Updated today and it broke Conky some how
Update today broke conky.
[sudo] password for keith:
  Kernel: 6.14.4-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
    root=UUID=1a5793f8-3377-4500-9b95-bcfc4a65af9e rw rootflags=subvol=@
  Desktop: Cinnamon v: 6.4.10 tk: GTK v: 3.24.49 wm: Muffin v: 6.4.1 tools:
    avail: cinnamon-screensaver,xautolock dm: LightDM v: 1.32.0 Distro: Garuda
  Type: Desktop System: Dell product: Inspiron 3670 v: N/A serial: <filter>
    Chassis: type: 3 serial: <filter>
  Mobo: Dell model: 0H4VK7 v: A01 serial: <filter> part-nu: 0868
    uuid: 4c4c4544-0047-4810-8036-c2c04f315332 UEFI: Dell v: 2.21.0
    date: 12/03/2021
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M325
  Info: model: Intel Core i5-9600K socket: LGA1151 (U3E1) note: check bits: 64
    type: MCP arch: Coffee Lake gen: core 9 level: v3 note: check built: 2018
    process: Intel 14nm family: 6 model-id: 0x9E (158) stepping: 0xC (12)
    microcode: 0xF8
  Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 smt: <unsupported> cache:
    L3: 9 MiB desc: 1x9 MiB
  Speed (MHz): avg: 800 min/max: 800/4600 base/boost: 3663/4300 scaling:
    driver: intel_pstate governor: performance volts: 1.0 V ext-clock: 100 MHz
    cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 bogomips: 44398
  Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: Dell
    ports: active: none empty: DP-1,HDMI-A-2 bus-ID: 00:02.0
    chip-ID: 8086:3e98 class-ID: 0380
  Device-2: NVIDIA GP108 [GeForce GT 1030] vendor: Gigabyte driver: nvidia
    v: 570.144 alternate: nouveau,nvidia_drm non-free: 550-570.xx+
    status: current (as of 2025-04; EOL~2026-12-xx) arch: Pascal code: GP10x
    process: TSMC 16nm built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
    link-max: gen: 3 speed: 8 GT/s ports: active: none off: HDMI-A-1
    empty: DVI-D-1 bus-ID: 01:00.0 chip-ID: 10de:1d01 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6 driver: X:
    loaded: nvidia gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 81 s-size: 602x331mm (23.70x13.03")
    s-diag: 687mm (27.05")
  Monitor-1: HDMI-A-1 mapped: HDMI-0 note: disabled model: Acer KB272HL H
    serial: <filter> built: 2022 res: mode: 1920x1080 hz: 75 scale: 100% (1)
    dpi: 82 gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 685mm (27")
    device: 3 drv: swrast gbm: drv: iris surfaceless: drv: nvidia x11:
    drv: nvidia inactive: wayland
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GT 1030/PCIe/SSE2
    memory: 1.95 GiB
  API: Vulkan v: 1.4.309 layers: 7 device: 0 type: discrete-gpu
    name: NVIDIA GeForce GT 1030 driver: nvidia v: 570.144 device-ID: 10de:1d01
    surfaces: xcb,xlib device: 1 type: discrete-gpu
    device-ID: 10de:1d01 surfaces: xcb,xlib device: 2 type: integrated-gpu
    name: Intel UHD Graphics 630 (CFL GT2) driver: mesa intel
    v: 25.0.4-arch1.1 device-ID: 8086:3e98 surfaces: xcb,xlib device: 3
    type: cpu name: llvmpipe (LLVM 19.1.7 256 bits) driver: mesa llvmpipe
    v: 25.0.4-arch1.1 (LLVM 19.1.7) device-ID: 10005:0000 surfaces: xcb,xlib
  Info: Tools: api: eglinfo, glxinfo, vulkaninfo
    gpu: nvidia-settings,nvidia-smi x11: xdpyinfo, xprop, xrandr
  Device-2: NVIDIA GP108 High Definition Audio vendor: Gigabyte
    bus-ID: 01:00.1 chip-ID: 10de:0fb8 class-ID: 0403
