Update not possible
Hi all,
I have this error and cannot run an update.
I do not know how to fix this.
Only been browsing and gaming on this laptop, no issues until the update this morning…\
I don’t understand how the system can break without doing anything but an update. . . . .
error: bluez: signature from "Robin Candau <antiz@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/bluez-5.83-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP
signature)).
Do you want to delete it? [Y/n] y
error: bluez-cups: signature from "Robin Candau <antiz@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/bluez-cups-5.83-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package
(PGP signature)).
error: bluez-hid2hci: signature from "Robin Candau <antiz@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/bluez-hid2hci-5.83-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted packa
ge (PGP signature)).
error: bluez-libs: signature from "Robin Candau <antiz@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/bluez-libs-5.83-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package
(PGP signature)).
error: bluez-utils: signature from "Robin Candau <antiz@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/bluez-utils-5.83-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package
(PGP signature)).
error: discord: signature from "Robin Candau <antiz@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/discord-1:0.0.96-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package
(PGP signature)).
error: thermald: signature from "Frederik Schwan <frederik.schwan@linux.com>" is unknown trust
:: File /var/cache/pacman/pkg/thermald-2.5.9-3-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (
PGP signature)).
error: failed to commit transaction (invalid or corrupted package)
Press enter to exit
type or paλ garuda-inxi
Kernel: 6.14.7-arch2-1 arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
clocksource: tsc avail: acpi_pm parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux
root=UUID=96027b0c-1e9d-4b46-8fec-d7788ff1d4d4 rw rootflags=subvol=@
quiet rd.udev.log_priority=3 vt.global_cursor_default=0 loglevel=3
pcie_aspm=off pci=noaer
Type: Laptop System: ASUSTeK product: ROG Strix G713RW_G713RW v: 1.0
Mobo: ASUSTeK model: G713RW v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: G713RW.327
date: 02/16/2023
ID-1: BAT0 charge: 74.8 Wh (100.0%) condition: 74.8/90.0 Wh (83.1%)
volts: 16.5 min: 15.9 model: AS3GWAF3KC GA50358 type: Unknown
serial: <filter> status: full
Info: model: AMD Ryzen 9 6900HX with Radeon Graphics bits: 64 type: MT MCP
family: 0x19 (25) model-id: 0x44 (68) stepping: 1 microcode: 0xA404107
Speed (MHz): avg: 3193 min/max: 400/4936 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 3193 2: 3193 3: 3193
4: 3193 5: 3193 6: 3193 7: 3193 8: 3193 9: 3193 10: 3193 11: 3193 12: 3193
13: 3193 14: 3193 15: 3193 16: 3193 bogomips: 105403
Device-1: NVIDIA GA104 [Geforce RTX 3070 Ti Laptop GPU] vendor: ASUSTeK
driver: nvidia v: 570.153.02 alternate: nouveau,nvidia_drm
gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16 ports: active: none
off: DP-1,eDP-1 empty: HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:24a0
Device-2: Advanced Micro Devices [AMD/ATI] Rembrandt [Radeon 680M]
vendor: ASUSTeK driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: none empty: DP-2, DP-3, DP-4, DP-5, DP-6,
Writeback-1, eDP-2 bus-ID: 05:00.0 chip-ID: 1002:1681 class-ID: 0300
temp: 51.0 C
gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 174 s-size: 373x210mm (14.69x8.27")
s-diag: 428mm (16.85")
Monitor-1: DP-1 mapped: DP-0 note: disabled pos: primary model: PG27AQDM
serial: <filter> built: 2023 res: N/A dpi: 108 gamma: 1.2
size: 600x350mm (23.62x13.78") diag: 695mm (27.3") ratio: 15:9, 16:9
modes: max: 2560x1440 min: 640x480
Monitor-2: eDP-1 mapped: DP-2 note: disabled model: BOE Display 0x0a69
built: 2021 res: N/A dpi: 171 gamma: 1.2 size: 381x214mm (15x8.43")
diag: 437mm (17.2") ratio: 16:9 modes: 2560x1440
drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 570.153.02
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3070 Ti Laptop
GPU/PCIe/SSE2 memory: 7.81 GiB
API: Vulkan v: 1.4.313 layers: 10 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3070 Ti Laptop GPU driver: nvidia v: 570.153.02
device-ID: 10de:24a0 surfaces: N/A device: 1 type: integrated-gpu name: AMD
Radeon 680M (RADV REMBRANDT) driver: mesa radv v: 25.1.1-arch1.2
device-ID: 1002:1681 surfaces: N/A device: 2 type: cpu name: llvmpipe
(LLVM 19.1.7 256 bits) driver: mesa llvmpipe v: 25.1.1-arch1.2 (LLVM
wl: wayland-info x11: xdriinfo, xdpyinfo, xprop, xrandr
Device-1: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
vendor: ASUSTeK driver: snd_pci_acp6x v: kernel alternate: snd_pci_acp3x,
snd_rn_pci_acp3x, snd_pci_acp5x, snd_acp_pci, snd_rpl_pci_acp6x,
snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt,
snd_sof_amd_vangogh, snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
lanes: 16 bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.14.7-arch2-1 status: kernel-api tools: N/A
vendor: AzureWave ASUS PCE-AXE59BT driver: mt7921e v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 14c3:7922 class-ID: 0280
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 03:00.0
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:3 chip-ID: 13d3:3568
Local Storage: total: 953.87 GiB used: 860.5 GiB (90.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2450 MTFDKBA1T0TFK
lanes: 4 tech: SSD serial: <filter> fw-rev: V5MA010 temp: 28.9 C
used: 860.27 GiB (90.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 232 MiB (77.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: zram size: 30.61 GiB used: 5 MiB (0.0%) priority: 100
System Temperatures: cpu: 60.9 C mobo: 54.5 C
Fan Speeds (rpm): cpu: 2700
GPU: device: nvidia screen: :0.0 temp: 46 C device: amdgpu temp: 51.0 C
Memory: total: 32 GiB note: est. available: 30.61 GiB used: 7.06 GiB (23.1%)
Processes: 420 Power: uptime: 6h 53m states: freeze,mem,disk
suspend, test_resume image: 12.17 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2023 libs: 567 tools: octopi,paru Compilers:
clang: 19.1.7 gcc: 15.1.1 Shell: garuda-inxi default: Bash v: 5.2.37
System install date:     2022-12-31
Last full system update: 2025-05-30
Failed units:ste code here
Hi
Please open Garuda Rani → Maintenance → Clean Cache and try to update again .
