1
heroic-games-launcher-bin-2.11.0-1 hwdata-0.377-1 iana-etc-20231117-1
imagemagick-7.1.1.23-1 intel-gmmlib-22.3.14-1 intel-media-driver-23.4.2-1 inxi-3.3.31.1-1
iproute2-6.6.0-2 iptables-nft-1:1.8.10-1 irqbalance-1.9.3-1 jre-openjdk-21.u35-8
jre-openjdk-headless-21.u35-3 [removal] kaccounts-integration-23.08.4-1
kaccounts-providers-23.08.4-1 kactivities-stats5-5.112.0-1 kactivities5-5.112.0-1
kactivitymanagerd-5.27.10-1 kajongg-23.08.4-1 kamera-23.08.4-1 kapman-23.08.4-1
karchive5-5.112.0-1 kate-23.08.4-1 katomic-23.08.4-1 kauth5-5.112.0-1 kblackbox-23.08.4-1
kblocks-23.08.4-1 kbookmarks5-5.112.0-1 kbounce-23.08.4-1 kbreakout-23.08.4-1
kcalc-23.08.4-1 kcalendarcore5-5.112.0-1 kcmutils5-5.112.0-1 kcodecs5-5.112.0-1
kcompletion5-5.112.0-1 kconfig5-5.112.0-1 kconfigwidgets5-5.112.0-1 kcontacts5-5.112.0-1
kcoreaddons5-5.112.0-1 kcrash5-5.112.0-1 kdbusaddons5-5.112.0-1 kde-cli-tools-5.27.10-1
kde-gtk-config-5.27.10-1 kdeclarative5-5.112.0-1 kdeconnect-23.08.4-1 kdecoration-5.27.10-1
kded5-5.112.0-1 kdegraphics-mobipocket-23.08.4-1 kdegraphics-thumbnailers-23.08.4-1
kdelibs4support-5.112.0-1 kdeplasma-addons-5.27.10-1 kdesu5-5.112.0-1 kdialog-23.08.4-1
kdiamond-23.08.4-1 kdnssd5-5.112.0-1 kdsoap-2.1.1-1 [removal] kdsoap-qt5-2.1.1-2
kdsoap-qt6-2.1.1-2 kdsoap-ws-discovery-client-0.3.0-2 kemoticons-5.112.0-1
kfilemetadata5-5.112.0-1 kfourinline-23.08.4-1 kget-23.08.4-1 kglobalaccel5-5.112.0-1
kgoldrunner-23.08.4-1 kguiaddons5-5.112.0-1 kholidays5-1:5.112.0-1 khotkeys-5.27.10-1
ki18n5-5.112.0-1 kiconthemes5-5.112.0-1 kidletime5-5.112.0-1 kigo-23.08.4-1
killbots-23.08.4-1 kimageformats5-5.112.0-1 kinfocenter-5.27.10-1 kinit-5.112.0-1
kio-extras-23.08.4-1 kio-fuse-5.1.0-1 kio-gdrive-23.08.4-1 kio5-5.112.0-1
kirigami-addons5-0.11.0-7 kirigami2-5.112.0-1 kiriki-23.08.4-1 kitemmodels5-5.112.0-1
kitemviews5-5.112.0-1 kjobwidgets5-5.112.0-1 kjumpingcube-23.08.4-1 klickety-23.08.4-1
klines-23.08.4-1 kmahjongg-23.08.4-1 kmenuedit-5.27.10-1 kmines-23.08.4-1
knavalbattle-23.08.4-1 knetwalk-23.08.4-1 knewstuff5-5.112.0-1 knights-23.08.4-1
knotifications5-5.112.0-1 knotifyconfig5-5.112.0-1 kolf-23.08.4-1 kollision-23.08.4-1
kompare-23.08.4-1 konquest-23.08.4-1 konsole-23.08.4-1 kpackage5-5.112.0-1
kparts5-5.112.0-1 kpat-23.08.4-1 kpeople5-5.112.0-1 kpipewire-5.27.10-1
kplotting5-5.112.0-1 kpmcore-23.08.4-1 kpty5-5.112.0-1 kquickcharts5-5.112.0-1
krb5-1.20.1-2 krdc-23.08.4-1 kreversi-23.08.4-1 krfb-23.08.4-1 krunner5-5.112.0-1
kscreen-5.27.10-1 kscreenlocker-5.27.10-1 kservice5-5.112.0-1 kshisen-23.08.4-1
ksirk-23.08.4-1 ksnakeduel-23.08.4-1 kspaceduel-23.08.4-1 ksquares-23.08.4-1
ksshaskpass-5.27.10-1 ksudoku-23.08.4-1 ksystemstats-5.27.10-1 ktexteditor5-5.112.0-1
ktextwidgets5-5.112.0-1 ktorrent-23.08.4-1 ktuberling-23.08.4-1 kubrick-23.08.4-1
kunitconversion5-5.112.0-1 kuserfeedback-1.2.0-1 [removal] kuserfeedback5-1.3.0-4