  API: ALSA v: k6.14.4-zen1-2-zen status: kernel-api tools: N/A
  Server-1: PipeWire v: 1.4.2 status: n/a (root, process) with:
  Device-2: Intel Ethernet I225-V driver: igc v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 port: N/A bus-ID: 03:00.0 chip-ID: 8086:15f3
  IF: enp3s0 state: up speed: 2500 Mbps duplex: full mac: <filter>
    v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5
  Local Storage: total: 2.73 TiB used: 988.92 GiB (35.4%)
    model: WD BLACK SN850X 1000GB size: 931.51 GiB block-size: physical: 512 B
    fw-rev: 620361WD temp: 25.9 C scheme: GPT
  SMART: yes health: PASSED on: 18d 2h cycles: 123
    read-units: 16,484,873 [8.44 TB] written-units: 13,280,904 [6.79 TB]
    model: WD20EARX-00PASB0 family: Green size: 1.82 TiB block-size:
    physical: 4096 B logical: 512 B sata: 3.0 speed: 6.0 Gb/s tech: N/A
    serial: <filter> fw-rev: AB51 temp: 28 C scheme: MBR
  SMART: yes state: enabled health: PASSED on: 1y 48d 12h cycles: 945
  ID-1: / raw-size: 558.98 GiB size: 558.98 GiB (100.00%)
    used: 121.24 GiB (21.7%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p5
    maj-min: 259:5
    used: 27 MiB (28.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:1
  ID-3: /home raw-size: 558.98 GiB size: 558.98 GiB (100.00%)
    maj-min: 259:5
  ID-4: /var/log raw-size: 558.98 GiB size: 558.98 GiB (100.00%)
    maj-min: 259:5
  ID-5: /var/tmp raw-size: 558.98 GiB size: 558.98 GiB (100.00%)
    maj-min: 259:5
  ID-1: swap-1 type: zram size: 31.16 GiB used: 0 KiB (0.0%) priority: 100
    comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 6
  System Temperatures: cpu: 28.0 C pch: 34.0 C mobo: 26.0 C gpu: nvidia
    temp: 32 C
  Fan Speeds (rpm): fan-1: 978 gpu: nvidia fan: 38%
  Memory: total: 32 GiB available: 31.16 GiB used: 2.87 GiB (9.2%)
  Processes: 293 Power: uptime: 14m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.39 GiB services: csd-power,upowerd
  Packages: 1660 pm: pacman pkgs: 1644 libs: 462 tools: pamac,paru
    pm: flatpak pkgs: 16 Compilers: clang: 19.1.7 gcc: 15.1.1
    Shell: garuda-inxi (sudo) default: Bash v: 5.2.37
    running-in: gnome-terminal inxi: 3.3.38
  System install date:     2024-09-26
  Last full system update: 2025-05-02 ↻
  Windows dual boot:       Yes
rebooted and conky did not and would not start manually.
$conky -DD
conky: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
Conky is conky-lua-nv
Oh right. libxml2 was updated yesterday and caused a lot of conflicts with orphans that prevented updating.
I have now installed conky on my updated system as a check. I get no errors, it can be started in the console but doesn’t show anything. When I installed Garuda, I also had conky but uninstalled it because it didn’t fit in with KDE and I was unable to turn it off or move it around (I am using KDE widgets or the System monitor).
Now I can’t say it does anything. It should show system info, right?
Yep, thats right. Take a look here:
Arch repo packages like emacs, libarchive and openconnect have already been rebuilt against the new library.
Just wait for an updated AUR version of conky-lua-nv.
I will conquer that the following solved my issue.
I deleted the existing ~/conky-lua-nv folder (with sudo privileges).
Then did the new git from Arch(https://aur.archlinux.org/conky-lua-nv.git)
Installed and all is back to normal.