if its a PGP issue you can try in terminal
sudo pacman -S archlinux-keyring
or you can try this it should update Keyrings aswell : update -syu
Hey,
so, you are using a non-standard kernel, have over 500 additional packages installed, and 3 failed units showing in your garuda-inxi… I’d hardly call this “break without doing anything”. :wink:
There’s an option in Garurda RANI to reset your pacman config and refresh the keyrings. Given the error message, that would be my best guess. You’ll find it in Garuda RANI → System Maintenance → Garuda update rescue tools → Garuda update fix.
After that, you could refresh your mirrows (might be redundant) and start a system update from the Common maintenance tab.
None of these should break anything. Let us know if that works. If it doesn’t there are more invasive things you can try.
sudo pacman -Sy archlinux-keyring chaotic-keyring
garuda-update
Hi there, Garuda rani is not installed? why not? I dont know.
Why Rani didnt get installed with a system update?
I have to install it manually I guess…
+ paccache -ruk 0
==> finished: 341 packages removed (disk space saved: 3.61 GiB)
╰─λ sudo pacman -Sy archlinux-keyring chaotic-keyring
garuda-update
[sudo] password for stamina:
:: Synchronising package databases...
garuda is up to date
core                                  117.8 KiB   673 KiB/s 00:00 [------------------------------------] 100%
extra                                   7.8 MiB  26.9 MiB/s 00:00 [------------------------------------] 100%
multilib                              134.2 KiB   754 KiB/s 00:00 [------------------------------------] 100%
chaotic-aur                           630.4 KiB  1060 KiB/s 00:01 [------------------------------------] 100%
warning: archlinux-keyring-20250430.1-1 is up to date -- reinstalling
warning: chaotic-keyring-20230616-1 is up to date -- reinstalling
resolving dependencies...
Package (2)                  Old Version   New Version   Net Change
core/archlinux-keyring       20250430.1-1  20250430.1-1    0.00 MiB
chaotic-aur/chaotic-keyring  20230616-1    20230616-1      0.00 MiB
Total Installed Size:  1.71 MiB
Net Upgrade Size:      0.00 MiB
(2/2) checking keys in keyring                                     [------------------------------------] 100%
(2/2) checking package integrity                                   [------------------------------------] 100%
:: File /var/cache/pacman/pkg/chaotic-keyring-20230616-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (checksum)).
error: failed to commit transaction (invalid or corrupted package (checksum))
core is up to date
extra is up to date
multilib is up to date
chaotic-aur is up to date
garuda downloading...
core downloading...
extra downloading...
multilib downloading...
chaotic-aur downloading...
spawn pacman -Su
warning: snapper-tools: local (1.3.1-1.6) is newer than chaotic-aur (1.3.1-1)
warning: insufficient columns available for table display
Packages (74) alsa-card-profiles-1:1.4.4-1  bluez-5.83-1  bluez-cups-5.83-1  bluez-hid2hci-5.83-1
bluez-libs-5.83-1  bluez-utils-5.83-1  brave-bin-1:1.79.118-1  ccid-1.6.2-1  discord-1:0.0.96-1
dxvk-async-git-2.6.1.r269.g44518bb-1  egl-x11-1.0.2-1  eza-0.21.4-1  game-devices-udev-0.24-1
garuda-dr460nized-4.6.0-1  gnome-desktop-1:44.3-1  gnome-desktop-common-1:44.3-1
google-chrome-137.0.7151.68-1  gst-libav-1.26.2-1  gst-plugin-pipewire-1:1.4.4-1
gst-plugins-bad-1.26.2-1  gst-plugins-bad-libs-1.26.2-1  gst-plugins-base-1.26.2-1
gst-plugins-base-libs-1.26.2-1  gst-plugins-good-1.26.2-1  gst-plugins-ugly-1.26.2-1
gstreamer-1.26.2-1  gstreamer-vaapi-1.26.2-1  hwdata-0.396-1  iputils-20250602-1  kbd-2.8.0-1
lib32-gst-plugins-base-1.26.2-1  lib32-gst-plugins-base-libs-1.26.2-1
lib32-gst-plugins-good-1.26.2-1  lib32-gstreamer-1.26.2-1  lib32-libldap-2.6.10-1
lib32-libpipewire-1:1.4.4-1  lib32-pipewire-1:1.4.4-1  lib32-pipewire-jack-1:1.4.4-1
lib32-sdl3-3.2.16-1  libarchive-3.8.1-1  libpipewire-1:1.4.4-1  linux-6.14.9.arch1-1
linux-headers-6.14.9.arch1-1  linux-lts-6.12.31-1  linux-lts-headers-6.12.31-1
linux-zen-6.14.9.zen1-1  linux-zen-headers-6.14.9.zen1-1  luajit-2.1.1748459687-1
noto-fonts-1:2025.06.01-1  pipewire-1:1.4.4-1  pipewire-alsa-1:1.4.4-1
pipewire-audio-1:1.4.4-1  pipewire-jack-1:1.4.4-1  pipewire-pulse-1:1.4.4-1
pipewire-v4l2-1:1.4.4-1  pipewire-x11-bell-1:1.4.4-1  pipewire-zeroconf-1:1.4.4-1
plasma5-themes-sweet-full-git-r422.c9e4956-1  python-cryptography-45.0.3-1
python-pypdf-5.6.0-1  python-setuptools-1:80.9.0-1  qt6-base-6.9.0-2  readline-8.2.013-2
resvg-0.45.1-1  sdl3-3.2.16-1  sqlite-3.50.0-1  taglib-2.1-1  thermald-2.5.9-3
visual-studio-code-bin-1.100.3-1  webkit2gtk-2.48.3-1  webkit2gtk-4.1-2.48.3-1
winetricks-git-20250102.r21.g89e18c2a-1  yubikey-manager-1:5.7.0-1  zziplib-0.13.80-1
Total Download Size:    217.69 MiB
Total Installed Size:  3111.04 MiB
Net Upgrade Size:         5.16 MiB
:: Retrieving packages...
