Update problem with broken dependency
[🔴] × garuda-inxi
  Kernel: 6.14.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=73d9d290-173d-40db-96a9-2f2e5b6744e1 rw rootflags=subvol=@
  Desktop: MATE v: 1.28.2 wm: marco v: 1.28.1 with: mate-panel
    tools: mate-screensaver avail: xautolock vt: 7 dm: LightDM v: 1.32.0
  Type: Laptop System: LENOVO product: 20YGS02Q00 v: ThinkPad E15 Gen 3
  Mobo: LENOVO model: 20YGS02Q00 serial: <superuser required>
    part-nu: LENOVO_MT_20YG_BU_Think_FM_ThinkPad E15 Gen 3
    uuid: <superuser required> UEFI: LENOVO v: R1OET41W (1.20 )
    date: 10/08/2024
  ID-1: BAT0 charge: 44.1 Wh (95.2%) condition: 46.3/45.0 Wh (102.8%)
    volts: 11.8 min: 11.1 model: LGC 5B10X026 type: Li-poly serial: <filter>
    status: not charging cycles: 38
  Info: model: AMD Ryzen 5 5500U with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 2 gen: 2 level: v3 note: check built: 2020-22
    process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x68 (104) stepping: 1
    microcode: 0x8608108
    desc: 6x512 KiB L3: 8 MiB desc: 2x4 MiB
  Speed (MHz): avg: 1113 min/max: 400/4056 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 1113 2: 1113 3: 1113
    4: 1113 5: 1113 6: 1113 7: 1113 8: 1113 9: 1113 10: 1113 11: 1113 12: 1113
    bogomips: 50306
  Device-1: Advanced Micro Devices [AMD/ATI] Lucienne vendor: Lenovo
    built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: eDP-1
    empty: DP-1,HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:164c class-ID: 0300
    temp: 36.0 C
  Device-2: IMC Networks Integrated Camera driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:6 chip-ID: 13d3:56ff
    class-ID: 0e02
    compositor: marco v: 1.28.1 driver: X: loaded: amdgpu unloaded: modesetting
  Monitor-1: eDP-1 mapped: eDP model: Lenovo 0x40ba built: 2019 res:
    max: 1920x1080 min: 640x480
    device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.0.4-arch1.1
    renoir ACO DRM 3.61 6.14.4-zen1-1-zen) device-ID: 1002:164c
    memory: 1000 MiB unified: no
  API: Vulkan v: 1.4.309 layers: 11 device: 0 type: integrated-gpu name: AMD
    Radeon Graphics (RADV RENOIR) driver: mesa radv v: 25.0.4-arch1.1
    device-ID: 1002:164c surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
    (LLVM 19.1.7 256 bits) driver: mesa llvmpipe v: 25.0.4-arch1.1 (LLVM
    19.1.7) device-ID: 10005:0000 surfaces: xcb,xlib
  Info: Tools: api: eglinfo, glxinfo, vulkaninfo
    Audio vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 16 bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
    vendor: Lenovo driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
    vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
    lanes: 16 bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.14.4-zen1-1-zen status: kernel-api tools: N/A
  Server-2: PipeWire v: 1.4.2 status: active with: 1: pipewire-pulse
    port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
    vendor: Lenovo driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:c822
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:2 chip-ID: 0bda:c123
  Local Storage: total: 4.78 TiB used: 4.31 TiB (90.1%)
    model: MZALQ256HBJD-00BL1 size: 238.47 GiB block-size: physical: 512 B
    fw-rev: 9L1QFXM7 temp: 23.9 C scheme: MBR
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: BUP Portable
    size: 4.55 TiB block-size: physical: 4096 B logical: 512 B type: USB
    fw-rev: 0004 scheme: GPT
  ID-1: / raw-size: 230.84 GiB size: 230.84 GiB (100.00%)
    used: 220.6 GiB (95.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-2: /boot/efi raw-size: 7.63 GiB size: 7.62 GiB (99.80%)
    used: 608 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 230.84 GiB size: 230.84 GiB (100.00%)
  ID-4: /var/log raw-size: 230.84 GiB size: 230.84 GiB (100.00%)
  ID-5: /var/tmp raw-size: 230.84 GiB size: 230.84 GiB (100.00%)
  ID-1: swap-1 type: zram size: 6.58 GiB used: 1.9 GiB (28.8%) priority: 100
  System Temperatures: cpu: 41.0 C mobo: N/A gpu: amdgpu temp: 37.0 C
  Fan Speeds (rpm): fan-1: 0 fan-2: 0
  Memory: total: 8 GiB note: est. available: 6.58 GiB used: 2.99 GiB (45.4%)
  Processes: 331 Power: uptime: 4d 4h 36m states: freeze,mem,disk
    reboot, suspend, test_resume image: 2.62 GiB
    services: mate-power-manager,upowerd Init: systemd v: 257
  Packages: pm: pacman pkgs: 1540 libs: 510 tools: octopi,paru Compilers:
    gcc: 14.2.1 Shell: garuda-inxi default: Bash v: 5.2.37
    running-in: mate-terminal inxi: 3.3.38
  System install date:     2024-12-27
  Last full system update: 2025-04-29 ↻
OK, I tried to update and got this:
 garuda downloading...
 core downloading...
 extra downloading...
 multilib downloading...
 chaotic-aur downloading...
spawn pacman -Su
warning: snapper-tools: local (1.3.1-1.6) is newer than chaotic-aur (1.3.1-1)
resolving dependencies...
:: installing libxml2 (2.14.2-2) breaks dependency 'libxml2.so=2-64' required by rest
 ╭─oldrocker99@oldrocker99 in ~ as 🧙 took 38s
[🔴] × yay -R ibxml2.so=2-64
error: target not found: ibxml2.so=2-64
I’m stuck on what to do.
I believe this has been accidentally truncated. What is the full package name there? (rest...)
You can query more about why it’s installed with pacman -Qi pkgname, you may not want to remove it immediately depending on what it is and what needs it.
rest should be an old package that has not been in the repos for a long time and on which no other package depends. You can safely remove it:
sudo pacman -R rest
Thanks you !
It worked! Thanks so much.
lol.
dont get mad at me.
just seen some post or topic related to depency’ s mostly :wink:
like it .)