kwallet-pam-5.27.10-1 kwallet5-5.112.0-1 kwayland-integration-5.27.10-1 kwayland5-5.112.0-1
kwidgetsaddons5-5.112.0-1 kwin-5.27.10-1 kwindowsystem5-5.112.0-1 kxmlgui5-5.112.0-1
lapack-3.12.0-3 layer-shell-qt-5.27.10-1 lcms2-2.16-1 lib32-curl-8.5.0-1
lib32-gettext-0.22.4-1 lib32-glib2-2.78.3-1 lib32-gnutls-3.8.2-1
lib32-gst-plugins-base-libs-1.22.7-1 lib32-gstreamer-1.22.7-1 lib32-harfbuzz-8.3.0-1
lib32-libcurl-compat-8.5.0-1 lib32-libcurl-gnutls-8.5.0-1 lib32-libdecor-0.2.1-1
lib32-libelf-0.190-1 lib32-libgcrypt-1.10.3-1 lib32-libnl-3.9.0-1
lib32-libpipewire-1:1.0.0-1 lib32-libtiff-4.6.0-2 lib32-libxml2-2.12.2-1
lib32-libxslt-1.1.39-1 lib32-nss-3.95-1 lib32-p11-kit-0.25.3-1 lib32-pipewire-1:1.0.0-1
lib32-pipewire-jack-1:1.0.0-1 lib32-readline-8.2.007-1 lib32-sdl2-2.28.5-1
lib32-speex-1.2.1-1 lib32-sqlite-3.44.0-1 lib32-systemd-255-1 lib32-util-linux-2.39.3-1
lib32-xz-5.4.5-1 libadwaita-1:1.4.2-1 libass-0.17.1-2 libavif-1.0.3-1 libcap-2.69-3
libcloudproviders-0.3.5-1 libcurl-compat-8.5.0-1 libcurl-gnutls-8.5.0-1 libde265-1.0.14-1
libdecor-0.2.1-2 libdrm-2.4.118-1 libelf-0.190-1 libgcrypt-1.10.3-1 libgusb-0.4.8-1
libheif-1.17.5-2 libibus-1.5.29-2 libimagequant-4.2.2-2 libkdcraw-23.08.2-1 [removal]
libkdcraw5-23.08.4-1 libkdegames-23.08.4-1 libkexiv2-23.08.4-1 libkgapi-23.08.4-1
libkmahjongg-23.08.4-1 libkomparediff2-23.08.4-1 libksba-1.6.5-1 libkscreen-5.27.10-1
libksysguard-5.27.10-1 libktorrent-23.08.4-1 libmaxminddb-1.8.0-1 libnbd-1.18.1-3
libnet-2:1.3-1 libnghttp2-1.58.0-1 libnl-3.9.0-1 libosinfo-1.11.0-1 libp11-kit-0.25.3-1
libpipewire-1:1.0.0-2 libpulse-16.1-7 libqaccessibilityclient-0.4.1-2 [removal]
libqaccessibilityclient-qt5-0.6.0-1 libqalculate-4.9.0-1 libretro-beetle-pce-1198-1
libretro-beetle-psx-2689-1 libretro-beetle-psx-hw-2689-1 libretro-beetle-supergrafx-996-1
libretro-bsnes-1:3120-1 libretro-core-info-1.16.0.3-1 libretro-flycast-5942-1
libretro-gambatte-1010-1 libretro-genesis-plus-gx-2083-1 libretro-mame-88634-1
libretro-play-8027-1 libretro-ppsspp-38911-1 libretro-scummvm-146706-1
libretro-shaders-slang-1380-1 libretro-snes9x-1:2533-1 libsndfile-1.2.2-2 libtiff-4.6.0-2
libunibreak-5.1-1 liburing-2.5-1 libuv-1.47.0-1 libvirt-1:9.10.0-1 libvirt-glib-5.0.0-1
libvirt-python-1:9.10.0-1 libwacom-2.9.0-2 libwbclient-4.19.3-1 libwireplumber-0.4.17-1
libxml2-2.12.2-1 libxslt-1.1.39-1 libyuv-r2426+464c51a0-1 lilv-0.24.22-1
linux-firmware-20231211.f2e52a1c-1 linux-firmware-whence-20231211.f2e52a1c-1
linux-wifi-hotspot-4.6.0-1 linux-zen-6.6.6.zen1-1 linux-zen-headers-6.6.6.zen1-1
love-11.5-1 lskat-23.08.4-1 lsof-4.99.0-1 luajit-2.1.1702233742-1 lutris-0.5.14-1
mariadb-libs-11.2.2-1 mbedtls2-2.28.6-1 mercurial-6.6-1 mhwd-db-garuda-2:1.1.6-1
mhwd-db-garuda-git-1:r63.2f652e8-3 [removal] mhwd-garuda-git-r25.3a28734-1 milou-5.27.10-1
modemmanager-qt5-5.112.0-1 mujs-1.3.4-1 mumble-1.5.517-6 network-manager-sstp-1.3.2-1