bluez-utils-5.83-1-x86_64             979.0 KiB  3.11 MiB/s 00:00 [------------------------------------] 100%
hwdata-0.396-1-any                   1675.6 KiB  5.24 MiB/s 00:00 [------------------------------------] 100%
bluez-5.83-1-x86_64                   565.5 KiB  4.35 MiB/s 00:00 [------------------------------------] 100%
thermald-2.5.9-3-x86_64               213.4 KiB  1721 KiB/s 00:00 [------------------------------------] 100%
iputils-20250602-1-x86_64             139.8 KiB  1109 KiB/s 00:00 [------------------------------------] 100%
bluez-libs-5.83-1-x86_64               91.5 KiB   750 KiB/s 00:00 [------------------------------------] 100%
bluez-cups-5.83-1-x86_64               18.9 KiB   267 KiB/s 00:00 [------------------------------------] 100%
plasma5-themes-sweet-full-git-r4...     3.0 MiB  3.43 MiB/s 00:01 [------------------------------------] 100%
bluez-hid2hci-5.83-1-x86_64             8.5 KiB   110 KiB/s 00:00 [------------------------------------] 100%
discord-1:0.0.96-1-x86_64              76.2 MiB  49.9 MiB/s 00:02 [------------------------------------] 100%
visual-studio-code-bin-1.100.3-1...   134.9 MiB  57.7 MiB/s 00:02 [------------------------------------] 100%
Total (11/11)                         217.7 MiB  86.9 MiB/s 00:03 [------------------------------------] 100%
(74/74) checking keys in keyring                                   [------------------------------------] 100%
(74/74) checking package integrity                                 [------------------------------------] 100%
:: File /var/cache/pacman/pkg/bluez-5.83-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
:: File /var/cache/pacman/pkg/bluez-cups-5.83-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
:: File /var/cache/pacman/pkg/bluez-hid2hci-5.83-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
:: File /var/cache/pacman/pkg/bluez-libs-5.83-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
:: File /var/cache/pacman/pkg/bluez-utils-5.83-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package(PGP signature)).
:: File /var/cache/pacman/pkg/discord-1:0.0.96-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package(PGP signature)).
:: File /var/cache/pacman/pkg/thermald-2.5.9-3-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
--> Some corrupt downloads were detected. Retrying...
spawn pacman -Su --config /tmp/tmp.UcaSigk7WS
Total Download Size:     78.06 MiB
thermald-2.5.9-3-x86_64               213.4 KiB   431 KiB/s 00:00 [------------------------------------] 100%
bluez-5.83-1-x86_64                   565.5 KiB  1136 KiB/s 00:00 [------------------------------------] 100%
bluez-utils-5.83-1-x86_64             979.0 KiB  1868 KiB/s 00:01 [------------------------------------] 100%
bluez-cups-5.83-1-x86_64               18.9 KiB   301 KiB/s 00:00 [------------------------------------] 100%
bluez-hid2hci-5.83-1-x86_64             8.5 KiB   137 KiB/s 00:00 [------------------------------------] 100%
bluez-libs-5.83-1-x86_64               91.5 KiB   133 KiB/s 00:01 [------------------------------------] 100%
discord-1:0.0.96-1-x86_64              76.2 MiB  74.5 MiB/s 00:01 [------------------------------------] 100%
Total (7/7)                            78.1 MiB  71.0 MiB/s 00:01 [------------------------------------] 100%
y
I just don’t understand how the system can get like this? I update regularly and I have not installed any new software.
core                                  117.8 KiB   483 KiB/s 00:00 [------------------------------------] 100%
extra is up to date
chaotic-aur                           630.4 KiB   942 KiB/s 00:01 [------------------------------------] 100%
core downloading...
