Hello.
This really isn't a problem or anything but I was wondering if the light.sh could be updated to handle being called by a key combo also? (Like I could do SHIFT + i (eye)) to disable/enable it.
Kernel: 5.16.11-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=5ea32362-776b-4a64-a2e7-1e1492b1137b rw rootflags=subvol=@
resume=UUID=99213909-149f-4663-8cb0-b7431f100328 loglevel=3
Desktop: sway 1.7 info: waybar vt: 1 dm: greetd Distro: Garuda Linux
Type: Laptop System: Dell product: XPS 13 9350 v: N/A
Mobo: Dell model: 0PWNCR v: A01 serial: <superuser required> UEFI: Dell
v: 1.11.1 date: 08/01/2019
ID-1: BAT0 charge: 30.4 Wh (100.0%) condition: 30.4/56.0 Wh (54.3%)
volts: 8.6 min: 7.6 model: LGC-LGC7.3 DELL 5K9CP5A type: Li-ion
serial: <filter> status: Full
Info: model: Intel Core i7-6500U bits: 64 type: MT MCP arch: Skylake
family: 6 model-id: 0x4E (78) stepping: 3 microcode: 0xEC
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 2550 high: 2984 min/max: 400/3100 scaling:
driver: intel_pstate governor: performance cores: 1: 2984 2: 2521 3: 2362
4: 2333 bogomips: 20799
Type: l1tf
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Dell driver: i915
v: kernel ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
Device-2: Microdia Integrated Webcam HD type: USB driver: uvcvideo
bus-ID: 1-5:4 chip-ID: 0c45:670c class-ID: 0e02
Display: wayland server: Xwayland v: 22.1.0 compositor: sway v: 1.7
driver: gpu: i915 display-ID: 1
Monitor-1: eDP-1 model: Sharp built: 2015 res: 3200x1800 hz: 60 dpi: 276
gamma: 1.2 scale: 2 size: 294x165mm (11.6x6.5") diag: 337mm (13.3")
ratio: 16:9 modes: 3200x1800
Message: Wayland GBM/EGL data currently not available.
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell
Sound Server-1: ALSA v: k5.16.11-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.47 running: yes
Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 3a:00.0 chip-ID: 8086:095a class-ID: 0280
IF: wlp58s0 state: up mac: <filter>
bus-ID: 1-3:3 chip-ID: 8087:0a2a class-ID: e001
address: <filter>
v: 3.0 port: f060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A
class-ID: 0104
Local Storage: total: 465.76 GiB used: 50.13 GiB (10.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO M.2 500GB
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-1: / raw-size: 456.66 GiB size: 456.66 GiB (100.00%)
used: 50.13 GiB (11.0%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 456.66 GiB size: 456.66 GiB (100.00%)
ID-4: /var/log raw-size: 456.66 GiB size: 456.66 GiB (100.00%)
ID-5: /var/tmp raw-size: 456.66 GiB size: 456.66 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.63 GiB used: 2 MiB (0.0%) priority: 100
System Temperatures: cpu: 56.0 C pch: 45.5 C mobo: 39.0 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 0
Processes: 229 Uptime: 1d 21h 4m wakeups: 5 Memory: 7.63 GiB
used: 2.71 GiB (35.6%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1324 lib: 327 Shell: Zsh
v: 5.8.1 running-in: alacritty inxi: 3.3.13
Garuda (2.5.5-1):
System install date: 2021-12-08
Last full system update: 2022-03-01
I looked at the light.sh and it looks like a simple if statement could make this work? Is this something that anyone else would use?
#!/bin/sh
CONTENT=$(curl -s https://freegeoip.app/json/)
longitude=$(echo $CONTENT | jq .longitude)
latitude=$(echo $CONTENT | jq .latitude)
PID=$(pgrep wlsunset)
if [ $PID ]; then
kill $PID
else
wlsunset -l $latitude -L $longitude &
fi