networkmanager-qt5-5.112.0-1 nfs-utils-2.6.4-1 nfsidmap-2.6.4-1 noto-fonts-1:23.12.1-1
noto-fonts-emoji-1:2.042-1 nss-3.95-1 obs-studio-30.0.0-1 okular-23.08.4-1
onevpl-2023.4.0-1 openvpn-2.6.8-1 osinfo-db-20231027-1 oxygen-sounds-5.27.10-1
p11-kit-0.25.3-1 palapeli-23.08.4-1 partitionmanager-23.08.4-1 paru-2.0.1-1 patool-2.0.0-2
pcsclite-2.0.1-1 perl-5.38.1-1 phonon-qt5-4.12.0-3 picmi-23.08.4-1 pipewire-1:1.0.0-2
pipewire-alsa-1:1.0.0-2 pipewire-audio-1:1.0.0-2 pipewire-jack-1:1.0.0-2
pipewire-pulse-1:1.0.0-2 pipewire-v4l2-1:1.0.0-2 pipewire-x11-bell-1:1.0.0-2
pipewire-zeroconf-1:1.0.0-2 pkcs11-helper-1.30.0-1 pkgconf-2.1.0-2
plasma-browser-integration-5.27.10-1 plasma-desktop-5.27.10-1 plasma-firewall-5.27.10-1
plasma-framework5-5.112.0-1 plasma-integration-5.27.10-1 plasma-nm-5.27.10-1
plasma-pa-5.27.10-1 plasma-systemmonitor-5.27.10-1 plasma-thunderbolt-5.27.10-1
plasma-wayland-session-5.27.10-1 plasma-workspace-5.27.10-1
plasma5-themes-sweet-full-git-r348.f6e53f1-1 plasma5-themes-sweet-kde-git-r27.fd0710a-1
poco-1.12.5p1-1 polkit-kde-agent-5.27.10-1 polkit-qt5-0.175.0-1 poppler-23.12.0-1
poppler-qt5-23.12.0-1 postgresql-libs-16.1-1 powerdevil-5.27.10-1 prison5-5.112.0-1
protobuf-25.1-1 protobuf-c-1.4.1-5 proton-ge-custom-2:GE.Proton8.25-1
protontricks-git-1.10.5.r13.g26952ae-1 purpose5-5.112.0-1 python-3.11.6-1
python-attrs-23.1.0-1 python-cairosvg-2.7.1-1 python-certifi-2023.11.17-1
python-charset-normalizer-3.3.2-1 python-contourpy-1.2.0-1 python-cycler-0.12.1-1
python-fastjsonschema-2.19.0-1 python-fonttools-4.46.0-1 python-markdown-3.5.1-1
python-matplotlib-3.8.1-1 python-moddb-0.10.0-1 python-numpy-1.26.2-1
python-packaging-23.2-1 python-pillow-10.1.0-2 python-platformdirs-4.1.0-1
python-pydantic-2.5.2-1 python-pydantic-core-1:2.14.5-1 python-setuptools-1:69.0.0-1
python-trove-classifiers-2023.11.29-1 python-typing_extensions-4.9.0-1
python-urllib3-1.26.18-1 python-zope-interface-6.1-1 qemu-audio-alsa-8.1.3-1
qemu-audio-dbus-8.1.3-1 qemu-audio-jack-8.1.3-1 qemu-audio-oss-8.1.3-1
qemu-audio-pa-8.1.3-1 qemu-audio-pipewire-8.1.3-1 qemu-audio-sdl-8.1.3-1
qemu-audio-spice-8.1.3-1 qemu-base-8.1.3-1 qemu-block-curl-8.1.3-1 qemu-block-dmg-8.1.3-1
qemu-block-nfs-8.1.3-1 qemu-block-ssh-8.1.3-1 qemu-chardev-spice-8.1.3-1
qemu-common-8.1.3-1 qemu-desktop-8.1.3-1 qemu-hw-display-qxl-8.1.3-1
qemu-hw-display-virtio-gpu-8.1.3-1 qemu-hw-display-virtio-gpu-gl-8.1.3-1
qemu-hw-display-virtio-gpu-pci-8.1.3-1 qemu-hw-display-virtio-gpu-pci-gl-8.1.3-1
qemu-hw-display-virtio-vga-8.1.3-1 qemu-hw-display-virtio-vga-gl-8.1.3-1
qemu-hw-usb-host-8.1.3-1 qemu-hw-usb-redirect-8.1.3-1 qemu-hw-usb-smartcard-8.1.3-1
qemu-img-8.1.3-1 qemu-system-x86-8.1.3-1 qemu-system-x86-firmware-8.1.3-1
qemu-ui-curses-8.1.3-1 qemu-ui-dbus-8.1.3-1 qemu-ui-egl-headless-8.1.3-1
qemu-ui-gtk-8.1.3-1 qemu-ui-opengl-8.1.3-1 qemu-ui-sdl-8.1.3-1 qemu-ui-spice-app-8.1.3-1