spawn pacman -Su
Packages (72) alsa-card-profiles-1:1.4.4-1  bluez-5.83-1  bluez-cups-5.83-1  bluez-hid2hci-5.83-1
gstreamer-1.26.2-1  gstreamer-vaapi-1.26.2-1  kbd-2.8.0-1  lib32-gst-plugins-base-1.26.2-1
lib32-gst-plugins-base-libs-1.26.2-1  lib32-gst-plugins-good-1.26.2-1  lib32-gstreamer-1.26.2-1
lib32-libldap-2.6.10-1  lib32-libpipewire-1:1.4.4-1  lib32-pipewire-1:1.4.4-1
lib32-pipewire-jack-1:1.4.4-1  lib32-sdl3-3.2.16-1  libarchive-3.8.1-1  libpipewire-1:1.4.4-1
linux-6.14.9.arch1-1  linux-headers-6.14.9.arch1-1  linux-lts-6.12.31-1
linux-lts-headers-6.12.31-1  linux-zen-6.14.9.zen1-1  linux-zen-headers-6.14.9.zen1-1
luajit-2.1.1748459687-1  noto-fonts-1:2025.06.01-1  pipewire-1:1.4.4-1  pipewire-alsa-1:1.4.4-1
Total Download Size:      0.67 MiB
Total Installed Size:  3100.89 MiB
Net Upgrade Size:         5.04 MiB
bluez-cups-5.83-1-x86_64               18.9 KiB   201 KiB/s 00:00 [------------------------------------] 100%
bluez-hid2hci-5.83-1-x86_64             8.5 KiB  85.7 KiB/s 00:00 [------------------------------------] 100%
bluez-libs-5.83-1-x86_64               91.5 KiB   863 KiB/s 00:00 [------------------------------------] 100%
bluez-5.83-1-x86_64                   565.5 KiB  4.06 MiB/s 00:00 [------------------------------------] 100%
Total (4/4)                           684.4 KiB  4.05 MiB/s 00:00 [------------------------------------] 100%
(72/72) checking keys in keyring                                   [------------------------------------] 100%
(72/72) checking package integrity                                 [------------------------------------] 100%
spawn pacman -Su --config /tmp/tmp.OWEYsUw9V4
bluez-libs-5.83-1-x86_64               91.5 KiB   824 KiB/s 00:00 [------------------------------------] 100%
thermald-2.5.9-3-x86_64               213.4 KiB  1592 KiB/s 00:00 [------------------------------------] 100%
bluez-5.83-1-x86_64                   565.5 KiB  3.97 MiB/s 00:00 [------------------------------------] 100%
bluez-utils-5.83-1-x86_64             979.0 KiB  6.25 MiB/s 00:00 [------------------------------------] 100%
bluez-cups-5.83-1-x86_64               18.9 KiB   789 KiB/s 00:00 [------------------------------------] 100%
bluez-hid2hci-5.83-1-x86_64             8.5 KiB   314 KiB/s 00:00 [------------------------------------] 100%
discord-1:0.0.96-1-x86_64              76.2 MiB  71.5 MiB/s 00:01 [------------------------------------] 100%
Total (7/7)                            78.1 MiB  71.4 MiB/s 00:01 [------------------------------------] 100%
Press enter to exit
╭─stamina@staminstrix in ~
╰─λ garuda-inxi
Kernel: 6.14.7-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
date: 02/16/2023
Speed (MHz): avg: 1100 min/max: 400/4936 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 1100 2: 1100 3: 1100
4: 1100 5: 1100 6: 1100 7: 1100 8: 1100 9: 1100 10: 1100 11: 1100 12: 1100
13: 1100 14: 1100 15: 1100 16: 1100 bogomips: 105391
off: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:24a0
temp: 46.0 C
Screen-1: 0 s-res: 2560x1440 s-dpi: 171 s-size: 380x210mm (14.96x8.27")
s-diag: 434mm (17.09")
Monitor-1: DP-0 pos: primary res: N/A size: 600x350mm (23.62x13.78")
modes: N/A
Monitor-2: DP-2 size-res: N/A modes: N/A
API: ALSA v: k6.14.7-zen2-1-zen status: kernel-api tools: N/A
Local Storage: total: 953.87 GiB used: 860.65 GiB (90.2%)
lanes: 4 tech: SSD serial: <filter> fw-rev: V5MA010 temp: 26.9 C
used: 860.42 GiB (90.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 30.6 GiB used: 5.1 MiB (0.0%) priority: 100
System Temperatures: cpu: 54.2 C mobo: N/A
Fan Speeds (rpm): cpu: 2600
GPU: device: nvidia screen: :0.0 temp: 45 C device: amdgpu temp: 48.0 C
Memory: total: 32 GiB note: est. available: 30.6 GiB used: 3.96 GiB (12.9%)
Processes: 431 Power: uptime: 4m states: freeze,mem,disk suspend: s2idle
image: 12.17 GiB services: org_kde_powerdevil, power-profiles-daemon,
I have been updating this system for 3 years and I have never seen the packages with the prefix bluez-? What is this? why have the installed packages , for example Discord, changed to bluez-Discord?
The packages with bluez as a prefix are coming up with errors.
Does somebody know what to do?
I installed garuda-Rani MANUALLY, I tried to clear cache and run an update - but I still get the same error.
bluez is bluetooth. I think you have problems reading (ie the bluez-discord). You have a missing or corrupt key OR an out of date cache.
I don’t know why your attempt to clear the cache didn’t apparently succeed, because i don’t know exactly how you tried it.
I installed Rani and used the cache clear function.
Well, perhaps you should try the old standby, pacman.
To totally clear the cache (overboard maybe..but why do half measures)?
pacman -Scc
Then update your keyring.
