Kernel: 6.16.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1 clocksource: tsc
root=UUID=1f858aa4-dc21-4849-9613-fd93f2269a29 rw rootflags=subvol=@ quiet loglevel=3
Desktop: KDE Plasma v: 6.4.4 tk: Qt v: N/A info: frameworks v: 6.17.0 wm: kwin_wayland vt: 1
Type: Desktop System: Gigabyte product: A520M S2H v: -CF serial: <superuser required>
Mobo: Gigabyte model: A520M S2H v: x.x serial: <superuser required> uuid: <superuser required>
UEFI: American Megatrends LLC. v: F19d date: 09/02/2024
Info: model: AMD Ryzen 5 5600GT with Radeon Graphics bits: 64 type: MT MCP arch: Zen 3 gen: 3
level: v3 note: check built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25) model-id: 0x50 (80)
stepping: 0 microcode: 0xA500012
Topology: cpus: 1x dies: 1 clusters: 1 cores: 6 threads: 12 tpc: 2 smt: enabled cache:
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2989 min/max: 422/4669 boost: enabled scaling: driver: amd-pstate-epp
governor: powersave cores: 1: 2989 2: 2989 3: 2989 4: 2989 5: 2989 6: 2989 7: 2989 8: 2989
9: 2989 10: 2989 11: 2989 12: 2989 bogomips: 86236
Device-1: Advanced Micro Devices [AMD/ATI] Cezanne [Radeon Vega Series / Radeon Mobile Series]
vendor: Gigabyte driver: amdgpu v: kernel arch: GCN-5 code: Vega process: GF 14nm built: 2017-20
pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: HDMI-A-1 empty: DP-1,HDMI-A-2
bus-ID: 05:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 29.0 C
Display: wayland server: X.org v: 1.21.1.18 with: Xwayland v: 24.1.8 compositor: kwin_wayland
driver: X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi gpu: amdgpu
display-ID: 0
Monitor-1: HDMI-A-1 model: Dell P2210 serial: <filter> built: 2011 res: mode: 1680x1050 hz: 60
scale: 100% (1) dpi: 90 gamma: 1.2 size: 474x296mm (18.66x11.65") diag: 559mm (22") ratio: 16:10
modes: max: 1680x1050 min: 720x400
gbm: drv: kms_swrast surfaceless: drv: radeonsi wayland: drv: radeonsi x11: drv: radeonsi
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.2.2-arch1.2 glx-v: 1.4
direct-render: yes renderer: AMD Radeon Graphics (radeonsi renoir ACO DRM 3.64 6.16.5-zen1-1-zen)
device-ID: 1002:1638 memory: 500 MiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.321 layers: 14 device: 0 type: integrated-gpu name: AMD Radeon Graphics
(RADV RENOIR) driver: mesa radv v: 25.2.2-arch1.2 device-ID: 1002:1638 surfaces: N/A device: 1
type: cpu name: llvmpipe (LLVM 20.1.8 256 bits) driver: mesa llvmpipe v: 25.2.2-arch1.2 (LLVM
gpu: corectrl wl: wayland-info x11: xdpyinfo, xprop, xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Renoir/Cezanne HDMI/DP Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 05:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 05:00.6
API: ALSA v: k6.16.5-zen1-1-zen status: kernel-api with: aoss type: oss-emulator tools: N/A
Server-2: PipeWire v: 1.4.7 status: active with: 1: pipewire-pulse status: active
Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet vendor: Gigabyte
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 03:00.0
Local Storage: total: 931.51 GiB used: 615.17 GiB (66.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNV2S1000G size: 931.51 GiB
fw-rev: CBG04418 temp: 24.9 C scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 615.17 GiB (66.1%) fs: btrfs
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 632 KiB (0.2%) fs: vfat
ID-3: /home raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 615.17 GiB (66.1%) fs: btrfs
ID-4: /var/log raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 615.17 GiB (66.1%)
ID-5: /var/tmp raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 615.17 GiB (66.1%)
ID-1: swap-1 type: zram size: 14.99 GiB used: 44.4 MiB (0.3%) priority: 100 comp: zstd
System Temperatures: cpu: 37.5 C mobo: 27.0 C gpu: amdgpu temp: 29.0 C
Memory: total: 16 GiB note: est. available: 14.99 GiB used: 3.25 GiB (21.7%)
Processes: 346 Power: uptime: 15m states: freeze,mem,disk suspend: deep avail: s2idle
wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 5.96 GiB
Packages: pm: dpkg pkgs: 0 pm: pacman pkgs: 2591 libs: 590 tools: octopi, pacaur, pacseek,
paru, pikaur, trizen, yay Compilers: clang: 20.1.8 gcc: 15.2.1 alt: 14 Client: Unknown Client:
electron inxi: 3.3.39
Garuda (2.8.2-2):
System install date: 2025-03-21
Last full system update: 2025-09-10
22/23 checks run in 0.77 seconds ⌛
Powered by garuda-health 🦅
… ich habe folgendes Problem: diese beiden Updates tauchen nach jedem Neustart wieder auf, obwohl sie jedesmal geupdated wurden >>> irgendeine Idee hierzu ???