qemu-ui-spice-core-8.1.3-1 qemu-vhost-user-gpu-8.1.3-1 qgpgme-qt5-1.23.2-1 qpdf-11.6.4-1
qqc2-desktop-style5-5.112.0-1 qt5-base-5.15.11+kde+r147-1 qt5-declarative-5.15.11+kde+r32-1
qt5-tools-5.15.11+kde+r4-1 qt6-base-6.6.1-1 qt6-declarative-6.6.1-1
qt6-imageformats-6.6.1-1 qt6-svg-6.6.1-1 qt6-translations-6.6.1-1 qt6-wayland-6.6.1-1
qtermwidget-1.4.0-1 rate-mirrors-0.17.0-1 readline-8.2.007-1
reshade-shaders-git-r36.6f025aa-1 retroarch-assets-glui-1:481-1
retroarch-assets-ozone-1:481-1 retroarch-assets-xmb-1:481-1
retroarch-autoconfig-udev-git-r2208.a57f148-1 ruby-bundler-2.4.22-1 scrcpy-2.3.1-1
sddm-kcm-5.27.10-1 sdl2-2.28.5-1 sdl2_image-2.8.0-1 seabios-1.16.3-1 serf-1.3.10-1
sfml-2.6.1-1 shaderc-2023.7-2 shadow-4.14.2-1 shared-mime-info-2.4-1
signon-kwallet-extension-23.08.4-1 smbclient-4.19.3-1 snapper-0.10.7-1
sof-firmware-2023.09.2-1 solid5-5.112.0-1 sonnet5-5.112.0-1 sord-0.16.16-1
spectacle-23.08.4-1 spirv-tools-2023.5-1 sqlite-3.44.2-2 sratom-0.6.16-1
strongswan-5.9.12-1 sudo-1.9.15.p2-1 sweet-kde-theme-git-r27.fd0710a-1 [removal]
sweet-theme-full-git-r340.4e8c200-1 [removal] syndication5-5.112.0-1
syntax-highlighting5-5.112.0-1 systemd-255-1 systemd-libs-255-1 systemd-sysvcompat-255-1
systemsettings-5.27.10-1 telegram-desktop-4.12.2-1 texinfo-7.1-2
thin-provisioning-tools-1.0.9-2 threadweaver5-5.112.0-1 thunderbird-115.5.2-1
ttf-firacode-nerd-3.1.1-1 ugrep-4.3.6-1 usbutils-017-1 util-linux-2.39.3-1
util-linux-libs-2.39.3-1 v4l-utils-1.26.0-1 vde2-2.3.3-4 vim-runtime-9.0.2143-1
vlc-3.0.20-2 webkit2gtk-2.42.3-1 webkit2gtk-4.1-2.42.3-1 whois-5.5.20-1 wine-mono-8.1.0-1
wine-nine-0.9-1 wine-staging-8.21-1 winetricks-20230212-2 wireplumber-0.4.17-1
wolfssl-5.6.4-1 wxwidgets-common-3.2.4-3 wxwidgets-gtk3-3.2.4-3 xdg-desktop-portal-1.18.2-1
xdg-desktop-portal-kde-5.27.10-1 xdg-utils-1.2.0r25+g0f49cf5-1 xz-5.4.5-1 zix-0.4.2-2
zxing-cpp-2.2.1-1
Total Download Size: 2550.42 MiB
Total Installed Size: 7767.99 MiB
Net Upgrade Size: 44.11 MiB
now it about to do this download at the end it always showing me the questions and at the end update failed I 've done this many time why does it keep saying failed ?
filo
13 December 2023 20:16
12
Try
update remote fix
In case of further errors, please provide the details, if different from the initial errors.
And again, please, format text output for readability.
This
Becomes
This
I done ```
update remote fix now it updating again without error and at the end it says
Update notices:
The GRUB bootloader at /EFI/Garuda has been updated/reinstalled using ‘grub-install’. If this looks correct, n
o further action has to be taken.
filo
13 December 2023 20:51
15
This is normal.
There was an update of the GRUB package and our script correctly reinstalled the GRUB.
Nothing to be worried about.
system
Closed
15 December 2023 21:11
18