Then if that’s successful, move on to a general update.
pacman -Syu
first 2 successful, thankyou..waiting on 3rd
Thankyou for your suggestions, the terminal output is below.
terminal output :
Cache directory: /var/cache/pacman/pkg/
:: Do you want to remove ALL files from cache? [y/N] y
removing all files from cache...
Database directory: /var/lib/pacman/
:: Do you want to remove unused repositories? [Y/n] y
removing unused sync repositories...
╭─stamina@staminstrix in ~ as 🧙 took 15s
╰─λ sudo pacman -S archlinux-keyring
Package (1)             Old Version   New Version   Net Change  Download Size
core/archlinux-keyring  20250430.1-1  20250430.1-1    0.00 MiB       1.18 MiB
Total Download Size:   1.18 MiB
Total Installed Size:  1.68 MiB
archlinux-keyring-20250430.1-1-any   1208.4 KiB  8.08 MiB/s 00:00 [------------------------------------] 100%
(1/1) checking keys in keyring                                     [------------------------------------] 100%
(1/1) checking package integrity                                   [------------------------------------] 100%
(1/1) loading package files                                        [------------------------------------] 100%
(1/1) checking for file conflicts                                  [------------------------------------] 100%
(1/1) checking available disk space                                [------------------------------------] 100%
==> root: 701
(1/1) reinstalling archlinux-keyring                               [------------------------------------] 100%
==> Appending keys from archlinux.gpg...
==> Updating trust database...
gpg: next trustdb check due at 2026-03-13
(1/9) Reloading system manager configuration...
(2/9) Restarting marked services...
(3/9) Arming ConditionNeedsUpdate...
(4/9) Checking for package with missing dependencies...
File "/usr/lib/qt/plugins/kf5/kfilemetadata/kfilemetadata_appimageextractor.so" from package "kfilemetadata5" is missing dependency "libappimage.so.1.0"
File "/usr/lib/libkhotkeysprivate.so.5.27.10" from package "khotkeys" is missing dependency "libkworkspace5.so.5"
File "/usr/lib/qt/plugins/kcm_hotkeys.so" from package "khotkeys" is missing dependency "libkworkspace5.so.5"
File "/usr/lib/qt/plugins/kf5/kded/khotkeys.so" from package "khotkeys" is missing dependency "libkworkspace5.so.5"
Package "python-shiboken2" has files in directory "/usr/lib/python3.11" that are ignored by the current Pythoninterpreter
Systemd enabled service has broken link in "/etc/systemd/system/local-fs.target.wants/ananicy-cpp.service"
Systemd enabled service has broken link in "/etc/systemd/system/multi-user.target.wants/irqbalance.service"
Systemd enabled service has broken link in "/etc/systemd/system/multi-user.target.wants/preload.service"
(5/9) Foreign/AUR package notification
asusctl-git 5.0.8.r0.gbb7b3a8-1
authy 2.5.0-1
faudio 24.03-1
js102 102.15.1-2
kcontacts5 5.116.0-1
kdelibs4support 5.116.0-1
kemoticons 5.116.0-1
kfilemetadata5 5.116.0-2
khotkeys 5.27.10-1
kirigami-addons5 0.11.0-7
kjs 5.115.0-1
kpeople5 5.116.0-1
kpeoplevcard 0.1-2
kquickcharts5 5.115.0-1
krunner5 5.115.0-1
kwin-scripts-forceblur 0.6.1-1.3
latte-dock 0.10.9-1
lib32-blas 3.11.0-1
lib32-faudio 24.01-1
lib32-gsm 1.0.22-1
lib32-lapack 3.11.0-1
lib32-libva-vdpau-driver 0.7.4-8
libsidplay 1.36.59-10
libva-vdpau-driver 0.7.4-7
libvisual 0.4.2-2
modemmanager-qt5 5.116.0-1
plasma5-applets-eventcalendar 76-1.4
plasma5-applets-netspeed 2.0-1
proton-ge-custom 2:GE.Proton9.23-1
python-shiboken2 5.15.13-1
qqc2-desktop-style5 5.116.1-1
reiserfsprogs 3.6.27-5
rootactions-servicemenu 2.7.3-1
stacer 1.1.0-1.4
surfshark-client 1.6.0.2040-1
t1lib 5.1.2-8
wine-tkg-staging-fsync-git 9.19.r0.g858bf979-327
yubioath-desktop 5.1.0-3
(6/9) Orphaned package notification...
adobe-source-code-pro-fonts 2.042u+1.062i+1.026vf-2
bc 1.08.2-1
bluez-qt5 5.116.0-1
box2d 3.1.0-1
cython 3.1.1-1
fish-autopair 1.0.4-2
gcab 1.6-2
gptfdisk 1.0.10-1
gtkglext 1.2.0-20.3
gtkmm 1:2.24.5-5
http-parser 2.9.4-2
js102 102.15.1-2
js115 115.24.0-1
jxrlib 0.2.4-2
kactivities-stats5 5.116.0-1
kcmutils5 5.116.0-1
kdeplasma-addons 6.3.5-1
kdesu5 5.116.0-1
kdnssd5 5.116.0-1
kdsoap-qt5 2.2.0-1
kholidays5 1:5.116.0-1
kidletime5 5.116.0-1
kimageannotator-qt5 0.7.1-3
kjs 5.115.0-1
knotifyconfig5 5.116.0-1
kpeoplevcard 0.1-2
krunner5 5.115.0-1
ktexteditor5 5.116.0-1
ldns 1.8.4-1
lib32-gsm 1.0.22-1
lib32-gst-plugins-base 1.26.1-1
lib32-gst-plugins-good 1.26.1-1
lib32-pcsclite 2.3.3-1
libgsf 1.14.53-2
libical 3.0.20-2
libindicator-gtk3 12.10.1-10
libkdcraw5 25.04.1-1
libomxil-bellagio 0.9.3-5
libqaccessibilityclient-qt5 0.6.0-1
libsmbios 2.4.3-8
libvips 8.16.1-2
libvisual 0.4.2-2
libxres 1.2.2-2
lua53 5.3.6-3
mbedtls2 2.28.10-1
mcfly 0.9.3-1
mkinitcpio-busybox 1.36.1-1
networkmanager-qt5 5.116.0-1
openfortivpn 1.23.1-1
oxygen-sounds 6.3.5-1
perl-ipc-run3 0.049-2
perl-parse-yapp 1.21-8
purpose5 5.116.0-1
python-appdirs 1.4.4-11
python-build 1.2.2-3
python-colorama 0.4.6-5
python-deprecated 1.2.18-1
python-importlib-metadata 8.7.0-1
python-installer 0.7.0-10
python-llfuse 1.5.0-3
python-ordered-set 4.1.0-7
python-paramiko 3.5.0-1
python-ply 3.11-14
python-pycurl 7.45.6-1
python-pydantic 2.11.5-1
python-pyrate-limiter 3.7.0-2
python-rx 3.2.0-8
python-tomli 2.0.1-5
python-toolz 1.0.0-2
python-uc-micro-py 1.0.3-3
python-validate-pyproject 0.24.1-1
python-xxhash 3.5.0-1
qt5-networkauth 5.15.17-1
qtkeychain-qt5 0.15.0-1
rapidjson 1.1.0-6
run-parts 5.22-1
sysfsutils 2.1.1-2
t1lib 5.1.2-8
tinycompress 1.2.13-1
vulkan-headers 1:1.4.313.0-1
wayland-protocols 1.44-1
webrtc-audio-processing-0.3 0.3.1-6
wine-gecko 2.47.4-2
wine-mono 10.0.0-1
wpebackend-fdo 1.16.0-1
xorg-xsetroot 1.1.3-2
yubikey-personalization 1.20.0-4
(7/9) Checking for .pacnew and .pacsave files...
.pac* files found:
/etc/pacman.d/chaotic-mirrorlist.pacnew
/etc/hosts.pacnew
/etc/issue.pacnew
/etc/passwd.pacnew
/etc/shells.pacnew
/etc/locale.gen.pacnew
/etc/default/grub.pacnew
/etc/pam.d/kde.pacnew
/etc/pacman.conf.pacnew
/etc/makepkg.conf.d/rust.conf.pacnew
/etc/updatedb.conf.pacsave
Please check and merge
==> root: 702
╭─stamina@staminstrix in ~ as 🧙 took 9s
╰─λ pacman -Syu
error: you cannot perform this operation unless you are root.
╭─stamina@staminstrix in ~ as 🧙 took 0s
[🔴] × sudo pacman -Syu
Garuda Linux is updated via the "garuda-update" command instead of pacman -Syu. https://wiki.garudalinux.org/en/garuda-update
Would you like to run "garuda-update" instead? (i = never ask again/ignore) [y/N/i] y
core is up to date
extra                                   7.8 MiB  25.8 MiB/s 00:00 [------------------------------------] 100%
core downloading...
spawn pacman -Su
dxvk-async-git-2.6.1.r270.g9cba329-1  egl-x11-1.0.2-1  eza-0.21.4-1  game-devices-udev-0.24-1
Total Download Size:   1267.77 MiB
linux-lts-6.12.31-1-x86_64            138.0 MiB  21.9 MiB/s 00:06 [------------------------------------] 100%
linux-zen-6.14.9.zen1-1-x86_64        144.3 MiB  22.9 MiB/s 00:06 [------------------------------------] 100%
google-chrome-137.0.7151.68-1-x86_64  153.3 MiB  22.9 MiB/s 00:07 [------------------------------------] 100%
linux-6.14.9.arch1-1-x86_64           139.2 MiB  20.7 MiB/s 00:07 [------------------------------------] 100%
brave-bin-1:1.79.118-1-x86_64         165.7 MiB  22.5 MiB/s 00:07 [------------------------------------] 100%
discord-1:0.0.96-1-x86_64              76.2 MiB  27.1 MiB/s 00:03 [------------------------------------] 100%
linux-headers-6.14.9.arch1-1-x86_64    50.3 MiB  21.3 MiB/s 00:02 [------------------------------------] 100%
linux-zen-headers-6.14.9.zen1-1-...    51.2 MiB  20.3 MiB/s 00:03 [------------------------------------] 100%
webkit2gtk-4.1-2.48.3-1-x86_64         33.5 MiB  11.2 MiB/s 00:03 [------------------------------------] 100%
linux-lts-headers-6.12.31-1-x86_64     26.8 MiB  21.7 MiB/s 00:01 [------------------------------------] 100%
noto-fonts-1:2025.06.01-1-any          27.9 MiB  20.7 MiB/s 00:01 [------------------------------------] 100%
webkit2gtk-2.48.3-1-x86_64             33.4 MiB  21.1 MiB/s 00:02 [------------------------------------] 100%
visual-studio-code-bin-1.100.3-1...   134.9 MiB  30.4 MiB/s 00:04 [------------------------------------] 100%
qt6-base-6.9.0-2-x86_64                14.3 MiB  48.4 MiB/s 00:00 [------------------------------------] 100%
gst-plugins-bad-libs-1.26.2-1-x86_64    2.9 MiB  40.8 MiB/s 00:00 [------------------------------------] 100%
gst-plugins-base-libs-1.26.2-1-x...     2.3 MiB  32.5 MiB/s 00:00 [------------------------------------] 100%
sqlite-3.50.0-1-x86_64                  2.2 MiB  36.0 MiB/s 00:00 [------------------------------------] 100%
gst-plugins-good-1.26.2-1-x86_64        2.2 MiB  33.9 MiB/s 00:00 [------------------------------------] 100%
dxvk-async-git-2.6.1.r270.g9cba3...    10.0 MiB  13.9 MiB/s 00:01 [------------------------------------] 100%
gstreamer-1.26.2-1-x86_64               2.0 MiB  27.2 MiB/s 00:00 [------------------------------------] 100%
garuda-dr460nized-4.6.0-1-any          22.9 MiB  27.4 MiB/s 00:01 [------------------------------------] 100%
lib32-gst-plugins-good-1.26.2-1-...     2.0 MiB  20.4 MiB/s 00:00 [------------------------------------] 100%
plasma5-themes-sweet-full-git-r4...     3.0 MiB  4.51 MiB/s 00:01 [------------------------------------] 100%
resvg-0.45.1-1-x86_64                   5.5 MiB  7.52 MiB/s 00:01 [------------------------------------] 100%
hwdata-0.396-1-any                   1675.6 KiB  15.2 MiB/s 00:00 [------------------------------------] 100%
pipewire-audio-1:1.4.4-1-x86_64      1575.8 KiB  30.8 MiB/s 00:00 [------------------------------------] 100%
sdl3-3.2.16-1-x86_64                 1410.7 KiB  20.9 MiB/s 00:00 [------------------------------------] 100%
lib32-gst-plugins-base-libs-1.26...  1597.1 KiB  15.6 MiB/s 00:00 [------------------------------------] 100%
lib32-pipewire-1:1.4.4-1-x86_64      1351.8 KiB  18.6 MiB/s 00:00 [------------------------------------] 100%
kbd-2.8.0-1-x86_64                   1258.1 KiB  27.3 MiB/s 00:00 [------------------------------------] 100%
python-cryptography-45.0.3-1-x86_64  1267.1 KiB  10.9 MiB/s 00:00 [------------------------------------] 100%
python-setuptools-1:80.9.0-1-any     1216.6 KiB  20.1 MiB/s 00:00 [------------------------------------] 100%
lib32-gstreamer-1.26.2-1-x86_64      1172.4 KiB  20.1 MiB/s 00:00 [------------------------------------] 100%
gst-plugins-bad-1.26.2-1-x86_64      1143.9 KiB  18.9 MiB/s 00:00 [------------------------------------] 100%
lib32-sdl3-3.2.16-1-x86_64           1003.9 KiB  20.0 MiB/s 00:00 [------------------------------------] 100%
bluez-utils-5.83-1-x86_64             979.0 KiB  24.5 MiB/s 00:00 [------------------------------------] 100%
eza-0.21.4-1-x86_64                   586.0 KiB  18.5 MiB/s 00:00 [------------------------------------] 100%
python-pypdf-5.6.0-1-any              674.8 KiB  16.1 MiB/s 00:00 [------------------------------------] 100%
pipewire-1:1.4.4-1-x86_64             651.7 KiB  15.2 MiB/s 00:00 [------------------------------------] 100%
bluez-5.83-1-x86_64                   565.5 KiB  13.8 MiB/s 00:00 [------------------------------------] 100%
libarchive-3.8.1-1-x86_64             558.3 KiB  12.4 MiB/s 00:00 [------------------------------------] 100%
libpipewire-1:1.4.4-1-x86_64          461.2 KiB  15.0 MiB/s 00:00 [------------------------------------] 100%
gnome-desktop-common-1:44.3-1-x86_64  446.1 KiB  13.2 MiB/s 00:00 [------------------------------------] 100%
taglib-2.1-1-x86_64                   452.6 KiB  12.3 MiB/s 00:00 [------------------------------------] 100%
yubikey-manager-1:5.7.0-1-any         422.2 KiB  11.1 MiB/s 00:00 [------------------------------------] 100%
luajit-2.1.1748459687-1-x86_64        328.0 KiB  10.3 MiB/s 00:00 [------------------------------------] 100%
gstreamer-vaapi-1.26.2-1-x86_64       313.9 KiB  10.9 MiB/s 00:00 [------------------------------------] 100%
readline-8.2.013-2-x86_64             325.5 KiB  7.22 MiB/s 00:00 [------------------------------------] 100%
lib32-libpipewire-1:1.4.4-1-x86_64    292.3 KiB  8.16 MiB/s 00:00 [------------------------------------] 100%
thermald-2.5.9-3-x86_64               213.4 KiB  6.31 MiB/s 00:00 [------------------------------------] 100%
gst-plugins-base-1.26.2-1-x86_64      210.9 KiB  5.28 MiB/s 00:00 [------------------------------------] 100%
lib32-gst-plugins-base-1.26.2-1-...   205.4 KiB  6.47 MiB/s 00:00 [------------------------------------] 100%
pipewire-pulse-1:1.4.4-1-x86_64       202.2 KiB  6.81 MiB/s 00:00 [------------------------------------] 100%
gst-plugins-ugly-1.26.2-1-x86_64      177.6 KiB  4.82 MiB/s 00:00 [------------------------------------] 100%
pipewire-jack-1:1.4.4-1-x86_64        162.3 KiB  5.28 MiB/s 00:00 [------------------------------------] 100%
lib32-libldap-2.6.10-1-x86_64         159.9 KiB  3.55 MiB/s 00:00 [------------------------------------] 100%
iputils-20250602-1-x86_64             139.8 KiB  3.10 MiB/s 00:00 [------------------------------------] 100%
pipewire-zeroconf-1:1.4.4-1-x86_64    114.8 KiB  3.40 MiB/s 00:00 [------------------------------------] 100%
gnome-desktop-1:44.3-1-x86_64         114.6 KiB  3.86 MiB/s 00:00 [------------------------------------] 100%
lib32-pipewire-jack-1:1.4.4-1-x86_64  105.9 KiB  3.45 MiB/s 00:00 [------------------------------------] 100%
gst-libav-1.26.2-1-x86_64              97.6 KiB  3.40 MiB/s 00:00 [------------------------------------] 100%
bluez-libs-5.83-1-x86_64               91.5 KiB  3.31 MiB/s 00:00 [------------------------------------] 100%
ccid-1.6.2-1-x86_64                    81.1 KiB  3.04 MiB/s 00:00 [------------------------------------] 100%
gst-plugin-pipewire-1:1.4.4-1-x86_64   64.4 KiB  1571 KiB/s 00:00 [------------------------------------] 100%
zziplib-0.13.80-1-x86_64               64.3 KiB  2.24 MiB/s 00:00 [------------------------------------] 100%
pipewire-v4l2-1:1.4.4-1-x86_64         40.7 KiB  1072 KiB/s 00:00 [------------------------------------] 100%
egl-x11-1.0.2-1-x86_64                 37.8 KiB   946 KiB/s 00:00 [------------------------------------] 100%
alsa-card-profiles-1:1.4.4-1-x86_64    27.4 KiB   701 KiB/s 00:00 [------------------------------------] 100%
bluez-cups-5.83-1-x86_64               18.9 KiB   592 KiB/s 00:00 [------------------------------------] 100%
pipewire-x11-bell-1:1.4.4-1-x86_64     10.2 KiB   292 KiB/s 00:00 [------------------------------------] 100%
bluez-hid2hci-5.83-1-x86_64             8.5 KiB   293 KiB/s 00:00 [------------------------------------] 100%
pipewire-alsa-1:1.4.4-1-x86_64          5.0 KiB  98.4 KiB/s 00:00 [------------------------------------] 100%
winetricks-git-20250102.r21.g89e...   185.0 KiB   233 KiB/s 00:01 [------------------------------------] 100%
game-devices-udev-0.24-1-any            9.5 KiB  16.5 KiB/s 00:01 [------------------------------------] 100%
Total (74/74)                        1267.8 MiB  98.4 MiB/s 00:13 [------------------------------------] 100%
spawn pacman -Su --config /tmp/tmp.vUFal1bzV4
thermald-2.5.9-3-x86_64               213.4 KiB  1395 KiB/s 00:00 [------------------------------------] 100%
bluez-libs-5.83-1-x86_64               91.5 KiB   583 KiB/s 00:00 [------------------------------------] 100%
bluez-utils-5.83-1-x86_64             979.0 KiB  5.66 MiB/s 00:00 [------------------------------------] 100%
bluez-5.83-1-x86_64                   565.5 KiB  2.78 MiB/s 00:00 [------------------------------------] 100%
bluez-hid2hci-5.83-1-x86_64             8.5 KiB   424 KiB/s 00:00 [------------------------------------] 100%
bluez-cups-5.83-1-x86_64               18.9 KiB   823 KiB/s 00:00 [------------------------------------] 100%
discord-1:0.0.96-1-x86_64              76.2 MiB  77.1 MiB/s 00:01 [------------------------------------] 100%
Total (7/7)                            78.1 MiB  76.8 MiB/s 00:01 [------------------------------------] 100%
y
It failed again though with the same message.
Should i not delete the corrupted packages that its says? I am unable to answer Y or N it does it automatically
for example:
It is possible the file is actually corrupted on the mirror, though unlikely. I have the bluetooth packages installed, so I know they’re (at least on some mirrors) originally fine.
I’m unsure why you have broken dependencies and broken links (which may well be in someway related to your issues).
Maybe your disk is failing or filesystem is corrupted.
I think I will try to reinstall the packages it mentions and see what happens.
Thankyou for you help and suggestions.
So I searched more on the issue, and found this thread.
https://forum.garudalinux.org/t/every-pgp-file-shows-corrupt/33493/5?u=tag
The command that solved the problem was:
update remote keyring
Update is now working, thanks again for all the help and suggestions @dbarron @BluishHumility @Duke187 @MagDux
BTW, update (garuda-update or upd) include all things you need.
Your hint failed.
Before you post here in the forum, you should check that your entries are correct and error-free.
update -syu
/usr/bin/garuda-update: invalid option -- 's'
/usr/bin/garuda-update: invalid option -- 'y'
/usr/bin/garuda-update: invalid option -- 'u'
update -Syu
/usr/bin/garuda-update: invalid option -- 'S'
Just update or sudo pacman -Syu.
At all, just read the wiki about garuda-update, please.
yes you are right SGS. I was on pc and have to go and swapped on phone and had arch commands in my head. I know this site too . Thanks for it :wink:
It is supposed to be pre installed since the last ISO, and we didn’t take the step to replace the older tools with it yet.
